    Automatic Location Refreshed Daily
    Scheduled Pinned Locked Moved Feature Requests
    6 Posts 3 Posters 3.7k Views 2 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      The issue with that is that it isn’t reliable. For example, my public IP says I’m in a town about an hour away because that is where Comcast’s main hub is. I’ve gone through this with a different project as well and it simply wasn’t reliable. For some people, or some cities it would work, but others it would simply put you where the service provider decide to resolve the IP, and often it’s at their main hub. You’re better off getting a cheap GPS unit for the rPi and using that. And no, that’s not a project I want to put on my plate, at least not for the foreseeable future.
      • KirAsh4K Offline
        KirAsh4 Moderator
        Also, depending on where they move to, the rPi’s settings will also need to be changed, timezones for example, and if they cross a big body of water, also the LOCALE … And that’s outside the scope of this project.
        • N Offline
          Nichollsg
          Yeah, that is one of the things that I have heard about and that is one of my biggest concerns. However, the people that I am going to be gifting this too live in big enough cities that the IP address location I have searched of each is still within the correct city limits. I will look into adding GPS to the pi for that, but it is definitely going to increase the price of this project along with time to figure out how to make it to work.
          If I were to approach this problem of using IP to get a city name, how would I go about adding that to the default/non-default weather or future modules? would it be best to use Python or Node.js?
          • N Offline
            Nichollsg @KirAsh4
            @KirAsh4 Yeah, I totally see why that could cause a huge headache of a problem!
            • cowboysdudeC Offline
              Unless you install a GPS module to show location… which is possible…
