    MMM-Jnews
    Scheduled Pinned Locked Moved Education
    33 Posts 10 Posters 22.0k Views 8 Watching
      bjoern
      Great module. I like it. Question: Some lines of text consist of 3 lines and the next message is 4. As a result, the modules above will always jump “up and down”. Can you set the module to 4 lines and these automatically fill depending on the content? Do you understand what I want to express?
        bhepler Module Developer @jeffreyking
        @jeffreyking -
        Just in case nobody else mentions it, you should delete the advice in the square brackets from your config.js file. The part that looks like this: [default is false, Raspberry Pi's don't like the images]
        Delete in the part in the square brackets from the next line as well. They are commentary from the developer.
        • cowboysdudeC Offline
          cowboysdude Module Developer @bjoern
          @bjoern I do and I will look at it :)
            cowboysdude Module Developer @bhepler
            @bhepler Changed the README.md as this has happened more than once LOL
              jeffreyking
              All working now just had to place a position line in thanks you so much.
                jeffreyking
                How can I make the module larger thank you
                  cowboysdude Module Developer @jeffreyking
                  @jeffreyking add this to your custom.css file
                         .MMM-Jnews .flex-item {
                          font-size: 22px;
                  Make the font-size whatever you want :)
                    jeffreyking
                    Thank you what about the picture
                      @jeffreyking
                      custom.css
                        .MMM-Jnews .image {
                      width:  90%;
                      height:  90%;
                      border-style: solid;
                      border-color: #92a8d1;
                      Be careful with that as the space provided will over write your text…so just trial and error.
                        darbos
                        This is nice! Thank you!
                        Quick question regarding your note on your github page. Ive only had a mirror for maybe 2 weeks, its running on a pi 3b+. I have a good amount of moduiles, but not all showing all the time and my pi sits around 55-60c .
                        Would it be better to run the magic mirror software on an ubuntu vm and just use fullpageos or something similar on the pi? Im not sure if that would take most the processing away from the pi or not?
                          cowboysdude Module Developer @darbos
                          @darbos mine runs on a mini itx board so I can pretty much do what I want.
                          If you want the basic MM then the PI is fine but if you want more you have to think bigger. ;)
                            darbos
                            I am just curious how much load is actually taken away from the pi if MM is actually running on a vm elsewhere(dell r720). I would think the pi is still gotta do some video processing correct?
                            I am looking to add some “pages” specifically going to make it so I can tell google to show me my security cams and have all my normal modules fade away and bring the cameras up(12 outdoor). I would actually like to make a couple pages with different information to be able to do that. I love this thing, thank you for sharing your hard work! I see your a hard workin guy out here.
                            I was lookin at those intel sticks possibly, I have never messed with one yet though. Ill take a look at the board you mentioned. Thanks
                            btw, its really easy to integrate voice if you use homeassistant, just using the apis / mqtt / remote module. I was looking for a module for a while that would let me create pages instead of having to call each module out with remote, i just happened to stumble on to it today
                              darbos
                              those look nice, thanks! i had to write back so quick cause that got me really curious. Ive seen quite a bit of your posts scrollin through here, but I havent seen your mirror, would you mind sharing a peek?
                                @darbos https://forum.magicmirror.builders/topic/1489/the-32-inch-mirror
                                I’ll post some updated ones for you :) I have 2 actually…one in the bathroom and my 32" I put on the wall in the kitchen…
                                Here are some videos
                                https://www.youtube.com/user/TheCowboysdude/videos
                                  darbos @cowboysdude
                                  @cowboysdude Dang, thats sweet!! Im gonna have to try that voice out
                                  • O Offline
                                    Ob018
                                    Hi, thanks for your module.
                                    It works perfectly.
                                    • I was wondering if you could add a way to “force” a specific language ?
                                      ( my mirror language is English and i would love to read the French news )
                                    • Is there a way to display more than 1 article at a time ?
                                    Thanks.
                                    G.
                                    Y cowboysdudeC 2 Replies Last reply Reply Quote 0
                                    • Y Offline
                                      yawns Moderator @Ob018
                                      @ob018 said in MMM-Jnews:
                                      mh, you could try to use this:
                                      	module: 'MMM-Jnews',
                                      		lang: "fr",
                                      		apiKey: "YOUR API KEY",
                                      		image : true,
                                      		rotateInterval: 25 * 1000
                                        Description:
                                        Added Language override support
                                        Please follow Readme on Github!
                                        Screenshots:
                                        Version 2.0.1
                                        Download:
                                        [card:cowboysdude/MMM-Jnews]
                                          cowboysdude Module Developer @Ob018
                                          @ob018 do a git pull and SEE README on how to use. ;)
                                          • O Offline
                                            Ob018 @cowboysdude
                                            @cowboysdude Yes ! Thanks a lot. you rock ;)
