    MMM-GooglePhotos
    294 Posts 56 Posters 389.0k Views 59 Watching
      [[global:former-user]] @kapsolas
      @kapsolas
        module: "MMM-GooglePhotos",
        position: "fullscreen_below",
          albumId: "<YOUR_GOOGLE_PHOTOS_ALBUM_ID>", // your album id from result of `auth_and_test.js`
          refreshInterval: 1000*60,  // too short refreshing might cause API quota limit. Under 10sec will exhaust your quota(usually total  under 25000 per day).
          scanInterval: 1000*60*60, // too many scans might cause API quota limit also.
          sort: "time", //'time', 'reverse', 'random'
          showWidth: "100%", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
          showHeight: "100%",
          originalWidthPx: 1920, // original size of loaded image. (related with image quality)
          originalHeightPx: 1080, // Bigger size gives you better quality, but can give you network burden.
          mode: "cover", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
      And you might need to adjust your css for your purpose (margin or padding)
      • K Offline
        kapsolas Module Developer @Guest
        @sean Thanks!
        Another question… If i have an album which I’ve shared, images from that party are not showing up.
        Actually, after adding some debugging in the node_helper file, the body (freehanded the response as I don’t have the exact body handy) from the API
        Status code: 400
        Message: “The media item is not in the user’s library it was contributed by another user to…”
        Basically, their was an unhandled exception being thrown where your case statement is for: time, reverse, random.
        Any idea how to configure the album to allow the API to pull all images regardless of who uploaded them?
          @kapsolas
          The picture was not created by you, right?
          I’ll research and try to fix it.
          • K Offline
            Correct.
            The setup is as follows:
            1. I created a shared album
            2. Invited my wife to it
            3. I uploaded photos
            4. My wife uploaded photos
            When I tried to set up the plugin, I discovered it was failing. I modified the code to print the body to the console and saw the message from the Google Photos API.
            The response is:
            error:
            { code: 400,
            message: ‘The media item is not in the user's library. It was contributed by another user to a shared album that this user joined to.’
            status: ’ INVALID_ARGUMENT’ }
            If we could get this to work, it would be a nice way to use GooglePhotos act like an online digital photo frame. Anyone with access to the shared album can upload photos.
              @kapsolas
              I guess the reason is the scope rule. “readonly” is set for the scope of API using. I’ll change it to “https://www.googleapis.com/auth/photoslibrary.sharing”, but it’s just guessing. Test will be needed.
              After fixing, I’ll tell you.
              (Today, I purchased my new MBP and am migrating, so I’m not ready to develop something, so it’ll take somewhat time.)
                @kapsolas
                Fixed. (I think). Try it. (just git pull, no need to npm install)
                mediaItem:search API could access photos shared from others, but mediaItem/ID API couldn’t. It looks so weird. Anyway, I changed it to use mediaItem:search. The only risk is expiration of temporary image URL, so you’d better keep scanInterval under 1 hour.
                • K Offline
                  Awesome! That worked and solved it!
                  I’ll need to pay around a bit with the sizes in the config (hopefully not the code) to see if I can get the images to display in the screen fully.
                  For now the images are being cropped as they are larger than the display area on the screen.
                  Again thank you!
                    @kapsolas set the mode to cover or contain. cover will be fit your entire region as large as possible but cropped, contain will show the entire image but has some black tape around top and bottom or left and right by the ratio of photo width/height like movie film.
                    • K Offline
                      kivlow
                      Hello i use node auth_and_test.js but i dont have any album ID in terminal only info : auth_and_test started.
                      What to do to get album ID ??
                      • K Offline
                        If you don’t see any response, it may be because an error is being returned by Google. Errors in the script are suppressed now.
                        If you are familiar with updating the code, you can add a console.log(body) message to see the error.
                        • K Offline
                          kivlow
                          @kapsolas said in MMM-GooglePhotos:
                          console.log(body)
                          in auth_andtes is console log error and i dont have any just info in console:
                          so i dont have i thing any error but no album ID :/
                            [[global:former-user]] @kivlow
                            @kivlow At your first execution, have you countered allowance process?
                              richfreeman
                              Hi Sean,
                              Great work.
                              Just set this up, all went ok to the point where the photo’s don’t display.
                              I have a section on the MM screen cleared where the default 800x600 image would be displayed, but it is a black screen. I have the following error on the console after starting MM.sh appearing every refresh interval.
                              “There is no scanned photo currently.”
                              The album has several photo’s within it, The album name appeared next to the Album ID, I’ve copied the Album ID only into my config.
                              Any pointers would be great.
                              Thanks again!
                                richfreeman @richfreeman
                                @richfreeman
                                DOH
                                Remove the <>
                                Change “<>” to simply “Album ID”
                                No <> needed.
                                Photo’s appeared !
                                Thanks.
                                • K Offline
                                  kivlow @Guest
                                  @sean said in MMM-GooglePhotos:
                                  At myr first execution terminal not react over 5min after auth_and_test command and i have info to kill suspended process.
                                  After that when i wrote auth_and_test i get only info that is started :/
                                    @kivlow
                                    I suspect you have executed node auth_and_test.js in shell terminal on your PC via SSH. right?
                                    If you run that commands on your RPI directly, it should try to open a browser for authenticating process.
                                    • K Offline
                                      kivlow
                                      @sean
                                      i power on RPI with raspbian then open from upper taskbar terminal and wrote node auth_and_test.js
                                      how to wrote it directly ??
                                        @kivlow
                                        What kind of RPI do you use? As you said “taskbar”, Is it RPI 2 or 3 with Jessie or Stretch Desktop, right?
                                        And, Have RPI had any browser (Chromium or Midori?)?
                                        I’ll change some code for the case of not opening browser automatically, Please wait a while.
                                        • K Offline
                                          kivlow
                                          I use raspberry pi 3b with raspbian borwser chromium.
                                          cool i wait :] p.s. express response
                                            @kivlow
                                            I’ve fixed.
                                            cd ~/MagicMirror/modules/MMM-GooglePhotos
                                            git pull
                                            You can see like this image;
                                            When the browser is not be opened automatically, copy the url and paste it into your browser manually.
                                            • 14
                                            • 15
                                            • 1 / 15
