    Gurus, what is the problem with this code ?
    10 Posts 4 Posters 2.8k Views 3 Watching
      I can’t read it when it’s not in a code block? :-0)
      • rsellmerR Offline
        rsellmer
        Ok … I am so sorry about that. It was not easy to understand.
        Let me try to explain … I need call a function which is declared into the config.js. However, this is impossible. Nothing appeared on the screen. I did not find any example using a function call. Is it clear ?
        • rsellmerR Offline
          rsellmer
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var full  = "";
          function LoadData() {
          full = "Hello";
          $( document ).ready(function() {
          	LoadData();
          var config = {
          	address: "localhost",
                  port: 8080,
          	ipWhitelist: ["192.168.1.9"],
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          	zoom: 0.85,
          		module: "helloworld",
          		position: "center",
          			text: full
            A Former User @rsellmer
            @rsellmer
            As I’ve written in your other post, jQuery is not included as a default. You did a try to use jQuery($(document).ready())
            rsellmerR 1 Reply Last reply Reply Quote 0
            • rsellmerR Offline
              rsellmer @Guest
              @sean Tks again … I am newb with MM, so I think that it is not possible to create a function in the config.js … I think that this will not work. because the next step I will need to call an api from config.js to get some data from mysql.
              In my test using a config.js out the MM system, I could call the api, but I think that this is not possible in the MM. Am I right ? Tks
                @rsellmer
                config.js is not for your custom job. leave it.
                When you want to do something your own, create module.
                Read the manual.
                • https://github.com/MichMich/MagicMirror/blob/master/modules/README.md
                And see how other modules work;
                • https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                You can start by modifying any simple module as your wish.
                  @rsellmer
                  one more thing;
                  config.js is validated when MM is booted up, not rendered. maybe you can put some codes in config.js but that would not be working as your expectation.
