    Gurus, what is the problem with this code ?
    10 Posts 4 Posters 3.1k Views 3 Watching
    • rsellmerR
      rsellmer
      When I use this function I got an error and nothing appear on the screen.
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var full  = "";
      function LoadData() {
      full = "Hello";
      $( document ).ready(function() {
      	LoadData();
      var config = {
      	address: "localhost",
              port: 8080,
      	ipWhitelist: ["192.168.1.9"],
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      	zoom: 0.85,
      		module: "helloworld",
      		position: "center",
      			text: full
        A Former User @rsellmer
        @rsellmer
        We don’t know what problem do you have. How can we imagine?
        • cowboysdudeC
          What are you trying to do and what isn’t working?
          • Mykle1M
            I can’t read it when it’s not in a code block? :-0)
            • rsellmerR
              rsellmer
              Ok … I am so sorry about that. It was not easy to understand.
              Let me try to explain … I need call a function which is declared into the config.js. However, this is impossible. Nothing appeared on the screen. I did not find any example using a function call. Is it clear ?
              • rsellmerR
                rsellmer
                 * MIT Licensed.
                var full  = "";
                full = "Hello";
                	LoadData();
                var config = {
                        port: 8080,
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                	zoom: 0.85,
                		position: "center",
                			text: full
                  @rsellmer
                  As I’ve written in your other post, jQuery is not included as a default. You did a try to use jQuery($(document).ready())
                  rsellmerR 1 Reply Last reply Reply Quote 0
                  • rsellmerR
                    rsellmer @Guest
                    @sean Tks again … I am newb with MM, so I think that it is not possible to create a function in the config.js … I think that this will not work. because the next step I will need to call an api from config.js to get some data from mysql.
                    In my test using a config.js out the MM system, I could call the api, but I think that this is not possible in the MM. Am I right ? Tks
                      @rsellmer
                      config.js is not for your custom job. leave it.
                      When you want to do something your own, create module.
                      Read the manual.
                      • https://github.com/MichMich/MagicMirror/blob/master/modules/README.md
                      And see how other modules work;
                      • https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                      You can start by modifying any simple module as your wish.
                        @rsellmer
                        one more thing;
                        config.js is validated when MM is booted up, not rendered. maybe you can put some codes in config.js but that would not be working as your expectation.
