    MMM-Hotword
    60 Posts 20 Posters 29.3k Views 17 Watching
      A Former User @richland007
      @richland007
      First, I haven’t been using AlexaPi and MMM-Voice.
      With short glance, It seems different mic could be assigned to AlexaPi and MMM-Voice separately.
      (See the AlexaPi and MMM-Voice Configuration.)
      But I don’t know whether it would work or not.
      And I’m not sure MMM-Hotword would do that. Because AlexaPi is out of MM. So, It is not controllable by MM. You should use another mic or even another RPI.
      I think, The better way of voice controlling with Alexa is to use Alexa Skill, - like MirrorMirrorOnTheWall
        maxbachmann
        @Sean
        ah great thought I already seen I alexa module that receives the messages. I guess thats a lot better (and easier) solution than running two voice recognitions. he also has a quite good docu on how to set up the whole alexa skill stuff :thumbs_up:
        • richland007R Offline
          richland007
          Oh dang i did not see the MirrorMirrorOnTheWall module…let me see how difficult is to implement that and i will bother you again LOL :)
          thank you guys @Sean
          • T Offline
            themc
            is there anyway to integrate hotword with xscreensaver so i can blank the screen at 10 minutes and it pops back on whenever i say the hotword to the mirror ?
              A Former User @themc
              @themc
              I think possible.
              With MMM-notficationTrigger, you can override HOTWORD_DETECTED notification to any notification for any other modules.
              So, If you have some module which can awake screen (I don’t know whether really that kind of module exists), it is possible.
              If it doesn’t exist, hmmm. you might be able to fork this repository and modify it for that purpose.
              • T Offline
                themc
                haha im a newbie when it comes to coding and finding the right lines but ill have a look arround to see if i can fix something up. i know xscreensaver can be turned on by the following command in terminal:
                -activate Tell xscreensaver to turn on immediately (that is, blank the screen, as if the user had been idle for long enough.) The screensaver will deactivate as soon as there is any user activity, as usual.
                It is useful to run this from a menu; you may wish to run it as
                sleep 5 ; xscreensaver-command -activate
                to be sure that you have time to take your hand off the mouse before the screensaver comes on. (Because if you jiggle the mouse, xscreensaver will notice, and deactivate.)
                so i think it should be possible to link a hotword to that line to execute it
                • T Offline
                  themc @themc
                  @themc @myself the correct command would be
                  -deactivate
                  This tells xscreensaver to pretend that there has just been user activity. This means that if the screensaver is active (the screen is blanked), then this command will cause the screen to un-blank as if there had been keyboard or mouse activity. If the screen is locked, then the password dialog will pop up first, as usual. If the screen is not blanked, then this simulated user activity will re-start the countdown (so, issuing the -deactivate command periodically is one way to prevent the screen from blanking.)
                    @themc
                    If you want just to use MMM-Hotword as screensaver-awakener,
                    modify node_helper.js ;
                    // add this in line 1:
                    var exec = require('child_process').exec
                    // around line 86
                    .on('hotword', (index, hotword, buffer)=>{
                      exec ("xscreensaver-command -deactivate", (err, stdout, stderr)=>{})
                    • T Offline
                      themc
                      awesome ill try it out right away
                        @themc
                        Not tested. I wrote that post by your description. So I don’t know whether it works really.
                        But you can find a way how to work.
                        • 1 / 6
