    MMM-NOAA V3.0 doesn't see anything
    13 Posts 4 Posters 6.0k Views 3 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @cowboysdude
      @cowboysdude
      I tried to do a commit and a pull request to add the Thai translation.
      I have no idea if it worked or what.
      If you didn’t get notified regarding it, let me know.
      And then, learn me on how to do a pull request.
      The instructions just aren’t clear enough on how to do the compare part,
      I kept getting the message : “There isn’t anything to compare.”…
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
        I can post the th.json file on here if you want
        Jim Hallock - 1995
          alvaron14 @cowboysdude
          @cowboysdude
          I tryed that but it still not working
                                  module: 'MMM-NOAA3',
                                          provider: "Yahoo",
                                          airKey: "T624yBx9xxxxxxxxx",
                                     css: "NOAA3",   // THIS MUST CONTAIN A CSS STYLE NAME
                                          updateInterval: 15 * 60 * 1000 // every 15 minutes or whatever you choose but make sure you have an api that will allow that many calls per day!!!
          That’s exactly what is in my code (except the airKey)
          • cowboysdudeC Offline
            cowboysdude Module Developer @alvaron14
            @alvaron14 I would have to see your entire config… If you did the git pull and npm install this config should be working…so I’m guessing something else is not correct ;)
            A 2 Replies Last reply Reply Quote 0
              @cowboysdude
              Should i reinstall the module or you want to see a especific document?
              And if i need to reinstall the module how can i do it?
                @cowboysdude
                This is my config/config.js
                What’s wrong?
                var config = {
                        port: 8080,
                        language: "es",
                        timeFormat: 24,
                        units: "metric",
                                        module: "alert",
                                        module: "updatenotification",
                                        position: "top_bar"
                                        module: "clock",
                                        position: "top_left"
                                        header: "Calendario",
        symbol: "calendar-check-o ",
        url: "https://calendar.google.com/calendar/ical/alvagomez%40gmail.com/private-75fa092d74afee9ff6xxxxxxxxxxxx/basic.ics"
                                                        module: "currentweather",
        locationID: "6362115",  //ID from http://www.openweathermap.org/help/city_list.txt
        appid: "adb1ddad12ee0e796180f33fxxxxxxxxxx"
                                                        module: "weatherforecast",
                                                        header: "El tiempo",
        appid: "adb1ddad12ee0e796xxxxxxxxxxxxx"
        provider: "Yahoo",
        module: 'MMM-Traffic',
        position: 'bottom_right',
        classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
        api_key: 'AIzaSyAXjuPzn1NQKm9ZBx6rjFxxxxxxxxxxxxx',
        mode: 'driving',
        origin: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
        destination: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
        route_name: 'Ruta al trabajo',
        changeColor: true,
        showGreen: true,
        limitYellow: 5, //Greater than 5% of journey time due to traffic
        limitRed: 20, //Greater than 20% of journey time due to traffic
        traffic_model: 'pessimistic',
        interval: 120000 //2 minutes
        module: "newsfeed",
        position: "bottom_bar",
        feeds: [
        title: "Portada",
        url: "http://estaticos.elmundo.es/elmundo/rss/portada.xml"
        title: "Valencia",
        url: "http://estaticos.elmundo.es/elmundo/rss/valencia.xml"
        title: "Internacional",
        url: "http://estaticos.elmundo.es/elmundo/rss/internacional.xml"
        showSourceTitle: true,
        showPublishDate: true
                • K Offline
                  kurtern84 Project Sponsor @alvaron14
                  @alvaron14 Try adding position under NOAA3 in your config.js
                  A 1 Reply Last reply Reply Quote 2
                    alvaron14 @kurtern84
                    @kurtern84 @cowboysdude
                    Ty the problem was the position, my new functional code:
                                                    provider: "Yahoo",
                    K 1 Reply Last reply Reply Quote 1
                    • K Offline
                      @alvaron14 Np! :)
                        cowboysdude Module Developer @kurtern84
                        @kurtern84 Thank you for the help!! :) Great catch!
