    MMM-NOAA V3.0 doesn't see anything
    13 Posts 4 Posters 7.0k Views 3 Watching
    • A
      alvaron14
      Hello guys im new with MagicMirror and im trying to install MMM-NOAA V3.0 but nothing appear, i followed this instructions:
      cd ~/MagicMirror/modules
      git clone https://github.com/cowboysdude/MMM-NOAA3
      cd MMM-NOAA3
      npm install
      And that’s my config.js code:
                               module: 'MMM-NOAA3',
                                      provider: "Yahoo",
                                      apiKey: "adb1ddad12ee0e796180f3xxxxxxxxxx",
                                      airKey: "T624yBxxxxxxxxx",
                                 css: "NOAA4",   // THIS MUST CONTAIN A CSS STYLE NAME
                                      updateInterval: 15 * 60 * 1000 // every 15 minutes or whatever you choose but make s$
      And that’s what i see. Someone know what im doing wrong?
      • cowboysdudeC
        Hello there :)
        If you’re using yahoo as your default provider no api key is used for the weather.
        Here’s the example from github
         	    provider: "Yahoo",
         	    airKey: "YOUR API KEY",
                 css: "NOAA3"                 // THIS MUST CONTAIN A CSS STYLE NAME
        justjim1220J A 2 Replies Last reply
        • justjim1220J
          justjim1220 Module Developer @cowboysdude
          @cowboysdude
          I tried to do a commit and a pull request to add the Thai translation.
          I have no idea if it worked or what.
          If you didn’t get notified regarding it, let me know.
          And then, learn me on how to do a pull request.
          The instructions just aren’t clear enough on how to do the compare part,
          I kept getting the message : “There isn’t anything to compare.”…
          Jim Hallock - 1995
          • justjim1220J
            I can post the th.json file on here if you want
            Jim Hallock - 1995
            • A
              alvaron14 @cowboysdude
              @cowboysdude
              I tryed that but it still not working
                                              provider: "Yahoo",
                                              airKey: "T624yBx9xxxxxxxxx",
                                         css: "NOAA3",   // THIS MUST CONTAIN A CSS STYLE NAME
                                              updateInterval: 15 * 60 * 1000 // every 15 minutes or whatever you choose but make sure you have an api that will allow that many calls per day!!!
              That’s exactly what is in my code (except the airKey)
              • cowboysdudeC
                cowboysdude Module Developer @alvaron14
                @alvaron14 I would have to see your entire config… If you did the git pull and npm install this config should be working…so I’m guessing something else is not correct ;)
                • A
                  @cowboysdude
                  Should i reinstall the module or you want to see a especific document?
                  And if i need to reinstall the module how can i do it?
                  K 1 Reply Last reply
                  • A
                    @cowboysdude
                    This is my config/config.js
                    What’s wrong?
                    var config = {
                            port: 8080,
                            language: "es",
                            timeFormat: 24,
                            units: "metric",
                                            module: "alert",
                                            module: "updatenotification",
                                            position: "top_bar"
                                            module: "clock",
                                            position: "top_left"
                                            header: "Calendario",
        symbol: "calendar-check-o ",
        url: "https://calendar.google.com/calendar/ical/alvagomez%40gmail.com/private-75fa092d74afee9ff6xxxxxxxxxxxx/basic.ics"
                                                            module: "currentweather",
        locationID: "6362115",  //ID from http://www.openweathermap.org/help/city_list.txt
        appid: "adb1ddad12ee0e796180f33fxxxxxxxxxx"
                                                            module: "weatherforecast",
                                                            header: "El tiempo",
        appid: "adb1ddad12ee0e796xxxxxxxxxxxxx"
        provider: "Yahoo",
        module: 'MMM-Traffic',
        position: 'bottom_right',
        classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
        api_key: 'AIzaSyAXjuPzn1NQKm9ZBx6rjFxxxxxxxxxxxxx',
        mode: 'driving',
        origin: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
        destination: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxx',
        route_name: 'Ruta al trabajo',
        changeColor: true,
        showGreen: true,
        limitYellow: 5, //Greater than 5% of journey time due to traffic
        limitRed: 20, //Greater than 20% of journey time due to traffic
        traffic_model: 'pessimistic',
        interval: 120000 //2 minutes
        module: "newsfeed",
        position: "bottom_bar",
        feeds: [
        title: "Portada",
        url: "http://estaticos.elmundo.es/elmundo/rss/portada.xml"
        title: "Valencia",
        url: "http://estaticos.elmundo.es/elmundo/rss/valencia.xml"
        title: "Internacional",
        url: "http://estaticos.elmundo.es/elmundo/rss/internacional.xml"
        showSourceTitle: true,
        showPublishDate: true
                    • K
                      kurtern84 Project Sponsor @alvaron14
                      @alvaron14 Try adding position under NOAA3 in your config.js
                      A 1 Reply Last reply
                      Reply Quote 2
                      • A
                        alvaron14 @kurtern84
                        @kurtern84 @cowboysdude
                        Ty the problem was the position, my new functional code:
                                                        provider: "Yahoo",
                        • K
                          @alvaron14 Np! :)
                          • cowboysdudeC
                            cowboysdude Module Developer @kurtern84
                            @kurtern84 Thank you for the help!! :) Great catch!
                            • K
                              kurtern84 Project Sponsor @cowboysdude
                              @cowboysdude no problem mate! 😊
