    MMM-KeyBindings: Control your mirror with Amazon Fire Stick Remote and Generic Keyboard Inputs
    keyboardremote controlfire stick remotebluetooth
    34 Posts 13 Posters 25.9k Views 12 Watching
    • AgilesChromsA
      AgilesChroms
      Top module ! :trophy:
      Unfortunately the slides are only visible on the monitor, and not in the browser.
      Have I overlooked something?
        shbatm Module Developer
        @AgilesChroms First thing I would check: What browser are you using to view the mirror? If using Chrome/Chromium on the browser (or any others with DevTools), please check the console and see if there are any errors (Ctrl+Shift+I). Also, which modules are you using besides KeyBindings? Could you post or message me a snippet of your config file?
        I am using this module with my fork of MMM-Carousel on both the monitor connected to the Pi and a separate browser without issue.
        AgilesChromsA 1 Reply Last reply
        • AgilesChromsA
          AgilesChroms @shbatm
          @shbatm
          I am using your modules
          It works with Firefox.
          Unfortunately, remote control does not influence the browser
          ///*KeyBindings*/
                      module: 'MMM-KeyBindings',
                     //position: "top_bar",
                          // See below for configurable options
                          enabledKeyStates: ["KEY_PRESSED", "KEY_LONGPRESSED"],
                          enableNotifyServer: true,
                          endableRelayServer: true,
                          handleKeys: true, //Array of additional keys to handle in this module above the standard set, Reference Mousetrap API for the available key enumerations.
                          evdev: {
                                  enabled: true,
                                  //alias: 'Amazon Fire TV Remote',
                                  bluetooth: 'A0:02:DC:9B:78:6E',
                                  eventPath: '/dev/input/event3',
                                  disableGrab: false,
                                  longPressDuration: 0.7,
                                  rawMode: false
          /*Carousel*/
                      module: 'MMM-Carousel',
                      position: "bottom_bar",
                          showPageIndicators: true,
                          showPageControls: 	true,
                          transitionInterval: 1 * 60 * 1000,
                          ignoreModules: ['alert'],
                          mode: 'slides',
                          slides: [
                              [ { name:'clock', classes:'zoom140', position:"top_center",displayType: "analog",} ],
                              [ { name:'clock', classes:'zoom100', position:"top_left"} , 'MMM-Traffic', 'calendar', 'compliments', 'MMM-WunderGround', 'MMM-Fuel', 'internet-monitor','newsfeed','MMM-DWD-WarnWeather','MMM-FRITZ-Box-Callmonitor'],
                              ['MMM-Globe', 'MMM-WunderGround','MMM-FRITZ-Box-Callmonitor', 'MMM-Callmonitor-Current-Call', 'newsfeed'],
                              [ { name:'clock', classes:'zoom075', position:"top_left"} , 'MMM-WunderGround', 'MMM-DHT-Sensor', 'MMM-FRITZ-Box-Callmonitor', 'MMM-Callmonitor-Current-Call', 'MMM-DWD-WarnWeather'],
                              [ { name:'clock', classes:'zoom100', position:"top_left"} ,'calendar', 'MMM-WunderGround', 'MMM-Fuel', 'MMM-DHT-Sensor', 'MMM-FRITZ-Box-Callmonitor', 'MMM-Callmonitor-Current-Call', 'newsfeed'],
                              ['mmm-weatherchart', 'MMM-Traffic']
           //clock calendar MMM-Fuel MMM-DHT-Sensor MMM-WunderGround MMM-DWD-WarnWeather MMM-FRITZ-Box-Callmonitor MMM-Callmonitor-Current-Call newsfeed internet-monitor
          /*               slides:
                                     classes:'zoom140',
                                     classes:'',
                                     position:"top_left"
                                     position:'top_right'
                                 'newsfeed'
                              keyBindingsMode: "DEFAULT",
                          keyBindings: {
                              NextSlide: "ArrowRight",
                              PrevSlide: "ArrowLeft",
          //                    Slide0:    "Return",
          //                    Slide1:    "Menu",
          //                    Slide2:    "MediaPreviousTrack",
          //                    Slide3:    "MediaNextTrack"
          take a look @ this.screencast
            @AgilesChroms By default, the Carousel module will only respond to remote control keys on the “server’s” screen. This was done so you could pull up the MM in a browser on another computer and navigate separately with a keyboard/mouse. It’s in the plan down the road for multiple remotes on different screens running from one server, but I haven’t made it that far yet.
            EDIT: I’m assuming that when you say browser, you’re talking about a browser on a different computer and not just another window on the server/RPi running MM. The suggestions below are based on that assumption.
            For now:
            First 2 corrections in your config:
            • Remove handleKeys: true, from MMM-KeyBindings, this is for adding extra keyboard keys to bind to.
            • Add "MMM-KeyBindings" to the ignoreModules list in MMM-Carousel (probably doesn’t do anything at the moment, but just future proofing).
            Next, 2 options for a fix:
            1. If you want to control the browser’s slides separately (i.e. from a keyboard attached to that computer):
              • In MMM-KeyBindings config section, add: enableMousetrap: true, which will turn on regular keyboard binding in the browser window.
              • Keyboard key presses only work when the browser is active and focused – usually have to click in the window and make sure it’s active before it will respond. I also had issues with some media keys not being sent to to browser at all-which is why I went with the evdev path in the first place.
              • Optional (and untested, but should work): If you want to use additional keyboard keys other than the standard keys, then in MMM-Carousel config section: add a duplicate entry in the keyBindings section:
                keyBindings: {
                    NextSlide: "ArrowRight", // Remote Key Name
                    NextSlide: "r",          // Keyboard Key Name
                    PrevSlide: "ArrowLeft",  // Remote Key Name
                    PrevSlide: "l"           // Keyboard Key Name
                You’ll also need to add any new “non-default” keys to MMM-KeyBindings:
                handleKeys: [ 'r', 'l' ],
            2. If you want the remote to control ALL screens: Remove the following from Line 71 in modules/MMM-Carousel/MMM-Carousel.js
               && payload.Sender === this.instance
              • This is a temporary test for now. In the future I will add a config option for the remote to control all instances or just the main screen. At the moment there is no good way to synchronize the screens when just using the Previous/Next navigation (e.g. if your main screen is on Slide 2 and you open a browser to Slide 0 and press next, both will move but one will be on Slide 3 and the other Slide 1).
            Please let me know if this helps / works – still new to MM2 and just starting development of these modules so any feedback or feature requests are more than welcome! I’m glad someone else is able to make use of the modules.
            • AgilesChromsA
              @shbatm said in MMM-KeyBindings: Control your mirror with Amazon Fire Stick Remote and Generic Keyboard Inputs:
              keyBindings: {
              NextSlide: “ArrowRight”, // Remote Key Name
              NextSlide: “r”, // Keyboard Key Name
              PrevSlide: “ArrowLeft”, // Remote Key Name
              PrevSlide: “l” // Keyboard Key Name
              Double definition of keys does not work.
              The remote control is ignored!
              Extra buttons on the remote control are handled
              //                keyBindings: {
                                  NextSlide: "k",          // Keyboard Key Name
                                  PrevSlide: "j",           // Keyboard Key Name
                                  Slide0:    "Return",
                                  Slide1:    "Menu",
                @AgilesChroms - I’m out of town for business, so bear with me since I’m unable to fully test these suggestions.
                To use custom keyboard keys AND the remote, you can also modify the evdevKeymap and handleKeys in the MMM-KeyBindings Config. The module tries to “map” the remote’s key names to more standard keyboard key names and this can be tweaked. For example in the MMM-KeyBindings Config:
                 evdevKeymap: {
                     Home: "KEY_HOMEPAGE",
                     Enter: "KEY_KPENTER",
                     j: "KEY_LEFT",          // Change default "ArrowLeft" to "j"
                     k: "KEY_RIGHT",         // Change default "ArrowRight" to "k"
                     ArrowUp: "KEY_UP",
                     ArrowDown: "KEY_DOWN",
                     Menu: "KEY_MENU",
                     MediaPlayPause: "KEY_PLAYPAUSE",
                     MediaNextTrack: "KEY_FASTFORWARD",
                     MediaPreviousTrack: "KEY_REWIND",
                     Return: "KEY_BACK"
                 handleKeys: ['j','k']       //  Add the new keys to the keyboard bindings
                In MMM-Carousel, you can now use:
                 keyBindings: { NextSlide: "k", PrevSlide: "j", Slide0: "Return", ... }
                Side note:
                Something you may also find useful: the evdevKeymap tries to standardize keys, but if it receives a key that isn’t in the map, it will still pass it along. I use this to also control my Mirror via my home automation system using GET requests.
                For example: if you add a keybinding to MMM-Carousel like Slide1: "SomeSlideTitle", you can jump to that slide with a GET request to the following URL:
                http://mirror_ip:8080/MMM-KeyBindings/notify?notification=KEYPRESS&payload=%7B%22KeyState%22%3A%20%22KEY_PRESSED%22%2C%20%22Duration%22%3A%200.0%2C%20%22KeyName%22%3A%20%22SomeSlideTitle%22%7D
                // payload parameter is a url-encoded JSON string:
                {"KeyState": "KEY_PRESSED", "Duration": 0.0, "KeyName": "SomeSlideTitle"}
                • AgilesChromsA
                  @shbatm
                  I am now satisfied with the behavior. The screen is now syncron with the browser
                  thank you for your help
                    You are welcome. Glad you made it work and happy to see someone can make use of the module!
                      jchenaud
                      hey thk for module !
                      i try to use it but i have some problem:
                      i have put that on my conf file .
                                  module :  'MMM-KeyBindings' ,
                                  config : {
                      				enableNotifyServer : false
                      i just want to use a local keyboard for now and i probably change after for remote.
                      and on my module of pages organisation
                      i have put your config :
                      Module.register("Print_text_from_txt",{
                      	curentPage: -1,
                      	defaults: {
                      		updateInterval:  1000,// 30 * 60 * 1000 //reads the file every 30 mins
                          /*** defaults ***
                           *   Add items below to your moduleName.js's `defaults` object
                              /*** MMM-KeyBindings STANDARD MAPPING ***/
                              /* Add the "mode" you would like to respond to */
                              keyBindings: {
                                  /* Add each key you want to respond to in the form:
                                   *      yourKeyName: "KeyName_from_MMM-KeyBindings"
                                  Right: "ArrowRight",
                                  Left: "ArrowLeft",
                      	start: function(){
                      		this.setupKeyBindings(); //key binding test
                      		this.sendSocketNotification("START", this.config);
                      notificationReceived: function(notification, payload){
                      		if (this.validateKeyPress(notification, payload)) { return; }
                      		if (notification === "PAGE_NUMBER_IS")
                      			this.curentPage = payload
                      			this.sendNotification("PAGE_CHANGED", this.curentPage);
                      i have clone directory on my module folder.
                      i have one error on console but she not cause by the module
                      TypeError: Failed to execute 'appendChild' on 'Node': parameter 1 is not of type 'Node'.
                          at updateModuleContent (main.js:206)
                          at main.js:139
                          at new Promise (<anonymous>)
                          at updateDomWithContent (main.js:137)
                          at main.js:119
                          at <anonymous>
                      i have probably miss something but i dont find :(
                      i haven’t notification on console
                      sorry for my bad language
                      and thanks for your help
                      edit:
                      i have miss on Line on config file
                      but notification is not hear and probably never send :(
                        jchenaud
                        hey i remake all process but nothing new . i am alone in this case ?
                        just my log when all looks ok
                         MagicMirror git:(master) ✗ npm start
                        > magicmirror@2.4.1 start /home/pi/MagicMirror
                        > sh run-start.sh
                        Starting MagicMirror: v2.4.1
                        Loading config ...
                        Loading module helpers ...
                        No helper found for module: MMM-EyeCandy.
                        Module helper loaded: Print_text_from_txt
                        Module helper loaded: MMM-kalliope
                        Module helper loaded: MMM-KeyBindings
                        No helper found for module: MMM-pages.
                        All module helpers loaded.
                        Server started ...
                        Starting module: newsfeed
                        Connecting socket for: Print_text_from_txt
                        Starting module helper: Print_text_from_txt
                        Connecting socket for: MMM-kalliope
                        MMM-kalliope is started
                        Connecting socket for: MMM-KeyBindings
                        MMM-KeyBindings helper has started...
                        Launching application.
                        Create new news fetcher for url: https://www.tdg.ch/rss_ticker.html - Interval: 300000
                        MMM-kalliope received a socket notification: CONNECT - Payload: null
                          rak
                          Hello guys,
                          I cant get the remote connected to the R3B+. I stuck. Searching the web like cracy since yetserday evening with no result.
                          It seems the pairing fails bc of the message “ServicesResolved: no”
                          Any clue whats missing?
                          $ sudo bluetoothctl
                          [NEW] Controller B8:27:EB:DF:FF:D1 raspberrypi [default]
                          [bluetooth]# agent on
                          Agent registered
                          [bluetooth]# scan on
                          Discovery started
                          [CHG] Controller B8:27:EB:DF:FF:D1 Discovering: yes
                          [NEW] Device C4:95:00:6F:19:8A Amazon Fire TV Remote
                          [CHG] Device C4:95:00:6F:19:8A RSSI: -66
                          [CHG] Device C4:95:00:6F:19:8A RSSI: -74
                          [CHG] Device C4:95:00:6F:19:8A RSSI: -62
                          [bluetooth]# scan off
                          Discovery stopped
                          [bluetooth]# pair C4:95:00:6F:19:8A
                          Attempting to pair with C4:95:00:6F:19:8A
                          [CHG] Device C4:95:00:6F:19:8A Connected: yes
                          Request confirmation
                          [agent] Confirm passkey 301420 (yes/no): yes
                          [CHG] Device C4:95:00:6F:19:8A Modalias: usb:v1949p0410d0304
                          [CHG] Device C4:95:00:6F:19:8A UUIDs: 00001101-0000-1000-8000-00805f9b34fb
                          [CHG] Device C4:95:00:6F:19:8A UUIDs: 00001124-0000-1000-8000-00805f9b34fb
                          [CHG] Device C4:95:00:6F:19:8A UUIDs: 00001200-0000-1000-8000-00805f9b34fb
                          [CHG] Device C4:95:00:6F:19:8A ServicesResolved: yes
                          [CHG] Device C4:95:00:6F:19:8A Paired: yes
                          Pairing successful
                          [CHG] Device C4:95:00:6F:19:8A ServicesResolved: no     <<<<< THIS sounds strange to me
                          [CHG] Device C4:95:00:6F:19:8A Connected: no
                          [bluetooth]# trust C4:95:00:6F:19:8A
                          [CHG] Device C4:95:00:6F:19:8A Trusted: yes
                          Changing C4:95:00:6F:19:8A trust succeeded
                          [bluetooth]# devices
                          Device 4F:8A:AE:69:E9:71 4F-8A-AE-69-E9-71
                          Device 6A:79:D3:6A:17:13 6A-79-D3-6A-17-13
                          Device 61:A4:04:D0:5D:66 61-A4-04-D0-5D-66
                          Device 6E:91:C7:B3:7A:C8 6E-91-C7-B3-7A-C8
                          Failed to pair: org.bluez.Error.AlreadyExists
                          [bluetooth]# conntect C4:95:00:6F:19:8A
                          Invalid command
                          [bluetooth]# connect C4:95:00:6F:19:8A
                          Attempting to connect to C4:95:00:6F:19:8A
                          Failed to connect: org.bluez.Error.Failed
                          [bluetooth]#
                            @rak Have you tried pairing the remote using the Bluetooth menu/GUI on the desktop?
                            R 1 Reply Last reply
                              @jchenaud I am away right now and will take a closer look at your issue when I am back in town.
                                rak @shbatm
                                @shbatm Thanks. Much appreciated. No urgent need. Looking forward to your reply.
                                I tried both. GUI and command line. Both gave the same error message. I even tried a 2nd remote without success. Same error message.
                                  rak
                                  @shbatm, did you had a chance to look into this? Thanks for an update.
                                    rak
                                    Solved it.
                                    I added “pairable on” to the mix. After that it worked.
                                    Works like a charm. Only thingis that after restarting MagicMirror (pm2 restart MagicMirror) the evdev service ist typically stopped and needs a restart as well (pm2 start evdev).
                                    Not sure whats missing here.
                                      rak
                                      Another thing. The evdev “process” stopps working every now and than. A pm2 start evdev, gets it going again. Any clue how I could troubleshoot this?
                                      • A
                                        Aries1984 Module Developer
                                        Hi there,
                                        first of all: Great module. You’ve just got a quite major issue in your documentation 😉 In your wiki (https://github.com/shbatm/MMM-KeyBindings/wiki/Integration-into-Other-Modules) you talk about “KeyCode” being a part of the payload.
                                        I wanted to use that in my module to determine which keyboard key has been pressed and react accordingly. More specificly I was intrested in the arrow-keys.
                                        First there was no reaction at all on any of the key presses. I could see that the press itself was recognized but when logging the payload “KeyCode” was always set to “undefined”. It cost me about 3hrs of my life only to find out that in your code you use “KeyName” but in the documentation you refer to “KeyCode”. I was surprised to be the first one to notice it but obiously I am as otherwise somebody else would have flagged it up already 😉
                                          ANNOUNCEMENT: Version 1.3.0 - Updated 3-Jan-2019 - [BREAKING CHANGES] Remove server controls in favor of External Modules, Remove Python script in favor of Native Node.JS modules
                                          Here are the highlights from this major change:
                                          • This update had the overall goal of simplifying this module. I made a major philosophy change with this update, shifting from the original goal of this module performing a lot of its own sever-side functions and also relying on other modules to implement listeners to handle key presses-to this module being focused on listening to keys and letting other modules handle the heavy lifting.
                                          • Removed all server-side controls from this module (monitor toggle, external interupts) in favor of declaring actions and sending notifications to other modules instead.
                                            • Instead of this module trying to figure out if it should do something like turn on the screen, before it sent the action out–now it just gets the action and sends it. If you want to control the screen, use a module made to do that, like MMM-Remote-Control.
                                          • Removed Notify Server in favor of extensible REST API being developed for MMM-Remote-Control
                                            • The “notify” server was cumbersome and difficult to properly format. It was only really required as a way for the python script to send notifications back. The new REST API is much simpler and the bluetooth monitoring is now done within Node, so that makes this redundant.
                                          • Added Actions to send notifications on a keypress rather than rely on other modules to actively listen for them.
                                            • Instead of requiring other modules to listen for specific “KEY_PRESSED” notifications, you can now translate key presses to notifications that other modules already understand.
                                            • The module is still extensible by other modules, and in fact, it has been made easier now. Rather than incorporate all of the code into your module, you can get a KeyHandler instance and add a few small functions to handle the key press notifications. The heavy lifting to validate a key press is done in the background. See this wiki page for updated instructions.
                                            shbatm Module Developer @Aries1984
                                            @aries1984 said in MMM-KeyBindings: Control your mirror with Amazon Fire Stick Remote and Generic Keyboard Inputs:
                                            Thanks for catching this. There must have been some remnants from the first version when that’s what I used. It’s been fixed now.
