    [Enhancement] Translation system
    Scheduled Pinned Locked Moved Core System
    13 Posts 9 Posters 19.3k Views 9 Watching
    • MichMichM
      MichMich
      I’ve just finished the translation system which now includes core translations files and a solid fallback mechanism. This way your modules can benefit from existing translations (in the core translations files).
      All the translations used by the default modules are defined in the core translation files, making is easy to translate the core of the system. Of course, 3rd party modules should use their own translation files.
      The translation files can be found in /translations . Pull request with new or improved translations are more than welcome!
      Note: although comments are officially not supported in JSON files, MagicMirror allows it by stripping the comments before parsing the JSON file. Comments in translation files could help other translators.
      If you built your own module, and you run into translation strings from which the core system could benefit (generic texts), feel free to send a PR with updated translation files.
        paviro
        Nice work! Thanks a lot! :smiley:
        – The Doctor
        • W
          Wilco89
          Nice Job!
          how to make a pull request?
          MichMichM 1 Reply Last reply Reply Quote 0
          • MichMichM
            MichMich @Wilco89
            @Wilco89 It looks like you figured it out?
              danito
              It says “finish translation system” but I can’t find any Finish translation.
              (sorry ;-) and thanks for the great work)
              • MichMichM
                MichMich @danito
                @danito lol
                • N
                  ninja
                  I’ve updated fr.json file on my computer.
                  I’m also trying to do it on github, but i’m total noob :p
                  A little hint please ? I’ve tried to “pull” but not sure i’m doing it right.
                  Thx
                  • L
                    Lx
                    Michael, I learned that the core translation file is small and already done for a bunch of languages. Should it be expanded in the future, I’d be glad to contribute to the Hungarian translation. I could not figure out in the forum how to get enlisted for such voluntary work, that’s why I write in this post.
                    Cheers, György
                      sdetweil @Lx
                      @lx use github to fork the MM repo, then download your copy using git clone
                      change/add whatever files need changing
                      then use git status to see the changed/new files
                      git add those files
                      then use git commit -m " description" to save those files into the local git repo copy
                      then use git push to send them to your fork on github
                      then on github create a ‘pull request’ (to the dev branch) to tell Mich that you are offering changes
                      if he approves, he will merge your changes
                      i expect that you will not understand some of that… google is your friend, search out each step…
                      qu1queQ 1 Reply Last reply Reply Quote 0
                      • L
                        Lx
                        Sam, thanks for the instruction. You are right, I’m a total newbie here. But your sequence + google is good enough for a start. Cheers, György
                        • qu1queQ
                          qu1que Project Sponsor @sdetweil
                          Hi, I’ve just tried to create a new PR with a new translation for MM. I’ve followed your steps, and everything goes well, but the merge is blocked due to this message:
                          Enforce Changelog / check (pull_request)
                          Here is a link to my PR:
                          https://github.com/MichMich/MagicMirror/pull/2491
                          I’m a noob on github. What it would be the next step?
                          Thanks in advance.
                            sdetweil @qu1que
                            @qu1que u needed to add the CHANGELOG.md
                            describing your change
                            on your same branch on pc edit the file, commit and push it. the existing PR will be updated and retested
                            • qu1queQ
                              Yeah, it seems now is working. Thanks!
