    MMM-DHT-Sensor
    dhtdht11
    14 Posts 5 Posters 8.1k Views 5 Watching
      STEFF92
      I need some help. I tried to install the DHT module from bernardpletikosa (https://github.com/bernardpletikosa/MMM-DHT-Sensor). But when i start my MagicMirror i onley get a black screen.
      Did i anything wrog in my config.js file? This is what i added:
      			module: "MMM-DHT-Sensor",
      			position: "bottom_right",
      				sensorTyp: "11",
      				sensorPIN: "7",
      				updateInterval: "2000 ms",
      				animationSpeed: "0",
      				titleText: "Raumtemperatur",
      				units: "metric",
        U need another set of braces starting before “module”
        And ending after the close brace of config
        This new close brace, also needs a trailing comma
          STEFF92 @sdetweil
          @sdetweil i tried it but then there was a black screen with the massage i should create a correct config.js file.
          Befor i added the DHT-module, my MagicMirror was running. Here is my complete config.js file:
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			module: "currentweather",
          				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
          				appid: "447e7403ed196c5dcfc895a3b85dd6b4"
          			module: "weatherforecast",
          			header: "Wettervorhersage",
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "Tagesschau",
          						url: "http://www.tagesschau.de/xml/rss2"
          						title: "BILD News",
          						url: "https://www.bild.de/rss-feeds/rss-16725492,feed=news.bild.html"
          						title: "Kicker News",
          						url: "http://rss.kicker.de/news/aktuell"
          						title: "Kicker BVB",
          						url: "http://rss.kicker.de/team/borussiadortmund"
          				showSourceTitle: true,
          				showPublishDate: true
                                module: 'MMM-soccer',
                                position: 'bottom_left',
                                        api_key: 'c7c930952f7a4d73951b33b2386d30c1',
                                        colored: false,
                                        show: 'GERMANY',
                                        leagues: {"GERMANY":430},
          				sensorTyp: "11",
          				sensorPIN: "7",
          				units: "metric",
          • Y Offline
            yawns Moderator @STEFF92
            Please try it this way:
            		sensorTyp: 11,
            		sensorPIN: 7,
            		updateInterval: 2000,
            		animationSpeed: 0,
            		units: "metric",
              STEFF92 @yawns
              @yawns same problem, nothing else than a black screen
                binia
                Try please without the comma the last line.
                		units: "metric"
                • Y Offline
                  @steff92 said in MMM-DHT-Sensor:
                  But you did run npm install in ~/MagicMirror/modules/MMM-DHT-Sensor ?
                    STEFF92 @binia
                    @binia doesn’t work
                      STEFF92 @yawns
                      @yawns yes i did
                        cut and paste your entire config, and paste into jslint.com,
                        at the bottom of the screen check
                        node.js, long lines, single quotes, and whitespace mess
                        may have to comment out a few trailing commas…
                        should find the problem, if its config text related…
                        otherwise
                        start the mm from the commandline on the pi and see what the error reports,
                          jslint suggests removing the extra trailing commas
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          	language: "en",
                          	timeFormat: 24,
                          	units: "metric",
                          			module: "alert"
                          			position: "top_bar"
                          			module: "clock",
                          			module: "newsfeed",
                          				feeds: [
                          						title: "BILD News",
                                                        colored: false,
                                                        show: 'GERMANY',
                          				sensorTyp: "11",
                          				sensorPIN: "7",
                          				units: "metric"
                            STEFF92 @sdetweil
                            @sdetweil i tried that code, but it doesnt work. Still the same problem.
                            I always start the MM in the command line with:
                            cd MagicMirror/
                            npm start
                            Then the black screen opens and i can’t see whats in the command line because if i want to stop MM i have to reboot the pi (I’m a total beginner, sorry, maybe there is an other possibility to stop without reboot).
                            I despair :loudly_crying_face:
                              sdetweil @STEFF92
                              @steff92 if u have a keyboard press ctrl-shift-i ( letter i) to open debug console.
                              Or start mirror in Dev mode, not full screen
                              npm start Dev
                              Alt-tab will also walk u between the available windows
                                cyberdie
                                This is my running config for this module:
                                			header: "Header",
                                				sensorPin: 2,
                                				sensorType: 11,
                                				updateInterval: 60 * 60 * 1000,
                                				initialLoadDelay: 0,
                                				animationSpeed: 1000,
                                				units: "metric",
                                				relativeScale: 35,
                                				debug: false
