    MMM-DHT-Sensor
    dhtdht11
    14 Posts 5 Posters 8.2k Views 5 Watching
      STEFF92 @sdetweil
      @sdetweil i tried it but then there was a black screen with the massage i should create a correct config.js file.
      Befor i added the DHT-module, my MagicMirror was running. Here is my complete config.js file:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: "currentweather",
      				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      				appid: "447e7403ed196c5dcfc895a3b85dd6b4"
      			module: "weatherforecast",
      			header: "Wettervorhersage",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "Tagesschau",
      						url: "http://www.tagesschau.de/xml/rss2"
      						title: "BILD News",
      						url: "https://www.bild.de/rss-feeds/rss-16725492,feed=news.bild.html"
      						title: "Kicker News",
      						url: "http://rss.kicker.de/news/aktuell"
      						title: "Kicker BVB",
      						url: "http://rss.kicker.de/team/borussiadortmund"
      				showSourceTitle: true,
      				showPublishDate: true
                            module: 'MMM-soccer',
                            position: 'bottom_left',
                                    api_key: 'c7c930952f7a4d73951b33b2386d30c1',
                                    colored: false,
                                    show: 'GERMANY',
                                    leagues: {"GERMANY":430},
      			module: "MMM-DHT-Sensor",
      			position: "bottom_right",
      				sensorTyp: "11",
      				sensorPIN: "7",
      				updateInterval: "2000 ms",
      				animationSpeed: "0",
      				titleText: "Raumtemperatur",
      				units: "metric",
      • Y Offline
        yawns Moderator @STEFF92
        Please try it this way:
        		sensorTyp: 11,
        		sensorPIN: 7,
        		updateInterval: 2000,
        		animationSpeed: 0,
        		units: "metric",
          STEFF92 @yawns
          @yawns same problem, nothing else than a black screen
            binia
            Try please without the comma the last line.
            		units: "metric"
            • Y Offline
              @steff92 said in MMM-DHT-Sensor:
              But you did run npm install in ~/MagicMirror/modules/MMM-DHT-Sensor ?
                STEFF92 @binia
                @binia doesn’t work
                  STEFF92 @yawns
                  @yawns yes i did
                    cut and paste your entire config, and paste into jslint.com,
                    at the bottom of the screen check
                    node.js, long lines, single quotes, and whitespace mess
                    may have to comment out a few trailing commas…
                    should find the problem, if its config text related…
                    otherwise
                    start the mm from the commandline on the pi and see what the error reports,
                      jslint suggests removing the extra trailing commas
                       * MIT Licensed.
                      var config = {
                      	port: 8080,
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert"
                      			position: "top_bar"
                      			module: "clock",
                      			module: "newsfeed",
                      				feeds: [
                      						title: "BILD News",
                                                    colored: false,
                                                    show: 'GERMANY',
                      				sensorTyp: "11",
                      				sensorPIN: "7",
                      				units: "metric"
                        STEFF92 @sdetweil
                        @sdetweil i tried that code, but it doesnt work. Still the same problem.
                        I always start the MM in the command line with:
                        cd MagicMirror/
                        npm start
                        Then the black screen opens and i can’t see whats in the command line because if i want to stop MM i have to reboot the pi (I’m a total beginner, sorry, maybe there is an other possibility to stop without reboot).
                        I despair :loudly_crying_face:
                          sdetweil @STEFF92
                          @steff92 if u have a keyboard press ctrl-shift-i ( letter i) to open debug console.
                          Or start mirror in Dev mode, not full screen
                          npm start Dev
                          Alt-tab will also walk u between the available windows
                            cyberdie
                            This is my running config for this module:
                            			header: "Header",
                            				sensorPin: 2,
                            				sensorType: 11,
                            				updateInterval: 60 * 60 * 1000,
                            				initialLoadDelay: 0,
                            				animationSpeed: 1000,
                            				units: "metric",
                            				relativeScale: 35,
                            				debug: false
