    MMM-DHT-Sensor
    dhtdht11
    14 Posts 5 Posters 8.5k Views 5 Watching
    • yawnsY
      yawns Moderator @STEFF92
      Please try it this way:
      	module: "MMM-DHT-Sensor",
      	position: "bottom_right",
      		sensorTyp: 11,
      		sensorPIN: 7,
      		updateInterval: 2000,
      		animationSpeed: 0,
      		titleText: "Raumtemperatur",
      		units: "metric",
        STEFF92 @yawns
        @yawns same problem, nothing else than a black screen
        yawnsY 1 Reply Last reply
          binia
          Try please without the comma the last line.
          		units: "metric"
          • yawnsY
            @steff92 said in MMM-DHT-Sensor:
            But you did run npm install in ~/MagicMirror/modules/MMM-DHT-Sensor ?
              STEFF92 @binia
              @binia doesn’t work
                STEFF92 @yawns
                @yawns yes i did
                  cut and paste your entire config, and paste into jslint.com,
                  at the bottom of the screen check
                  node.js, long lines, single quotes, and whitespace mess
                  may have to comment out a few trailing commas…
                  should find the problem, if its config text related…
                  otherwise
                  start the mm from the commandline on the pi and see what the error reports,
                    jslint suggests removing the extra trailing commas
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert"
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			module: "currentweather",
                    				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                    				appid: "447e7403ed196c5dcfc895a3b85dd6b4"
                    			module: "weatherforecast",
                    			header: "Wettervorhersage",
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "Tagesschau",
                    						url: "http://www.tagesschau.de/xml/rss2"
                    						title: "BILD News",
                    						url: "https://www.bild.de/rss-feeds/rss-16725492,feed=news.bild.html"
                    						title: "Kicker News",
                    						url: "http://rss.kicker.de/news/aktuell"
                    						title: "Kicker BVB",
                    						url: "http://rss.kicker.de/team/borussiadortmund"
                    				showSourceTitle: true,
                    				showPublishDate: true
                                          module: 'MMM-soccer',
                                          position: 'bottom_left',
                                                  api_key: 'c7c930952f7a4d73951b33b2386d30c1',
                                                  colored: false,
                                                  show: 'GERMANY',
                                                  leagues: {"GERMANY":430}
                    				sensorTyp: "11",
                    				sensorPIN: "7",
                    				updateInterval: "2000 ms",
                    				animationSpeed: "0",
                    				units: "metric"
                      STEFF92 @sdetweil
                      @sdetweil i tried that code, but it doesnt work. Still the same problem.
                      I always start the MM in the command line with:
                      cd MagicMirror/
                      npm start
                      Then the black screen opens and i can’t see whats in the command line because if i want to stop MM i have to reboot the pi (I’m a total beginner, sorry, maybe there is an other possibility to stop without reboot).
                      I despair :loudly_crying_face:
                        sdetweil @STEFF92
                        @steff92 if u have a keyboard press ctrl-shift-i ( letter i) to open debug console.
                        Or start mirror in Dev mode, not full screen
                        npm start Dev
                        Alt-tab will also walk u between the available windows
                          cyberdie
                          This is my running config for this module:
                          			header: "Header",
                          				sensorPin: 2,
                          				sensorType: 11,
                          				updateInterval: 60 * 60 * 1000,
                          				initialLoadDelay: 0,
                          				animationSpeed: 1000,
                          				units: "metric",
                          				relativeScale: 35,
                          				debug: false
