    MMM-Hue
    huehome automation
    25 Posts 16 Posters 28.9k Views 17 Watching
      Clogs
      Hi @Mitchfarino
      Like your MMM-Hue module but will admit getting it to work was a little bit more tricky then what I had anticipated.
      My version 1.0 Hue hub setup controlling a 9 individual bulbs. I did not set up the bulbs as part of a groups.
      Wanted to share just a few simple findings to help others to get your module to work even better.
      Inspecting your code in MMM-Hue.js I found that you had a this.lightsorgroups hardcoded to “groups”. As a result of this my Hue setup was presented as just the Home icon with ‘Lights On’ as the status.
      Changing the hardcoded this.lightsorgroups to “lights” did result in a similar display as shown in your first post however all the named lights showed the X (fa-times) icon for the status even though lights were on, others off an others unreacheable.
      So I made a further minor change on line 69 and changed it to:
      lightstatus.classList.add("fa", this.result[lamps[i]].state.reachable ? (this.result[lamps[i]].state.on ? "fa-lightbulb-o" : "fa-adjust" ) : "fa-times");
      Keep up the good work.
      M 1 Reply Last reply
        Mitchfarino Module Developer @Clogs
        Hi @Clogs
        Thanks for your feedback, I’m sorry I haven’t been able to update the module to account for individual lights
        As you have noticed it is in the code, I just didn’t expose it to the config.
        I’m going to pick it up soon, and will update in this thread.
        Thanks for letting me know, and for giving me the nudge I need to get it updated
        • T
          tidus5
          Hello @Mitchfarino
          Im trying to make your module “clickable” :-)
          could you help me with that ?
          Module.register(“MMM-Hue”, {
          defaults: {
              bridgeip: "",
              userid: "",
              colour: true
          // Define required scripts.
          getScripts: function () {
              return [this.file("js/jquery.js")];
          getStyles: function () {
              return ["font-awesome.css", "MMM-Hue.css"];
          // Define start sequence.
          start: function () {
              //These will be moved to config in a later release
              this.lightsorgroups = "groups";
              this.updateInterval = 60 * 100; // 10000 updates every 10 minutes
              this.animationSpeed = 2 * 1000;
              this.initialLoadDelay = 0;
              //end
              var result = false;
              this.url = "http://" + this.config.bridgeip + "/api/" + this.config.userid + "/" + this.lightsorgroups;
              this.getData();
              setInterval(() => {
                  this.getData();
              }, this.updateInterval);
          // Override dom generator.
          getDom: function () {
              //alert("http://" + this.config.bridgeip + "/api/" + this.config.userid + "/" + this.config.lightsorgroups);
              if (this.result) {
                  var table = document.createElement("table");
                  table.classList.add("small", "table", "align-left");
                  table.appendChild(this.createLabelRow());
                  var lamps = Object.keys(this.result);
                  for (var i = 0; i < lamps.length; i++) {
                      var row = document.createElement("tr");
                      var room = document.createElement("td");
                      room.innerHTML = this.result[lamps[i]].name;;
                      row.appendChild(room);
                      var lightsallLabel = document.createElement("td");
                      lightsallLabel.classList.add("centered");
                      var lightstatus = document.createElement("i");
                      //lightstatus.classList.add(“fa”, this.result[lamps[i]].state.reachable ? (this.result[lamps[i]].state.on ? “fa-lightbulb-o” : “fa-adjust” ) : “fa-times”);
          	buttonlightstatus[i] = false;  // CUSTOM
          	buttonlight[i] = document.createElement("span");  // CUSTOM
          	//var buttonlightstatus[i] = false;  // CUSTOM
          	//var buttonlight[i] = document.createElement("span");  // CUSTOM
          	//weatherbutton.className = "wi wi-day-rain-mix navbar";
          	//var forecast = MM.getModules().withClass('weatherforecast');
          	if(this.result[lamps[i]].state.all_on)
          	lightstatus.classList.add("fa-lightbulb-o")
          	buttonlightstatus[i] = true;
          	else if (this.result[lamps[i]].state.any_on)
          	lightstatus.classList.add("fa-adjust")
          	else {
          	lightstatus.classList.add("fa-times")
          	// lightstatus.classList.add("fa", this.result[lamps[i]].state.all_on ? "fa-lightbulb-o" : (this.result[lamps[i]].state.any_on ? "fa-adjust" : "fa-times"));  // CUSTOM
                      if (this.config.colour) {
                          if (this.result[lamps[i]].state.all_on) {
                              lightstatus.classList.add("lights-all-on")
                          else {
                              if (this.result[lamps[i]].state.any_on) {
                                  lightstatus.classList.add("lights-partial-on")
                      lightsallLabel.appendChild(lightstatus);
              		wrapper.appendChild(buttonlight[i]);  //CUSTOM
                      row.appendChild(lightsallLabel);
                      table.appendChild(row);
                  wrapper.appendChild(table);
                 										//CUSTOM
                  		$(buttonlight[i]).on("click", function(){
          					if(buttonlightstatus[i]){
          					alert('its work');
          					putJSON(t"http://" + this.config.bridgeip + "/api/" + this.config.userid + "/lights/" + buttonlightstatus[i] +"/state , ({'on':false});
          					}else{
          					putJSON(t"http://" + this.config.bridgeip + "/api/" + this.config.userid + "/lights/" + buttonlightstatus[i] +"/state , ({'on':true});
              } else {
                  wrapper.innerHTML = "No Data returned";
              return wrapper;
          createLabelRow: function () {
              var labelRow = document.createElement("tr");
              var roomiconlabel = document.createElement("th");
              var typeIcon = document.createElement("room");
              typeIcon.classList.add("fa", "fa-home");
              roomiconlabel.appendChild(typeIcon);
              labelRow.appendChild(roomiconlabel);
              var lightsonlabel = document.createElement("th");
              lightsonlabel.classList.add("centered");
              var typeIcon = document.createElement("lightson");
              //typeIcon.classList.add("fa", "fa-lightbulb-o");
              typeIcon.innerHTML = "Lights On";
              lightsonlabel.appendChild(typeIcon);
              labelRow.appendChild(lightsonlabel);
              return labelRow;
          getData: function () {
              $.getJSON(this.url, (data) => {
                  this.result = data;
                  this.updateDom();
          my brigde is in Amsterdam and im in Belgium for Christmas :-)
            d3r
            Would it be possible to display the wake up and sleep times of the bulbs/groups? Is that supported by the api?
            I use my hue lights to wake me up in the morning. Some days I need to wake up at 5am others 6am. I find myself forgetting to change the wake up time in the app. If I could display the wake up time on my MM2, I would remember to change the wake up time which would be perfect.
            • slametpsS
              slametps
              @Mitchfarino : I did a pull-request for Indonesian translation and showLabel option to your MMM-Hue module.
              regards,
              Slamet PS
                schlachtkreuzer6
                hi!
                show only when on does not work for me… any tip? thanks!
                  shane1234
                  Would it be possible to have the icons match the color of the lights and/or display an icon for each light in the room?
                    sirdizzle
                    Can anyone assist me in configuring the module correctly?
                    I have it set up, but having trouble filtering out more than one group via hideGroupsWithString
                    Currently, I have hideGroupsWithString: "Custom group for $lights" and that works, but I’m not sure how to add more groups to the string correctly.
                    I know this is an old thread, but any help would be appreciated.
                      Mikrosoft
                      Hi just installing this module and have set all id and ip correct and the only thing i have changed is made it bottom_left in the css file but i have nothing showing up when i load.
                      what am i doing wrong ?
                        Smotx @sirdizzle
                        @sirdizzle said in MMM-Hue:
                        Same question here.
                        I want to hide my dimmer and hgrp.
                        Thanks for help
                        • WayneRigleyW
                          WayneRigley
                          i ended up getting the Hue Module to work as preset config options. if i turn on the lights there is a long delay in showing on the Magic Mirror, but it does show after a while in our bedroom group. i have 6 bulbs in our bedroom group so if i change the Hue config file from groups to lights and restart the MM all the lights and names show up with an “x” and its impossible to get the MM to show the lights are ON … any help > as i want to add several bulbs arond the house NOT on a schedule and at a glance see where things are…
                          Wayne R
                          • F
                            freescl
                            Hello there,
                            I am experiencing issues with getting MMM-hue to show on the screen.
                            I have successfully created a hue bridge user id, so maybe my config is wrong?
                            		    module: 'MMM-Hue',
                            		    position: 'top_right',
                            		    config:{
                                            	bridgeip: "192.168.xxx.xxx",
                            		        userid: "MY-ID-OF-HUE-BRIDGE",
                                           		colour: false
                            Can anyone help?
                            Thanks,
                            F 1 Reply Last reply
                            • F
                              freescl @freescl
                              @freescl
                              Just found out, that copying the Module to default modules folder helps to get it run… Hope it helps someone else :)
                              • citizendevpiC
                                citizendevpi
                                I am getting a no data returned on my display how can i fix this?
                                  Hi all,
                                  I just wanted to update, that I have moved away from the Hue Bulbs/Bridge so I haven’t been able to work with this module for some time now.
                                  Hopefully someone has forked it and resolved any issues.
                                  I do still have my bridge and bulbs, just switched them out for alternatives. I may switch back at some point.
                                  mumblebajM 1 Reply Last reply
                                  • mumblebajM
                                    mumblebaj Module Developer @Mitchfarino
                                    @Mitchfarino What a pity though. The module works perfectly for me though. There are some instructions missing though but I managed to get it up and running when I first implemented it a few months ago. Great module.
                                      dazza120
                                      Not a fork but hue lights https://github.com/michael5r/mmm-hue-lights
