    602 Posts 67 Posters 2.3m Views 68 Watching
    • evroomE Offline
      evroom
      Quite happy with MMM-RTSPStream so far; thx to those that contributed to it.
      Next thing I am trying to use MMM-RTSPStream for, is streaming sat-tv from a Dreambox & VU+ receivers.
      I am able to stream a channel using:
      omxplayer --vol -3000 --win “0 0 480 320” --live http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
      It is not a rtsp stream, but it can use omxplayer for streaming.
      When I try to use MMM-iFrame, I can add the URL, but then it tries to open a program that can play mpg (and MagicMirror won’t start).
      When I use it to stream using my browser (on my PC), I have it open VLC player, but installing VLC on Raspberry (using HW acceleration) is quite an act, so I would prefer to use omxplayer.
      Could this be done ?
      I am not so familiar with JavaScript and CCS (yet), more a Perl guy, but am willing to assist and test-drive.
      MagicMirror version: 2.37.0
      A 1 Reply Last reply Reply Quote 1
      • evroomE Offline
        evroom
        To come back to my own request.
        The line that works from the command line is:
        When I look at the code
        https://github.com/shbatm/MMM-RTSPStream/blob/master/node_helper.js
        I notice following:
        –vol : not present, not really necessary, yet
        –win : present
        –live : present
        –avdict rtsp_transport:tcp : present, needed ?
        -–video_queue 4 : present, needed ?
        –fps 30 : present, needed ?
        When home I will try:
        $ omxplayer --avdict rtsp_transport:tcp --win “0 0 480 320” --live -–video_queue 4 --fps 30 http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
        And I will try:
        node_helper.js :
        if (this.config[s.name].protocol == “http”) {
        args.unshift(“–vol 3000”);
        • evroomE Offline
          evroom
          Okay, it is actually quite simple.
          It works without any modifications.
          stream1: {
          	url: 'http://192.168.178.28:8001/1:0:19:2B66:3F3:1:C00000:0:0:0:', // ZDF HD
          	//url: 'http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:', // ARD HD
          	protocol: "tcp",
          	width: 590,
          	height: 332
          2|mm       | Starting stream stream1 with args: [
          2|mm       |     "--avdict",
          2|mm       |     "rtsp_transport:tcp",
          2|mm       |     "--win",
          2|mm       |     "4, 608, 594, 940",
          2|mm       |     "--live",
          2|mm       |     "--video_queue",
          2|mm       |     "4",
          2|mm       |     "--fps",
          2|mm       |     "30",
          2|mm       |     "http://192.168.178.28:8001/1:0:19:2B66:3F3:1:C00000:0:0:0:"
          2|mm       | ]
          2|mm       | Starting PM2 for omx_stream1
          2|mm       | PM2 started for omx_stream1
          It is just that the Raspberry Pi 3 Model 3 and omxplayer only can handle 1 TS stream, as it appears to be the case.
          Simular like the max. 3 RTSP camera streams.
          So, if you do not use omxplayer for something else and you want to use MMM-RTSPStream for streaming just the one TS channel, it can be used.
          • E Offline
            epi
            Hi @shbatm & others! After install (followed your guide here https://github.com/shbatm/MMM-RTSPStream), I see a black frame with a white border, without the stream. I tried both mine stream url and samples. My sample works great via VLC. Can you help me to find an issue?
            module: 'MMM-RTSPStream',
            position: 'middle_center',
                autoStart: true,
                moduleWidth: 354,
                moduleHeight: 240,
                localPlayer: 'omxplayer',
                stream1: {
                    url: 'rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp',
                    snapshotUrl: '',
                    snapshotRefresh: 10, // Seconds
                    frameRate: "30",
                    port: 9999,
            update, after a few commas in the config I managed to get test stream up&running, but not my webcam. Any solution available? :)
            • E Offline
              epi
              @epi said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              I assume issue is in my stream URL either localPlayer. Any suggestions?
              • E Offline
                epi
                pi@raspberrypi:~ $ pm2 logs
                /home/pi/.pm2/pm2.log last 15 lines:
                PM2        | [2018-09-21T20:42:51.125Z] PM2 log: App [omx_stream1] with id [1] and pid [6551], exited with code [1] via signal [SIGI                                              NT]
                PM2        | [2018-09-21T20:42:51.132Z] PM2 log: Starting execution sequence in -fork mode- for app name:omx_stream1 id:1
                PM2        | [2018-09-21T20:42:51.159Z] PM2 log: App name:omx_stream1 id:1 online
                PM2        | [2018-09-21T20:42:53.221Z] PM2 log: App [omx_stream1] with id [1] and pid [6582], exited with code [1] via signal [SIGI                                              NT]
                PM2        | [2018-09-21T20:42:53.234Z] PM2 log: Starting execution sequence in -fork mode- for app name:omx_stream1 id:1
                PM2        | [2018-09-21T20:42:53.253Z] PM2 log: App name:omx_stream1 id:1 online
                PM2        | [2018-09-21T20:42:59.249Z] PM2 log: Stopping app:mm id:0
                PM2        | [2018-09-21T20:42:59.562Z] PM2 log: App [mm] with id [0] and pid [6136], exited with code [0] via signal [SIGINT]
                PM2        | [2018-09-21T20:42:59.632Z] PM2 log: pid=6136 msg=process killed
                PM2        | [2018-09-21T20:42:59.635Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
                PM2        | [2018-09-21T20:42:59.651Z] PM2 log: App name:mm id:0 online
                PM2        | [2018-09-21T20:43:35.020Z] PM2 log: Stopping app:omx_stream1 id:1
                PM2        | [2018-09-21T20:43:35.054Z] PM2 error: Process with pid 6613 already exists
                PM2        | [2018-09-21T20:43:35.174Z] PM2 log: App [omx_stream1] with id [1] and pid [6613], exited with code [1] via signal [SIGI                                              NT]
                PM2        | [2018-09-21T20:43:35.193Z] PM2 log: pid=6613 msg=process killed
                /home/pi/.pm2/logs/omx-stream1-error.log last 15 lines:
                0|mm       | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                0|mm       | [885:0919/041827.726584:FATAL:bus.cc(1152)] D-Bus connection was disconnected. Aborting.
                0|mm       | [10472:0919/213258.329193:FATAL:bus.cc(1152)] D-Bus connection was disconnected. Aborting.
                0|mm       | TypeError: `port` or a `server` must be provided
                0|mm       |     at new WebSocketServer (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/node_modules/                                              ws/lib/WebSocketServer.js:44:11)
                0|mm       |     at VideoStream.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/vid                                              eoStream.js:32:24)
                0|mm       |     at Class.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:49:32)
                0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:257:22)
                0|mm       |     at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                0|mm       |     at emitTwo (events.js:126:13)
                0|mm       |     at Socket.emit (events.js:214:7)
                0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:513:12
                0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
                0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
                0|mm       | Starting stream stream1 with args: [
                0|mm       |     "--avdict",
                0|mm       |     "rtsp_transport:tcp",
                0|mm       |     "--win",
                0|mm       |     "800, 421, 1120, 661",
                0|mm       |     "--live",
                0|mm       |     "--video_queue",
                0|mm       |     "4",
                0|mm       |     "--fps",
                0|mm       |     "30",
                0|mm       |     "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0"
                0|mm       | ]
                0|mm       | PM2: omx_stream1 already running. Stopping old instance...
                0|mm       | Starting PM2 for omx_stream1
                0|mm       | PM2 started for omx_stream1
                  shbatm Module Developer
                  Looking at the logs it looks like it’s trying to launch everything correctly. Just to confirm:
                  1. The stream works correctly in VLC using the URL you have above.
                  2. Since you’re using OMXPlayer – you are testing on the mirror with the RPi connected (not with VNC/Remote Desktop, etc). You won’t see playback from OMXPlayer on anything but the monitor connected to the RPi.
                  You can try:
                  1. Make sure the stream works with OMXPlayer by testing with the command line (shut down Magic Mirror first):
                    omxplayer --avdict rtsp_transport:tcp --win 800, 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp
                  2. Test the above with and without .sdp at the end of the path. I noticed in your log above for some reason it didn’t pass the extension .sdp. I don’t know if this is the issue or not. You can also try without the --win argument to test it full screen.
                  3. Using UDP instead of TCP, put protocol: "udp" in your stream config (to test from command line, remove the rtsp_transport:tcp argument.
                  4. Using stream=1 to test the lower resolution sub-stream. Sometimes OMXPlayer just refuses to do anything (without any errors) if it doesn’t have enough video memory–I’ve only seen it happen trying to play 3 streams at once though.
                  5. Try adding a ? at the end of the stream url. Just something I saw while googling your url format to find out what kind of camera you have.
                  • E Offline
                    epi
                    • E Offline
                      epi @shbatm
                      @shbatm
                      @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                      1. Yes, it does work in VLC.
                      2. I control RPi via SSH & VNC, but it is connected via HDMI to monitor and I don’t see any output on the actual screen neither via VNC, nor actual screen.
                      Testing:
                      1. By making tests I encounter an error:
                      pi@raspberrypi:~ $ sudo reboot
                      login as: pi
                      pi@192.168.2.111's password:
                      Linux raspberrypi 4.14.50-v7+ #1122 SMP Tue Jun 19 12:26:26 BST 2018 armv7l
                      The programs included with the Debian GNU/Linux system are free software;
                      the exact distribution terms for each program are described in the
                      individual files in /usr/share/doc/*/copyright.
                      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                      permitted by applicable law.
                      Last login: Mon Sep 24 01:55:35 2018
                      SSH is enabled and the default password for the 'pi' user has not been changed.
                      This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
                      pi@raspberrypi:~ $ pm2 stop mm
                      [PM2] Applying action stopProcessId on app [mm](ids: 0)
                      [PM2] [mm](0) ✓
                      │ App name │ id │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
                      │ mm       │ 0  │ fork │ 0   │ stopped │ 0       │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
                       Use `pm2 show <id|name>` to get more details about an app
                      pi@raspberrypi:~ $ omxplayer --avdict rtsp_transport:tcp --win 800, 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USER&password=PASS&channel=1&stream=0.sdp
                      [1] 1084
                      [2] 1085
                      [3] 1086
                      pi@raspberrypi:~ $ File "421," not found.
                      pi@raspberrypi:~ $
                      1. Did not work
                      2. Also did not work, this time another file is not being found
                      omxplayer --avdict 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USER&password=PASS&channel=1&stream=0
                      [7] 1213
                      [8] 1214
                      [9] 1215
                      [4]   Exit 1                  omxplayer --avdict 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USERNAME
                      [5]   Done                    password=PASSWORD
                      [6]   Done                    channel=1
                      pi@raspberrypi:~ $ File "1120," not found.
                      1. 5., Did not work
                        @epi My fault: for command line you have to fix the window command line argument:
                        ... --win 800,421,1120,661 ... or ... --win '800 421 1120 661' ... and I think put the URL in quotes.
                        You can test it without that whole argument (should play full screen). This is what I meant in #2 above. Here’s some combos to try:
                        # Option 1 -- Should be full screen (if it works):
                        omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp"
                        # Option 2:
                        omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0"
                        # Option 3 Sub-stream:
                        omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=1.sdp"
                        # Option 4 UDP:
                        omxplayer --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp"
                        • E Offline
                          epi @shbatm
                          @shbatm
                          I did a fresh install of RPI OS & MM all addons
                          Option one: freeze, then after a wait console available again
                          pi@raspberrypi:~/MagicMirror/modules/MMM-RTSPStream $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USER&password=PASS&channel=1&stream=0.sdp"
                          Video codec omx-h264 width 1280 height 960 profile 77 fps 30.000000
                          Audio codec pcm_alaw channels 1 samplerate 8000 bitspersample 8
                          Subtitle count: 0, state: off, index: 1, delay: 0
                          V:PortSettingsChanged: 1280x960@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                          have a nice day ;)
                          Option two: many lines
                          COMXVideo::Decode timeout
                          Option three: same as first one, freeze then
                          Video codec omx-h264 width 704 height 576 profile 77 fps 30.000000
                          V:PortSettingsChanged: 704x576@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                          Option four:
                          pi@raspberrypi:~ $ omxplayer --live --video_queue 4 --fps 30 "rtsp://192.168.2.2        37:554/user=USER&password=PASS&channel=1&stream=0.sdp"
                          • Cr4z33C Offline
                            Cr4z33
                            Hi @shbatm I am playing with your module to see TV programs from a Vu+ Duo² (a DVB-S2+DVB-T Linux/Enigma2 decoder).
                            The only thing I can’t succed is to see HD TV programs.
                            I’ve tried to use both
                            url
                            and
                            hdUrl
                            , but those streams won’t start (while normal SD programs are working just fine).
                            This is my current script by the way (the HD channel has been disabled in the meantime):
                            		    module: "MMM-RTSPStream",
                            		    position: "bottom_right",
                            		    // header: "Sky TG24",
                            		        autoStart: true,
                            		        rotateStreams: false,
                            		        rotateStreamTimeout: 10,
                            		        moduleWidth: 390,
                            		        moduleHeight: 219,
                            		        remotePlayer: 'none',
                            		        showSnapWhenPaused: false,
                            		        remoteSnaps: false,
                            		        stream1: {
                            		            // name: 'Sky TG24',
                            		            // url: 'http://192.168.1.6:8001/1:0:1:5:7918:217C:EEEE0000:0:0:0:',
                            		            name: 'RAI 3 TGR Puglia',
                            		            url: 'http://192.168.1.6:8001/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:',
                            		            // name: 'RAI 3 HD',
                            		            // hdUrl: 'http://192.168.1.6:8001/1:0:1:2191:5:13E:EEEE0000:0:0:0:',
                            		            protocol: "tcp",
                            		            frameRate: 'undefined',
                            		            width: 390,
                            		            height: 219,
                            • evroomE Offline
                              evroom
                              Can you check this ?
                              $ vcgencmd codec_enabled MPG2
                              It should say “MPG2=enabled”.
                              License can be bought for a few euro’s:
                              http://www.raspberrypi.com/mpeg-2-license-key/
                              • Cr4z33C Offline
                                Cr4z33 @evroom
                                @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                It is enabled as I followed your advice. ;)
                                As I said normal SD TV programs work just fine.
                                The problem is with High Definition programs.
                                • evroomE Offline
                                  evroom
                                  RAI 3 HD probably is not free-to-air, so I cannot check it.
                                  But to be honest, it seems NOT to work for me too.
                                  Only SD, no HD.
                                  I had it working on v2.4.1 (made notes about it to not to forget) and did not use it after that.
                                  You can test it directly, without having to change the MM config all the time:
                                  $ omxplayer --win "0 0 800 480" --live "http://192.168.1.6:8001/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:"
                                  $ omxplayer --win "0 0 800 480" --live "http://192.168.1.6:8001/1:0:1:2191:5:13E:EEEE0000:0:0:0:"
                                  omxplayer will show the stream details:
                                  Video codec omx-mpeg2 width 720 height 576 profile 4 fps 25.000000
                                  Video codec omx-h264 width 1920 height 1080 profile 100 fps 50.000000
                                  On my Pi it seems to run, but nothing appears on the screen.
                                  • Cr4z33C Offline
                                    Cr4z33 @evroom
                                    @evroom I am in the same boat (with my Raspberry Pi 3 b+).
                                    However I am 100% sure my Pi can handle HD channel streams as they work perfectly if using VLC!
                                    • evroomE Offline
                                      evroom
                                      I can stream full HD at 50 fps:
                                      A bit odd.
                                      • Cr4z33C Offline
                                        Cr4z33 @evroom
                                        @evroom oops it came out I have to wait at least 30-40 seconds before I can see (succesfully) a 1080i @ 60Fps HD stream. :smiling_face_with_smiling_eyes:
                                        However yesterday I found one more issue…
                                        I connected the RPI for the first time to the TV to see how MagicMirror was looking on it, but I found out that the stream stops as soon as I ask something to Google Assistant (MMM-AssistantMk2 + MMM-Hotword by @Sean ) and it replies.
                                        After that the stream doesn’t resume at all.
                                        I don’t know where to start and cannot see why this is going on as the RPI can easily play 2+ media files at a time. :confounded_face:
                                        • evroomE Offline
                                          evroom
                                          @Cr4z33
                                          As I do not use MMM-AssistantMk2 and/or MMM-Hotword, I cannot help you there.
                                          In principle the streaming should continue.
                                          As a matter of fact, when I stop MM, my cam streams still continue (are listed by pm2 as independent applications).
                                          As soon as there will be a MMM-HotAssistant, I might give it a try :-)
                                          • Cr4z33C Offline
                                            Cr4z33 @evroom
                                            @evroom no problem mate although it looks like the developer is no more active in this thread my bad. :confused_face:
                                            Do you know by chance what to edit to see the stream in the same position as the white frame (I actually would like to get rid of it)?
                                            • 30
                                            • 31
                                            • 6 / 31
