    602 Posts 67 Posters 2.4m Views 68 Watching
      shbatm Module Developer @nagaculun
      @nagaculun You’ll have to set the width and height of the stream manually because and OMXPlayer should resize the video for you. It’s a bit trial and error, but you should be able to get it lined up very close.
      Refer to the README and the moduleOffset module setting and width, height, and absPosition stream settings.
      Let me know if you have issues getting it to work.
      • G
        goprojojo
        I need some help with this module. I can see the RTSP stream without issues BUT when I use it with the MMM-Wallpaper then the stream doesn’t show. Any suggestions?
        • evroomE
          evroom
          I have been playing with MagicMirror for 2 weeks now and am slowly getting the hang of it.
          It was the MMM-RTSPStream that sparked it all and made me decide to dedicate a monitor for all the other nice modules.
          Now I have a question concerning MMM-RTSPStream.
          The streams are ordered from left to right and then from top to bottom, all depending on the size of the windows.
          I would like to have a bit more control, like with tables.
          My goal for now is to have a bigger window on the left and 2 little windows on the right.
          I have no idea how to place a picture, so I try to place a link to a picture.
          This shows the current implementation, with 2 streams.
          Current implementation - 2 streams
          Any idea where and how to achieve that (if possible at all) ??
          I guess the MMM-RTSPStream.css is a place to start, but for the moment I fail to understand it to be able to make the wanted changes.
          Due to a lack of knowledge of css, but I am willing to learn.
          Thanks in advance and best regards,
          Erik-Jan
          MagicMirror version: 2.37.0
            shbatm Module Developer @evroom
            @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            @evroom – First of all welcome to the community.
            You should be able to do what you’re asking by manipulating the CSS (or another way I’ll mention below).
            For CSS:
            First, you should put all customizations in the ~/MagicMirror/css/custom.css file so they don’t get overwritten by any module or MagicMirror updates.
            Try adding this to custom.css:
            .MMM-RTSPStream .innerWrapper {
                float: left;
            Without float (original):
            With float (and reducing the size of the other two streams by half and the moduleWidth settings in my config):
            Background if needed for further changes: the MMM-RSTPStream draws all of the streams inside of a single, outerdiv with the "MMM-RTSPStream wrapper" classes. Each stream consists of an "MMM-RTSPStream innerWrapper"-classed div block which contains all the controls, canvas, and screenshot for each stream. This is the tag you’ll need to manipulate to get it to do what you want. If you need to override one particular stream’s size/container, you can reference it in CSS by using it’s ID, which ends in the stream number. For example, something like this:
            #iw_stream1 {
                width: 123px;
            Additional option If you’re using Raspberry Pi directly attached to the monitor and using OMXPlayer to play the streams, you can also turn off the borders and send exact sizes and locations for each stream on the monitor using the absPosition parameter. See the README on GitHub for more details. This will break any thumbnail or remote playback, though.
            • evroomE
              evroom
              @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              float: left;
              @shbatm
              Thanks a lot! Works just fine.
              A bit of calculating and adjusting the margin, and it does what I wanted.
              • evroomE
                evroom
                Quite happy with MMM-RTSPStream so far; thx to those that contributed to it.
                Next thing I am trying to use MMM-RTSPStream for, is streaming sat-tv from a Dreambox & VU+ receivers.
                I am able to stream a channel using:
                omxplayer --vol -3000 --win “0 0 480 320” --live http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                It is not a rtsp stream, but it can use omxplayer for streaming.
                When I try to use MMM-iFrame, I can add the URL, but then it tries to open a program that can play mpg (and MagicMirror won’t start).
                When I use it to stream using my browser (on my PC), I have it open VLC player, but installing VLC on Raspberry (using HW acceleration) is quite an act, so I would prefer to use omxplayer.
                Could this be done ?
                I am not so familiar with JavaScript and CCS (yet), more a Perl guy, but am willing to assist and test-drive.
                A 1 Reply Last reply
                • evroomE
                  evroom
                  To come back to my own request.
                  The line that works from the command line is:
                  When I look at the code
                  https://github.com/shbatm/MMM-RTSPStream/blob/master/node_helper.js
                  I notice following:
                  –vol : not present, not really necessary, yet
                  –win : present
                  –live : present
                  –avdict rtsp_transport:tcp : present, needed ?
                  -–video_queue 4 : present, needed ?
                  –fps 30 : present, needed ?
                  When home I will try:
                  $ omxplayer --avdict rtsp_transport:tcp --win “0 0 480 320” --live -–video_queue 4 --fps 30 http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:
                  And I will try:
                  node_helper.js :
                  if (this.config[s.name].protocol == “http”) {
                  args.unshift(“–vol 3000”);
                  • evroomE
                    evroom
                    Okay, it is actually quite simple.
                    It works without any modifications.
                    stream1: {
                    	url: 'http://192.168.178.28:8001/1:0:19:2B66:3F3:1:C00000:0:0:0:', // ZDF HD
                    	//url: 'http://192.168.178.28:8001/1:0:19:283D:3FB:1:C00000:0:0:0:', // ARD HD
                    	protocol: "tcp",
                    	width: 590,
                    	height: 332
                    2|mm       | Starting stream stream1 with args: [
                    2|mm       |     "--avdict",
                    2|mm       |     "rtsp_transport:tcp",
                    2|mm       |     "--win",
                    2|mm       |     "4, 608, 594, 940",
                    2|mm       |     "--live",
                    2|mm       |     "--video_queue",
                    2|mm       |     "4",
                    2|mm       |     "--fps",
                    2|mm       |     "30",
                    2|mm       |     "http://192.168.178.28:8001/1:0:19:2B66:3F3:1:C00000:0:0:0:"
                    2|mm       | ]
                    2|mm       | Starting PM2 for omx_stream1
                    2|mm       | PM2 started for omx_stream1
                    It is just that the Raspberry Pi 3 Model 3 and omxplayer only can handle 1 TS stream, as it appears to be the case.
                    Simular like the max. 3 RTSP camera streams.
                    So, if you do not use omxplayer for something else and you want to use MMM-RTSPStream for streaming just the one TS channel, it can be used.
                    • E
                      epi
                      Hi @shbatm & others! After install (followed your guide here https://github.com/shbatm/MMM-RTSPStream), I see a black frame with a white border, without the stream. I tried both mine stream url and samples. My sample works great via VLC. Can you help me to find an issue?
                      module: 'MMM-RTSPStream',
                      position: 'middle_center',
                          autoStart: true,
                          moduleWidth: 354,
                          moduleHeight: 240,
                          localPlayer: 'omxplayer',
                          stream1: {
                              url: 'rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp',
                              snapshotUrl: '',
                              snapshotRefresh: 10, // Seconds
                              frameRate: "30",
                              port: 9999,
                      update, after a few commas in the config I managed to get test stream up&running, but not my webcam. Any solution available? :)
                      • E
                        epi
                        @epi said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                        I assume issue is in my stream URL either localPlayer. Any suggestions?
                        • E
                          epi
                          pi@raspberrypi:~ $ pm2 logs
                          /home/pi/.pm2/pm2.log last 15 lines:
                          PM2        | [2018-09-21T20:42:51.125Z] PM2 log: App [omx_stream1] with id [1] and pid [6551], exited with code [1] via signal [SIGI                                              NT]
                          PM2        | [2018-09-21T20:42:51.132Z] PM2 log: Starting execution sequence in -fork mode- for app name:omx_stream1 id:1
                          PM2        | [2018-09-21T20:42:51.159Z] PM2 log: App name:omx_stream1 id:1 online
                          PM2        | [2018-09-21T20:42:53.221Z] PM2 log: App [omx_stream1] with id [1] and pid [6582], exited with code [1] via signal [SIGI                                              NT]
                          PM2        | [2018-09-21T20:42:53.234Z] PM2 log: Starting execution sequence in -fork mode- for app name:omx_stream1 id:1
                          PM2        | [2018-09-21T20:42:53.253Z] PM2 log: App name:omx_stream1 id:1 online
                          PM2        | [2018-09-21T20:42:59.249Z] PM2 log: Stopping app:mm id:0
                          PM2        | [2018-09-21T20:42:59.562Z] PM2 log: App [mm] with id [0] and pid [6136], exited with code [0] via signal [SIGINT]
                          PM2        | [2018-09-21T20:42:59.632Z] PM2 log: pid=6136 msg=process killed
                          PM2        | [2018-09-21T20:42:59.635Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
                          PM2        | [2018-09-21T20:42:59.651Z] PM2 log: App name:mm id:0 online
                          PM2        | [2018-09-21T20:43:35.020Z] PM2 log: Stopping app:omx_stream1 id:1
                          PM2        | [2018-09-21T20:43:35.054Z] PM2 error: Process with pid 6613 already exists
                          PM2        | [2018-09-21T20:43:35.174Z] PM2 log: App [omx_stream1] with id [1] and pid [6613], exited with code [1] via signal [SIGI                                              NT]
                          PM2        | [2018-09-21T20:43:35.193Z] PM2 log: pid=6613 msg=process killed
                          /home/pi/.pm2/logs/omx-stream1-error.log last 15 lines:
                          0|mm       | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                          0|mm       | [885:0919/041827.726584:FATAL:bus.cc(1152)] D-Bus connection was disconnected. Aborting.
                          0|mm       | [10472:0919/213258.329193:FATAL:bus.cc(1152)] D-Bus connection was disconnected. Aborting.
                          0|mm       | TypeError: `port` or a `server` must be provided
                          0|mm       |     at new WebSocketServer (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/node_modules/                                              ws/lib/WebSocketServer.js:44:11)
                          0|mm       |     at VideoStream.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/vid                                              eoStream.js:32:24)
                          0|mm       |     at Class.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:49:32)
                          0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:257:22)
                          0|mm       |     at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
                          0|mm       |     at emitTwo (events.js:126:13)
                          0|mm       |     at Socket.emit (events.js:214:7)
                          0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:513:12
                          0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
                          0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
                          0|mm       | Starting stream stream1 with args: [
                          0|mm       |     "--avdict",
                          0|mm       |     "rtsp_transport:tcp",
                          0|mm       |     "--win",
                          0|mm       |     "800, 421, 1120, 661",
                          0|mm       |     "--live",
                          0|mm       |     "--video_queue",
                          0|mm       |     "4",
                          0|mm       |     "--fps",
                          0|mm       |     "30",
                          0|mm       |     "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0"
                          0|mm       | ]
                          0|mm       | PM2: omx_stream1 already running. Stopping old instance...
                          0|mm       | Starting PM2 for omx_stream1
                          0|mm       | PM2 started for omx_stream1
                            Looking at the logs it looks like it’s trying to launch everything correctly. Just to confirm:
                            1. The stream works correctly in VLC using the URL you have above.
                            2. Since you’re using OMXPlayer – you are testing on the mirror with the RPi connected (not with VNC/Remote Desktop, etc). You won’t see playback from OMXPlayer on anything but the monitor connected to the RPi.
                            You can try:
                            1. Make sure the stream works with OMXPlayer by testing with the command line (shut down Magic Mirror first):
                              omxplayer --avdict rtsp_transport:tcp --win 800, 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp
                            2. Test the above with and without .sdp at the end of the path. I noticed in your log above for some reason it didn’t pass the extension .sdp. I don’t know if this is the issue or not. You can also try without the --win argument to test it full screen.
                            3. Using UDP instead of TCP, put protocol: "udp" in your stream config (to test from command line, remove the rtsp_transport:tcp argument.
                            4. Using stream=1 to test the lower resolution sub-stream. Sometimes OMXPlayer just refuses to do anything (without any errors) if it doesn’t have enough video memory–I’ve only seen it happen trying to play 3 streams at once though.
                            5. Try adding a ? at the end of the stream url. Just something I saw while googling your url format to find out what kind of camera you have.
                            E 1 Reply Last reply
                            • E
                              epi
                              • E
                                epi @shbatm
                                @shbatm
                                1. Yes, it does work in VLC.
                                2. I control RPi via SSH & VNC, but it is connected via HDMI to monitor and I don’t see any output on the actual screen neither via VNC, nor actual screen.
                                Testing:
                                1. By making tests I encounter an error:
                                pi@raspberrypi:~ $ sudo reboot
                                login as: pi
                                pi@192.168.2.111's password:
                                Linux raspberrypi 4.14.50-v7+ #1122 SMP Tue Jun 19 12:26:26 BST 2018 armv7l
                                The programs included with the Debian GNU/Linux system are free software;
                                the exact distribution terms for each program are described in the
                                individual files in /usr/share/doc/*/copyright.
                                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                permitted by applicable law.
                                Last login: Mon Sep 24 01:55:35 2018
                                SSH is enabled and the default password for the 'pi' user has not been changed.
                                This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
                                pi@raspberrypi:~ $ pm2 stop mm
                                [PM2] Applying action stopProcessId on app [mm](ids: 0)
                                [PM2] [mm](0) ✓
                                │ App name │ id │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
                                │ mm       │ 0  │ fork │ 0   │ stopped │ 0       │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
                                 Use `pm2 show <id|name>` to get more details about an app
                                pi@raspberrypi:~ $ omxplayer --avdict rtsp_transport:tcp --win 800, 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USER&password=PASS&channel=1&stream=0.sdp
                                [1] 1084
                                [2] 1085
                                [3] 1086
                                pi@raspberrypi:~ $ File "421," not found.
                                pi@raspberrypi:~ $
                                1. Did not work
                                2. Also did not work, this time another file is not being found
                                omxplayer --avdict 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USER&password=PASS&channel=1&stream=0
                                [7] 1213
                                [8] 1214
                                [9] 1215
                                [4]   Exit 1                  omxplayer --avdict 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USERNAME
                                [5]   Done                    password=PASSWORD
                                [6]   Done                    channel=1
                                pi@raspberrypi:~ $ File "1120," not found.
                                1. 5., Did not work
                                  @epi My fault: for command line you have to fix the window command line argument:
                                  ... --win 800,421,1120,661 ... or ... --win '800 421 1120 661' ... and I think put the URL in quotes.
                                  You can test it without that whole argument (should play full screen). This is what I meant in #2 above. Here’s some combos to try:
                                  # Option 1 -- Should be full screen (if it works):
                                  omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp"
                                  # Option 2:
                                  omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0"
                                  # Option 3 Sub-stream:
                                  omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=1.sdp"
                                  # Option 4 UDP:
                                  omxplayer --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp"
                                  • E
                                    epi @shbatm
                                    @shbatm
                                    I did a fresh install of RPI OS & MM all addons
                                    Option one: freeze, then after a wait console available again
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-RTSPStream $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USER&password=PASS&channel=1&stream=0.sdp"
                                    Video codec omx-h264 width 1280 height 960 profile 77 fps 30.000000
                                    Audio codec pcm_alaw channels 1 samplerate 8000 bitspersample 8
                                    Subtitle count: 0, state: off, index: 1, delay: 0
                                    V:PortSettingsChanged: 1280x960@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                                    have a nice day ;)
                                    Option two: many lines
                                    COMXVideo::Decode timeout
                                    Option three: same as first one, freeze then
                                    Video codec omx-h264 width 704 height 576 profile 77 fps 30.000000
                                    V:PortSettingsChanged: 704x576@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                                    Option four:
                                    pi@raspberrypi:~ $ omxplayer --live --video_queue 4 --fps 30 "rtsp://192.168.2.2        37:554/user=USER&password=PASS&channel=1&stream=0.sdp"
                                    • Cr4z33C
                                      Cr4z33
                                      Hi @shbatm I am playing with your module to see TV programs from a Vu+ Duo² (a DVB-S2+DVB-T Linux/Enigma2 decoder).
                                      The only thing I can’t succed is to see HD TV programs.
                                      I’ve tried to use both
                                      url
                                      and
                                      hdUrl
                                      , but those streams won’t start (while normal SD programs are working just fine).
                                      This is my current script by the way (the HD channel has been disabled in the meantime):
                                      		    module: "MMM-RTSPStream",
                                      		    position: "bottom_right",
                                      		    // header: "Sky TG24",
                                      		        autoStart: true,
                                      		        rotateStreams: false,
                                      		        rotateStreamTimeout: 10,
                                      		        moduleWidth: 390,
                                      		        moduleHeight: 219,
                                      		        remotePlayer: 'none',
                                      		        showSnapWhenPaused: false,
                                      		        remoteSnaps: false,
                                      		        stream1: {
                                      		            // name: 'Sky TG24',
                                      		            // url: 'http://192.168.1.6:8001/1:0:1:5:7918:217C:EEEE0000:0:0:0:',
                                      		            name: 'RAI 3 TGR Puglia',
                                      		            url: 'http://192.168.1.6:8001/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:',
                                      		            // name: 'RAI 3 HD',
                                      		            // hdUrl: 'http://192.168.1.6:8001/1:0:1:2191:5:13E:EEEE0000:0:0:0:',
                                      		            protocol: "tcp",
                                      		            frameRate: 'undefined',
                                      		            width: 390,
                                      		            height: 219,
                                      • evroomE
                                        evroom
                                        Can you check this ?
                                        $ vcgencmd codec_enabled MPG2
                                        It should say “MPG2=enabled”.
                                        License can be bought for a few euro’s:
                                        http://www.raspberrypi.com/mpeg-2-license-key/
                                        Cr4z33C 1 Reply Last reply
                                        • Cr4z33C
                                          Cr4z33 @evroom
                                          It is enabled as I followed your advice. ;)
                                          As I said normal SD TV programs work just fine.
                                          The problem is with High Definition programs.
                                          • evroomE
                                            evroom
                                            RAI 3 HD probably is not free-to-air, so I cannot check it.
                                            But to be honest, it seems NOT to work for me too.
                                            Only SD, no HD.
                                            I had it working on v2.4.1 (made notes about it to not to forget) and did not use it after that.
                                            You can test it directly, without having to change the MM config all the time:
                                            $ omxplayer --win "0 0 800 480" --live "http://192.168.1.6:8001/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:"
                                            $ omxplayer --win "0 0 800 480" --live "http://192.168.1.6:8001/1:0:1:2191:5:13E:EEEE0000:0:0:0:"
                                            omxplayer will show the stream details:
                                            Video codec omx-mpeg2 width 720 height 576 profile 4 fps 25.000000
                                            Video codec omx-h264 width 1920 height 1080 profile 100 fps 50.000000
                                            On my Pi it seems to run, but nothing appears on the screen.
                                            • 30
                                            • 31
                                            • 6 / 31
