    602 Posts 67 Posters 2.3m Views 68 Watching
    • E Offline
      epi
      pi@raspberrypi:~ $ pm2 logs
      /home/pi/.pm2/pm2.log last 15 lines:
      PM2        | [2018-09-21T20:42:51.125Z] PM2 log: App [omx_stream1] with id [1] and pid [6551], exited with code [1] via signal [SIGI                                              NT]
      PM2        | [2018-09-21T20:42:51.132Z] PM2 log: Starting execution sequence in -fork mode- for app name:omx_stream1 id:1
      PM2        | [2018-09-21T20:42:51.159Z] PM2 log: App name:omx_stream1 id:1 online
      PM2        | [2018-09-21T20:42:53.221Z] PM2 log: App [omx_stream1] with id [1] and pid [6582], exited with code [1] via signal [SIGI                                              NT]
      PM2        | [2018-09-21T20:42:53.234Z] PM2 log: Starting execution sequence in -fork mode- for app name:omx_stream1 id:1
      PM2        | [2018-09-21T20:42:53.253Z] PM2 log: App name:omx_stream1 id:1 online
      PM2        | [2018-09-21T20:42:59.249Z] PM2 log: Stopping app:mm id:0
      PM2        | [2018-09-21T20:42:59.562Z] PM2 log: App [mm] with id [0] and pid [6136], exited with code [0] via signal [SIGINT]
      PM2        | [2018-09-21T20:42:59.632Z] PM2 log: pid=6136 msg=process killed
      PM2        | [2018-09-21T20:42:59.635Z] PM2 log: Starting execution sequence in -fork mode- for app name:mm id:0
      PM2        | [2018-09-21T20:42:59.651Z] PM2 log: App name:mm id:0 online
      PM2        | [2018-09-21T20:43:35.020Z] PM2 log: Stopping app:omx_stream1 id:1
      PM2        | [2018-09-21T20:43:35.054Z] PM2 error: Process with pid 6613 already exists
      PM2        | [2018-09-21T20:43:35.174Z] PM2 log: App [omx_stream1] with id [1] and pid [6613], exited with code [1] via signal [SIGI                                              NT]
      PM2        | [2018-09-21T20:43:35.193Z] PM2 log: pid=6613 msg=process killed
      /home/pi/.pm2/logs/omx-stream1-error.log last 15 lines:
      0|mm       | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
      0|mm       | [885:0919/041827.726584:FATAL:bus.cc(1152)] D-Bus connection was disconnected. Aborting.
      0|mm       | [10472:0919/213258.329193:FATAL:bus.cc(1152)] D-Bus connection was disconnected. Aborting.
      0|mm       | TypeError: `port` or a `server` must be provided
      0|mm       |     at new WebSocketServer (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/node_modules/                                              ws/lib/WebSocketServer.js:44:11)
      0|mm       |     at VideoStream.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/vid                                              eoStream.js:32:24)
      0|mm       |     at Class.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:49:32)
      0|mm       |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:257:22)
      0|mm       |     at Socket.<anonymous> (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
      0|mm       |     at emitTwo (events.js:126:13)
      0|mm       |     at Socket.emit (events.js:214:7)
      0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:513:12
      0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:131:7)
      0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
      0|mm       | Starting stream stream1 with args: [
      0|mm       |     "--avdict",
      0|mm       |     "rtsp_transport:tcp",
      0|mm       |     "--win",
      0|mm       |     "800, 421, 1120, 661",
      0|mm       |     "--live",
      0|mm       |     "--video_queue",
      0|mm       |     "4",
      0|mm       |     "--fps",
      0|mm       |     "30",
      0|mm       |     "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0"
      0|mm       | ]
      0|mm       | PM2: omx_stream1 already running. Stopping old instance...
      0|mm       | Starting PM2 for omx_stream1
      0|mm       | PM2 started for omx_stream1
        shbatm Module Developer
        @epi said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        /user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp
        Looking at the logs it looks like it’s trying to launch everything correctly. Just to confirm:
        1. The stream works correctly in VLC using the URL you have above.
        2. Since you’re using OMXPlayer – you are testing on the mirror with the RPi connected (not with VNC/Remote Desktop, etc). You won’t see playback from OMXPlayer on anything but the monitor connected to the RPi.
        You can try:
        1. Make sure the stream works with OMXPlayer by testing with the command line (shut down Magic Mirror first):
          omxplayer --avdict rtsp_transport:tcp --win 800, 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp
        2. Test the above with and without .sdp at the end of the path. I noticed in your log above for some reason it didn’t pass the extension .sdp. I don’t know if this is the issue or not. You can also try without the --win argument to test it full screen.
        3. Using UDP instead of TCP, put protocol: "udp" in your stream config (to test from command line, remove the rtsp_transport:tcp argument.
        4. Using stream=1 to test the lower resolution sub-stream. Sometimes OMXPlayer just refuses to do anything (without any errors) if it doesn’t have enough video memory–I’ve only seen it happen trying to play 3 streams at once though.
        5. Try adding a ? at the end of the stream url. Just something I saw while googling your url format to find out what kind of camera you have.
        • E Offline
          epi
          • E Offline
            epi @shbatm
            @shbatm
            @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
            1. Yes, it does work in VLC.
            2. I control RPi via SSH & VNC, but it is connected via HDMI to monitor and I don’t see any output on the actual screen neither via VNC, nor actual screen.
            Testing:
            1. By making tests I encounter an error:
            pi@raspberrypi:~ $ sudo reboot
            login as: pi
            pi@192.168.2.111's password:
            Linux raspberrypi 4.14.50-v7+ #1122 SMP Tue Jun 19 12:26:26 BST 2018 armv7l
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Mon Sep 24 01:55:35 2018
            SSH is enabled and the default password for the 'pi' user has not been changed.
            This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
            pi@raspberrypi:~ $ pm2 stop mm
            [PM2] Applying action stopProcessId on app [mm](ids: 0)
            [PM2] [mm](0) ✓
            │ App name │ id │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
            │ mm       │ 0  │ fork │ 0   │ stopped │ 0       │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
             Use `pm2 show <id|name>` to get more details about an app
            pi@raspberrypi:~ $ omxplayer --avdict rtsp_transport:tcp --win 800, 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USER&password=PASS&channel=1&stream=0.sdp
            [1] 1084
            [2] 1085
            [3] 1086
            pi@raspberrypi:~ $ File "421," not found.
            pi@raspberrypi:~ $
            1. Did not work
            2. Also did not work, this time another file is not being found
            omxplayer --avdict 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USER&password=PASS&channel=1&stream=0
            [7] 1213
            [8] 1214
            [9] 1215
            [4]   Exit 1                  omxplayer --avdict 421, 1120, 661 --live --video_queue 4 --fps 30 rtsp://192.168.2.237:554/user=USERNAME
            [5]   Done                    password=PASSWORD
            [6]   Done                    channel=1
            pi@raspberrypi:~ $ File "1120," not found.
            1. 5., Did not work
              @epi My fault: for command line you have to fix the window command line argument:
              ... --win 800,421,1120,661 ... or ... --win '800 421 1120 661' ... and I think put the URL in quotes.
              You can test it without that whole argument (should play full screen). This is what I meant in #2 above. Here’s some combos to try:
              # Option 1 -- Should be full screen (if it works):
              omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp"
              # Option 2:
              omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0"
              # Option 3 Sub-stream:
              omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=1.sdp"
              # Option 4 UDP:
              omxplayer --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USERNAME&password=PASSWORD&channel=1&stream=0.sdp"
              • E Offline
                epi @shbatm
                @shbatm
                I did a fresh install of RPI OS & MM all addons
                Option one: freeze, then after a wait console available again
                pi@raspberrypi:~/MagicMirror/modules/MMM-RTSPStream $ omxplayer --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 "rtsp://192.168.2.237:554/user=USER&password=PASS&channel=1&stream=0.sdp"
                Video codec omx-h264 width 1280 height 960 profile 77 fps 30.000000
                Audio codec pcm_alaw channels 1 samplerate 8000 bitspersample 8
                Subtitle count: 0, state: off, index: 1, delay: 0
                V:PortSettingsChanged: 1280x960@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                have a nice day ;)
                Option two: many lines
                COMXVideo::Decode timeout
                Option three: same as first one, freeze then
                Video codec omx-h264 width 704 height 576 profile 77 fps 30.000000
                V:PortSettingsChanged: 704x576@30.00 interlace:0 deinterlace:0 anaglyph:0 par:1.00 display:0 layer:0 alpha:255 aspectMode:0
                Option four:
                pi@raspberrypi:~ $ omxplayer --live --video_queue 4 --fps 30 "rtsp://192.168.2.2        37:554/user=USER&password=PASS&channel=1&stream=0.sdp"
                • Cr4z33C Offline
                  Cr4z33
                  Hi @shbatm I am playing with your module to see TV programs from a Vu+ Duo² (a DVB-S2+DVB-T Linux/Enigma2 decoder).
                  The only thing I can’t succed is to see HD TV programs.
                  I’ve tried to use both
                  url
                  and
                  hdUrl
                  , but those streams won’t start (while normal SD programs are working just fine).
                  This is my current script by the way (the HD channel has been disabled in the meantime):
                  		    module: "MMM-RTSPStream",
                  		    position: "bottom_right",
                  		    // header: "Sky TG24",
                  		        autoStart: true,
                  		        rotateStreams: false,
                  		        rotateStreamTimeout: 10,
                  		        moduleWidth: 390,
                  		        moduleHeight: 219,
                  		        localPlayer: 'omxplayer',
                  		        remotePlayer: 'none',
                  		        showSnapWhenPaused: false,
                  		        remoteSnaps: false,
                  		        stream1: {
                  		            // name: 'Sky TG24',
                  		            // url: 'http://192.168.1.6:8001/1:0:1:5:7918:217C:EEEE0000:0:0:0:',
                  		            name: 'RAI 3 TGR Puglia',
                  		            url: 'http://192.168.1.6:8001/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:',
                  		            // name: 'RAI 3 HD',
                  		            // hdUrl: 'http://192.168.1.6:8001/1:0:1:2191:5:13E:EEEE0000:0:0:0:',
                  		            protocol: "tcp",
                  		            frameRate: 'undefined',
                  		            width: 390,
                  		            height: 219,
                  • evroomE Offline
                    evroom
                    Can you check this ?
                    $ vcgencmd codec_enabled MPG2
                    It should say “MPG2=enabled”.
                    License can be bought for a few euro’s:
                    http://www.raspberrypi.com/mpeg-2-license-key/
                    MagicMirror version: 2.37.0
                    • Cr4z33C Offline
                      Cr4z33 @evroom
                      @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                      It is enabled as I followed your advice. ;)
                      As I said normal SD TV programs work just fine.
                      The problem is with High Definition programs.
                      • evroomE Offline
                        evroom
                        RAI 3 HD probably is not free-to-air, so I cannot check it.
                        But to be honest, it seems NOT to work for me too.
                        Only SD, no HD.
                        I had it working on v2.4.1 (made notes about it to not to forget) and did not use it after that.
                        You can test it directly, without having to change the MM config all the time:
                        $ omxplayer --win "0 0 800 480" --live "http://192.168.1.6:8001/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:"
                        $ omxplayer --win "0 0 800 480" --live "http://192.168.1.6:8001/1:0:1:2191:5:13E:EEEE0000:0:0:0:"
                        omxplayer will show the stream details:
                        Video codec omx-mpeg2 width 720 height 576 profile 4 fps 25.000000
                        Video codec omx-h264 width 1920 height 1080 profile 100 fps 50.000000
                        On my Pi it seems to run, but nothing appears on the screen.
                        • Cr4z33C Offline
                          Cr4z33 @evroom
                          @evroom I am in the same boat (with my Raspberry Pi 3 b+).
                          However I am 100% sure my Pi can handle HD channel streams as they work perfectly if using VLC!
                          • evroomE Offline
                            evroom
                            I can stream full HD at 50 fps:
                            A bit odd.
                            • Cr4z33C Offline
                              Cr4z33 @evroom
                              @evroom oops it came out I have to wait at least 30-40 seconds before I can see (succesfully) a 1080i @ 60Fps HD stream. :smiling_face_with_smiling_eyes:
                              However yesterday I found one more issue…
                              I connected the RPI for the first time to the TV to see how MagicMirror was looking on it, but I found out that the stream stops as soon as I ask something to Google Assistant (MMM-AssistantMk2 + MMM-Hotword by @Sean ) and it replies.
                              After that the stream doesn’t resume at all.
                              I don’t know where to start and cannot see why this is going on as the RPI can easily play 2+ media files at a time. :confounded_face:
                              • evroomE Offline
                                evroom
                                @Cr4z33
                                As I do not use MMM-AssistantMk2 and/or MMM-Hotword, I cannot help you there.
                                In principle the streaming should continue.
                                As a matter of fact, when I stop MM, my cam streams still continue (are listed by pm2 as independent applications).
                                As soon as there will be a MMM-HotAssistant, I might give it a try :-)
                                • Cr4z33C Offline
                                  Cr4z33 @evroom
                                  @evroom no problem mate although it looks like the developer is no more active in this thread my bad. :confused_face:
                                  Do you know by chance what to edit to see the stream in the same position as the white frame (I actually would like to get rid of it)?
                                  • evroomE Offline
                                    evroom
                                    Looking at the css file of the module, I would try to edit the custom.css and add this:
                                    .MMM-RTSPStream .innerWrapper {
                                      border: 0;
                                    Not tested.
                                      shbatm Module Developer @Cr4z33
                                      @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                      Please check the web browser console (ctrl+shift+i) and see if for some reason AssistantMk2 or Hotword are sending a pause/hide command to other modules. You would see something like: MMM-RTSPSTREAM is suspended.... Also, after the stream disappears, check the status of PM2 (pm2 status from ssh/terminal) and see if omx_streamX is still running. That will let me know if the module is telling the stream to stop or if omxplayer is giving up.
                                      Regarding the border alignment, search this forum and/or the closed issues on GitHub, it’s been answered before. @evroom’s solution looks correct to hide the border, but I can’t remember for sure.
                                      Mini-rant: OMXPLAYER is the lowest resource player I’ve found to use for playing video streams on a Pi, but frankly, it’s a finicky b***h and has terrible logging to inform you of the problem. 90% of the issues raised with this module are caused by omxplayer itself, which, unfortunately I don’t have any better way to solve than any other user. That’s why I use pm2 to manage the streams so it will at least attempt to restart when it crashes.
                                      @evroom, regarding the streams not stopping… Last week I found a bug in PM2’s API, calling stop on a process from node doesn’t work. I will work on a workaround until the PM2 devs correct the issue.
                                      Cr4z33C ? 2 Replies Last reply Reply Quote 0
                                      • BKeyportB Offline
                                        BKeyport Module Developer
                                        I can confirm OMX is a major B.
                                        I had to convert over to FFMPEG to get things to work without crashing the entire system to the point of taking it offline, but not crashing MM other than not updating anymore (Clock and such still work, just it couldn’t get anything off the internet)
                                        • Cr4z33C Offline
                                          Cr4z33 @shbatm
                                          @shbatm thanks for the reply.
                                          I can confirm that I’ve got rid of the white frame by following @evroom 's suggestion (thanks mate).
                                          Back in topic I’ve uploaded here the log 'cause I am not sure whether it is actually reporting a problem with MMM-RTSPStream or not. :thinking_face:
                                          Looking at it it says MMM-RTSPStream.js:161 MMM-RTSPStream has resumed... after two questions I made to Google Assistant, but I found no mention about RTSP pausing or stopping.
                                          However I can confirm that omx_stream has indeed stopped from running! :frowning_face_with_open_mouth:
                                           pm2 status
                                          │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
                                          │ mm          │ 0  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.5 MB   │
                                          │ omx_stream1 │ 1  │ N/A  │ fork   │ stopped │ 0   │ 0%     │ 0 B      │
                                            [[global:former-user]] @shbatm
                                            @shbatm @Cr4z33
                                            It might be due to collision of stream output from multi-source (omxplayer and my voice output)
                                            I’m not an expert of *nix system, so I cannot give a suggestion about using mixer(ALSA), but…
                                            in MMM-AssistantMk configuration, this could be help (not tested by myself. I don’t have RTSP-stream…)
                                            onIdle: {
                                              timer: 1000*10, //After 10sec of last query,
                                              command: "RTSP_ACTIVATE"
                                            onActivate: {
                                              timer: 0,
                                              command: "RTSP_DEACTIVATE"
                                            command: {
                                              "RTSP_ACTIVATE": {
                                                notificationExec: {
                                                  notification: "RTSP-PLAY",
                                                  payload: "all"
                                              "RTSP_DEACTIVATE": {
                                                notificationExec: {
                                                  notification: "RTSP-STOP",
                                                  payload: "all"
                                            • 30
                                            • 31
                                            • 6 / 31
