    602 Posts 67 Posters 2.3m Views 68 Watching
    • evroomE
      evroom
      Can you check this ?
      $ vcgencmd codec_enabled MPG2
      It should say “MPG2=enabled”.
      License can be bought for a few euro’s:
      http://www.raspberrypi.com/mpeg-2-license-key/
      MagicMirror version: 2.37.0
      • Cr4z33C
        Cr4z33 @evroom
        @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        It is enabled as I followed your advice. ;)
        As I said normal SD TV programs work just fine.
        The problem is with High Definition programs.
        • evroomE
          evroom
          RAI 3 HD probably is not free-to-air, so I cannot check it.
          But to be honest, it seems NOT to work for me too.
          Only SD, no HD.
          I had it working on v2.4.1 (made notes about it to not to forget) and did not use it after that.
          You can test it directly, without having to change the MM config all the time:
          $ omxplayer --win "0 0 800 480" --live "http://192.168.1.6:8001/1:0:1:D4B:8800:13E:EEEE0000:0:0:0:"
          $ omxplayer --win "0 0 800 480" --live "http://192.168.1.6:8001/1:0:1:2191:5:13E:EEEE0000:0:0:0:"
          omxplayer will show the stream details:
          Video codec omx-mpeg2 width 720 height 576 profile 4 fps 25.000000
          Video codec omx-h264 width 1920 height 1080 profile 100 fps 50.000000
          On my Pi it seems to run, but nothing appears on the screen.
          • Cr4z33C
            Cr4z33 @evroom
            @evroom I am in the same boat (with my Raspberry Pi 3 b+).
            However I am 100% sure my Pi can handle HD channel streams as they work perfectly if using VLC!
            • evroomE
              evroom
              I can stream full HD at 50 fps:
              A bit odd.
              • Cr4z33C
                Cr4z33 @evroom
                @evroom oops it came out I have to wait at least 30-40 seconds before I can see (succesfully) a 1080i @ 60Fps HD stream. :smiling_face_with_smiling_eyes:
                However yesterday I found one more issue…
                I connected the RPI for the first time to the TV to see how MagicMirror was looking on it, but I found out that the stream stops as soon as I ask something to Google Assistant (MMM-AssistantMk2 + MMM-Hotword by @Sean ) and it replies.
                After that the stream doesn’t resume at all.
                I don’t know where to start and cannot see why this is going on as the RPI can easily play 2+ media files at a time. :confounded_face:
                • evroomE
                  evroom
                  @Cr4z33
                  As I do not use MMM-AssistantMk2 and/or MMM-Hotword, I cannot help you there.
                  In principle the streaming should continue.
                  As a matter of fact, when I stop MM, my cam streams still continue (are listed by pm2 as independent applications).
                  As soon as there will be a MMM-HotAssistant, I might give it a try :-)
                  • Cr4z33C
                    Cr4z33 @evroom
                    @evroom no problem mate although it looks like the developer is no more active in this thread my bad. :confused_face:
                    Do you know by chance what to edit to see the stream in the same position as the white frame (I actually would like to get rid of it)?
                    • evroomE
                      evroom
                      Looking at the css file of the module, I would try to edit the custom.css and add this:
                      .MMM-RTSPStream .innerWrapper {
                        border: 0;
                      Not tested.
                        shbatm Module Developer @Cr4z33
                        @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                        Please check the web browser console (ctrl+shift+i) and see if for some reason AssistantMk2 or Hotword are sending a pause/hide command to other modules. You would see something like: MMM-RTSPSTREAM is suspended.... Also, after the stream disappears, check the status of PM2 (pm2 status from ssh/terminal) and see if omx_streamX is still running. That will let me know if the module is telling the stream to stop or if omxplayer is giving up.
                        Regarding the border alignment, search this forum and/or the closed issues on GitHub, it’s been answered before. @evroom’s solution looks correct to hide the border, but I can’t remember for sure.
                        Mini-rant: OMXPLAYER is the lowest resource player I’ve found to use for playing video streams on a Pi, but frankly, it’s a finicky b***h and has terrible logging to inform you of the problem. 90% of the issues raised with this module are caused by omxplayer itself, which, unfortunately I don’t have any better way to solve than any other user. That’s why I use pm2 to manage the streams so it will at least attempt to restart when it crashes.
                        @evroom, regarding the streams not stopping… Last week I found a bug in PM2’s API, calling stop on a process from node doesn’t work. I will work on a workaround until the PM2 devs correct the issue.
                        Cr4z33C ? 2 Replies Last reply Reply Quote 0
                        • BKeyportB
                          BKeyport Module Developer
                          I can confirm OMX is a major B.
                          I had to convert over to FFMPEG to get things to work without crashing the entire system to the point of taking it offline, but not crashing MM other than not updating anymore (Clock and such still work, just it couldn’t get anything off the internet)
                          • Cr4z33C
                            Cr4z33 @shbatm
                            @shbatm thanks for the reply.
                            I can confirm that I’ve got rid of the white frame by following @evroom 's suggestion (thanks mate).
                            Back in topic I’ve uploaded here the log 'cause I am not sure whether it is actually reporting a problem with MMM-RTSPStream or not. :thinking_face:
                            Looking at it it says MMM-RTSPStream.js:161 MMM-RTSPStream has resumed... after two questions I made to Google Assistant, but I found no mention about RTSP pausing or stopping.
                            However I can confirm that omx_stream has indeed stopped from running! :frowning_face_with_open_mouth:
                             pm2 status
                            │ Name        │ id │ mode │ status │ ↺       │ cpu │ memory │
                            │ mm          │ 0  │ N/A  │ fork   │ online  │ 0   │ 0%     │ 2.5 MB   │
                            │ omx_stream1 │ 1  │ N/A  │ fork   │ stopped │ 0   │ 0%     │ 0 B      │
                              A Former User @shbatm
                              @shbatm @Cr4z33
                              It might be due to collision of stream output from multi-source (omxplayer and my voice output)
                              I’m not an expert of *nix system, so I cannot give a suggestion about using mixer(ALSA), but…
                              in MMM-AssistantMk configuration, this could be help (not tested by myself. I don’t have RTSP-stream…)
                              onIdle: {
                                timer: 1000*10, //After 10sec of last query,
                                command: "RTSP_ACTIVATE"
                              onActivate: {
                                timer: 0,
                                command: "RTSP_DEACTIVATE"
                              command: {
                                "RTSP_ACTIVATE": {
                                  notificationExec: {
                                    notification: "RTSP-PLAY",
                                    payload: "all"
                                "RTSP_DEACTIVATE": {
                                  notificationExec: {
                                    notification: "RTSP-STOP",
                                    payload: "all"
                              • Cr4z33C
                                Cr4z33 @Guest
                                Thanks to @sean I’ve quickly fixed the RTSP issue by applying what he wrote here.
                                So if you are like me using both MMM-RTSPStream and MMM-AssistantMk2, open the config and in the MMM-AssistantMk2 module section replace
                                with
                                				onIdle: {
                                				onActivate: {
                                				  timer: 0,
                                				command: {
                                				  "RTSP_ACTIVATE": {
                                				    notificationExec: {
                                				      payload: "all"
                                				    notificationExec: {
                                				      payload: "all"
                                That way the stream will NEVER stop even if enquiring Google Assistant! :grinning_face_with_smiling_eyes:
                                Thank you @shbatm for willing to help me too.
                                  A Former User @Cr4z33
                                  @cr4z33
                                  Frankly said, it might not be due to my config modifying suggestion. (Because IT SHOULD PAUSE AND RESUME, but you said NEVER STOP)
                                  I think it is due to use HDMI as output. I don’t know about it, but it might be able to mix from multi-sources.
                                  • Cr4z33C
                                    Cr4z33 @Guest
                                    @sean yeah I actually forgot to mention that the RTSP outputs to HDMI while Google Assistant outputs to a RPI Voice HAT speaker. :grimacing_face:
                                      That’s how it works. not by my code. :D
                                      • Cr4z33C
                                        Cr4z33 @Guest
                                        @sean of course. :winking_face:
                                        To everybody else: I removed the white frame and forgot to ask how to move the streaming windows.
                                        It is now offset compared to its module position. :confused_face:
                                        I guess I need to edit something in
                                        .MMM-RTSPStream .canvas {
                                          position: absolute;
                                          z-index: 1;
                                          left: 50%;
                                          top: 50%;
                                          /*width: 352px;
                                          height: 240px;*/
                                          -webkit-transform: translate(-50%, -50%);
                                            width: 100%;
                                        height: 100%;
                                        right?
                                          Play with the moduleOffset and absPosition config options. Search this forum for those and check out the README on GitHub for details of what each one does.
                                          • cowboysdudeC
                                            cowboysdude Module Developer @barnosch
                                            @barnosch Are you getting any console.log errors or PM2 errors?
                                            • 30
                                            • 31
                                            • 6 / 31
