    Magic Mirror -> Special Caracters won't display in headers
    16 Posts 3 Posters 7.0k Views 3 Watching
    • G Offline
      Galm
      I have a small display problems. Special charaters (https://www.degraeve.com/reference/specialcharacters.php) won’t display in titles. The fun part is that they do display in each modules so i don’t get it.
      Regional setting are correctly set since i can get the special caracters (texte mode) when i am on the interface. Did i miss something?
      Thanks a lot for your help
      ? justjim1220J 2 Replies Last reply Reply Quote 0
        A Former User @Galm
        @galm
        As I know, Roboto font of default MM has some chars missed. My remembrance tell me there were some topics about it.
        • justjim1220J Offline
          justjim1220 Module Developer @Galm
          @galm
          I was able to get the &#8593 and the ↓ to show in one of my headers…
          What characters are you having issues with?
          "Life's Too Short To Dance With Ugly People"
          Jim Hallock - 1995
          • G Offline
            Galm
            I am having issue with (capital or not) : à; é; ô… french caractere i will say… WHat it is fun : inside modules like calendar, it is working will and this type of caractere are showing properly
              @galm
              show me your header codes
              there are a few ways to get them to show…
              Jim Hallock - 1995
              • G Offline
                Galm
                well i haven’t change anything on headers code… that’s the standard one… i can use special caracter code to make it work as a workaround if i want
                  @galm
                  yes, I typed the code for the characters in the header of the config file…
                  Jim Hallock - 1995
                    @galm
                    I don’t think it is possible to do without using character codes
                    I would think that if you had a french keyboard, id would type right in…
                    Jim Hallock - 1995
                    • G Offline
                      Galm
                      well why should not be since within the module (calendar for example) it is working ? what’s why i don’t get it. the meta header is correct in the HTML pages (index.html) so it should show up
                      justjim1220J 4 Replies Last reply Reply Quote 0
                        @galm
                        So, how are you putting in the characters?
                        French keyboard?
                        Jim Hallock - 1995
                          @galm
                          You can also copy and paste the characters…
                          Jim Hallock - 1995
                            @galm
                            I found this, I don’t know if it would help you or not…
                            http://www.columbia.edu/itc/french/matheis/1102fa01/edit/accents.html#PC
                            Jim Hallock - 1995
                            • G Offline
                              Galm
                              well since it is HTML the only way workaround i can see is using HTML core for special caratere… i was hoping somebody could explan to me why i have a difference between the header and the module in terms of applying UTF-8 standard :(
                                @galm
                                This is copy/paste…
                                Jim Hallock - 1995
                                • G Offline
                                  Galm
                                  I did some research… found that it was coming from my test editor… change its config and now it works perfectly
                                  Thanks alot for your time :)
                                  justjim1220J 1 Reply Last reply Reply Quote 1
                                    @galm
                                    I’m glad you got it figured out!
                                    Jim Hallock - 1995
