    Magic Mirror -> Special Caracters won't display in headers
    16 Posts 3 Posters 7.2k Views 3 Watching
      [[global:former-user]] @Galm
      @galm
      As I know, Roboto font of default MM has some chars missed. My remembrance tell me there were some topics about it.
      • justjim1220J Offline
        justjim1220 Module Developer @Galm
        @galm
        I was able to get the &#8593 and the ↓ to show in one of my headers…
        What characters are you having issues with?
        Jim Hallock - 1995
        • G Offline
          Galm
          I am having issue with (capital or not) : à; é; ô… french caractere i will say… WHat it is fun : inside modules like calendar, it is working will and this type of caractere are showing properly
            @galm
            show me your header codes
            there are a few ways to get them to show…
            Jim Hallock - 1995
            • G Offline
              Galm
              well i haven’t change anything on headers code… that’s the standard one… i can use special caracter code to make it work as a workaround if i want
              justjim1220J 2 Replies Last reply Reply Quote 0
                @galm
                yes, I typed the code for the characters in the header of the config file…
                Jim Hallock - 1995
                  @galm
                  I don’t think it is possible to do without using character codes
                  I would think that if you had a french keyboard, id would type right in…
                  Jim Hallock - 1995
                  • G Offline
                    Galm
                    well why should not be since within the module (calendar for example) it is working ? what’s why i don’t get it. the meta header is correct in the HTML pages (index.html) so it should show up
                    justjim1220J 4 Replies Last reply Reply Quote 0
                      @galm
                      So, how are you putting in the characters?
                      French keyboard?
                      Jim Hallock - 1995
                        @galm
                        You can also copy and paste the characters…
                        Jim Hallock - 1995
                          @galm
                          I found this, I don’t know if it would help you or not…
                          http://www.columbia.edu/itc/french/matheis/1102fa01/edit/accents.html#PC
                          Jim Hallock - 1995
                          • G Offline
                            Galm
                            well since it is HTML the only way workaround i can see is using HTML core for special caratere… i was hoping somebody could explan to me why i have a difference between the header and the module in terms of applying UTF-8 standard :(
                              @galm
                              This is copy/paste…
                              Jim Hallock - 1995
                              • G Offline
                                Galm
                                I did some research… found that it was coming from my test editor… change its config and now it works perfectly
                                Thanks alot for your time :)
                                justjim1220J 1 Reply Last reply Reply Quote 1
                                  @galm
                                  I’m glad you got it figured out!
                                  Jim Hallock - 1995
