    Magic Mirror Blanks Several Hours
    29 Posts 12 Posters 17.1k Views 12 Watching
      StrIIker
      Ahh, that’s the issue! The modules must get stuck and no longer refresh. Has anyone else run into this issue and found a cause / solution? My issue crops up more often than once per day and I’d prefer to get a permanent fix for this. I don’t have any unusual modules loaded (actually it has been happening from day one while I have been slowly working on it so this has been happening with a fresh install).
        sdetweil @StrIIker
        @striiker is this version 2.4.1?
        The update module was throwing an error causing the black screen.
        I would comment out that module
        M S G 4 Replies Last reply Reply Quote 0
          MadScientist @sdetweil
          That didn’t help in my case, hence the work-around with the cronjob. But it’s true that everybody should first try to disable the update module in their config.
            StrIIker @sdetweil
            @sdetweil said in Magic Mirror Blanks Several Hours:
            I am at the latest build (2.5.0) although I installed Magic Mirror from the previous version and have the update module running.
              StrIIker @MadScientist
              @madscientist said in Magic Mirror Blanks Several Hours:
              I was unaware of the suggestion to kill the update module. I have removed it from my config and will monitor the status. Thank you for the suggestion (and @sdetweil )! Any other best practice suggestions which I should consider? I have just done the base install and modified weather icons / details and also installed Alexapi (yet to work on that module as I am still trying to understand if I should also install either MMM-Alexa or MMM-Awesome-Alexa too as I am not clear on how these all work).
                @madscientist Could you please share what you use in your cronjob to reload the modules? Thanks!
                  MadScientist @StrIIker
                  @striiker 0 6 * * * pm2 reload mm
                  It reloads my mm.sh script every day at 6am. Working perfectly fine for quite some time now.
                    StrIIker @sdetweil
                    I’m in the same boat as @MadScientist in that my module rotation still dies necessitating a restart of the modules. Canceling the update check did improve the situation in that it apparently does not crash out as often.
                    • G Offline
                      Graham Rich @sdetweil
                      @sdetweil So I’ve updated my MagicMirror today with NPM update and NPM upgrade and my mirror is now black when I load it. My Mirror is pretty busy with NNOA3, video window from MotionEye and a few of the UK train apps. I was going to thin it down to see if that fixes it but thought Id check if anyone else found a fix yet.
                      • G Offline
                        Graham Rich
                        I’m not sure if my issue isnt an update failure. Im getting this message on upgrade
                        pi@pi:~/MagicMirror $ npm update
                        phantomjs-prebuilt@2.1.16 install /home/pi/MagicMirror/node_modules/phantomjs-prebuilt
                        node install.js
                        PhantomJS not found on PATH
                        Unexpected platform or architecture: linux/arm
                        It seems there is no binary available for your platform/architecture
                        Try to install PhantomJS globally
                        npm WARN grunt-yamllint@0.3.0 requires a peer of grunt@>=1.0.1 but none is installed. You must install peer dependencies yourself.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 (node_modules/phantomjs-prebuilt):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: phantomjs-prebuilt@2.1.16 install: node install.js
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                        • moment@2.22.2
                        • iconv-lite@0.4.24
                        • walk@2.3.14
                          added 5 packages from 11 contributors and audited 2316 packages in 40.649s
                          found 5 low severity vulnerabilities
                          run npm audit fix to fix them, or npm audit for details
                        node install.js
                        electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                        node ./download-chromedriver.js
                        successfully dowloaded and extracted!
                        • spectron@3.8.0
                          removed 4 packages, updated 2 packages and audited 2311 packages in 42.884s
                          MadScientist @Graham Rich
                          @graham-rich to update your MM installation you have to enter your MM directory and run git pull && npm install. Looks like you tried to update npm instead.
                          • G Offline
                            Graham Rich
                            Just run NPM install in the MagicMirror directory and seems to have fixed it. Was suggestion from NPM audit command
                            thanks for suggestion tho
                              chief
                              I’m having trouble with this as well - blank screen for the past day no matter what I try to do. Now when I try to git pull && npm install, I get the following errors:
                              pi@raspberrypi:~/MagicMirror $ sudo git pull && npm install
                              Already up-to-date.
                              npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/socket.io-parser/node_modules
                              npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
                              npm ERR! path /home/pi/MagicMirror/node_modules/socket.io-parser/node_modules
                              npm ERR! code EACCES
                              npm ERR! errno -13
                              npm ERR! syscall access
                              npm ERR! Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/node_modules/socket.io-parser/node_modules’
                              npm ERR! { Error: EACCES: permission denied, access ‘/home/pi/MagicMirror/node_modules/socket.io-parser/node_modules’
                              npm ERR! stack: ‘Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/socket.io-parser/node_modules'’,
                              npm ERR! errno: -13,
                              npm ERR! code: ‘EACCES’,
                              npm ERR! syscall: ‘access’,
                              npm ERR! path: ‘/home/pi/MagicMirror/node_modules/socket.io-parser/node_modules’ }
                              npm ERR!
                              npm ERR! The operation was rejected by your operating system.
                              npm ERR! It is likely you do not have the permissions to access this file as the current user
                              npm ERR!
                              npm ERR! If you believe this might be a permissions issue, please double-check the
                              npm ERR! permissions of the file and its containing directories, or try running
                              npm ERR! the command again as root/Administrator (though this is not recommended).
                              npm ERR! /home/pi/.npm/_logs/2018-10-09T16_49_46_380Z-debug.log
                              AND if I try to update npm itself, a different error appears:
                              pi@raspberrypi:~/MagicMirror $ sudo npm update
                              npm ERR! path /home/pi/MagicMirror/node_modules/source-map/build/suffix-utils.jsm
                              npm ERR! code Unknown system error -117
                              npm ERR! errno -117
                              npm ERR! syscall unlink
                              npm ERR! Unknown system error -117: Unknown system error -117, unlink ‘/home/pi/MagicMirror/node_modules/source-map/build/suffix-utils.jsm’
                              npm ERR! /root/.npm/_logs/2018-10-09T16_54_00_820Z-debug.log
                              Any help??
                                MadScientist
                                Why are you running the update command with sudo?
                                Does your mirror work but it blanks the screen after some hours or is it always black?
                                  chief @MadScientist
                                  @madscientist It was always black - if I don’t run with sudo it quits almost immediately. I’m not sure exactly what the issue was, but I went ahead and restored a backup from 2.4.1 and it’s working fine now (removed the update alert on the top bar).
                                    StrIIker
                                    I’m still having the issue where my screen blanks (modules stop loading) after about 5-6 hours. I perform a Ctrl-r to reload and it continues. Has anyone else figured out a cause or a solution? I’ll have to add several more cron jobs to reload modules periodically. I am not running anything beyond the core modules at present. I even performed a fresh install and still see this happen. I can’t see this being normal or people just tolerating it…
                                    Thoughts?
                                    /* Magic Mirror Config Sample
                                    * MIT Licensed.
                                    var config = {
                                    	"port": 8080,
                                    	"language": "en",
                                    	"timeFormat": 24,
                                    	"units": "imperial",
                                    	"modules": [
                                    			"module": "alert"
                                    			"module": "clock",
                                    			"position": "top_left"
                                    			"module": "calendar",
                                    			"header": "Calendar",
                                    			"position": "top_left",
                                    			"config": {
                                    				"calendars": [
                                    						"symbol": "calendar-check-o ",
                                    						"url": "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                                    						"color": "#FFFFFF"
                                    						"symbol": "calendar ",
                                    						"url": "https://eleted",
                                    						"color": "#04f448",
                                    						"fetchInterval": 30000
        "symbol": "birthday-cake ",
        "url": "https://deleted                              "color": "#DA70D6",
                                    				"colored": true,
                                    				timeFormat: "absolute",
                                    				showEnd: false,
                                    				fullDayEventDateFormat: 'Do MMM',
                                    			"module": "compliments",
                                    			"position": "lower_third"
                                    			"module": "currentweather",
                                    			"position": "top_right",
                                    			"config": {
                                    				"location": "deleted",
                                    				"locationID": "deleted",
                                    				"appid": "deleted
                                    			"module": "weatherforecast",
                                    			"header": "Weather Forecast",
                                    			"config": {
                                    				"appid": "deleted",
                                    				"colored": "true"
                                    			"module": "newsfeed",
                                    			"position": "bottom_bar",
                                    			"config": {
                                    				"feeds": [
                                    						"title": "New York Times",
                                    						"url": "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                    						"title": "BBC World News",
                                    						"url": "http://feeds.bbci.co.uk/news/world/us_and_canada/rss.xml"
                                    						"title": "Reuters Science News",
                                    						"url": "http://feeds.reuters.com/reuters/scienceNews"
                                    				"showSourceTitle": true,
                                    				"showPublishDate": true
                                    			"module": "MMM-Admin-Interface"
                                    	"address": "0.0.0.0",
                                    	"ipWhitelist": [
                                    		"127.0.0.1",
                                    		"::ffff:127.0.0.1",
                                    		"::1",
                                    		"deleted"
                                      StrIIker @chief
                                      @chief said in Magic Mirror Blanks Several Hours:
                                      If you need to run this as sudo then your installation probably has root as the owner of the files. A simple way to check this is log in as pi and type cd ~ and then ls -al you should see the list of files and directories and a column of pi pi (shows owner and group membership of the file or directory). If you see a lot of root root then you ran something which changed ownership of these files and directories…
                                      ls -al
                                      total 221604
                                      drwxr-xr-x  17 pi pi      4096 Oct 10 16:00 .
                                      drwxr-xr-x  27 pi pi      4096 Oct 10 10:33 ..
                                      -rw-r--r--   1 pi pi     24164 Oct  8 18:56 CHANGELOG.md
                                      drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 clientonly
                                      drwxr-xr-x   2 pi pi      4096 Oct  8 19:00 config
                                      -rw-------   1 pi pi 498610176 Oct 10 16:00 core
                                      drwxr-xr-x   3 pi pi      4096 Oct  8 19:16 css
                                      -rw-r--r--   1 pi pi       856 Oct  8 18:56 dangerfile.js
                                      -rw-r--r--   1 pi pi       132 Oct  8 18:56 .eslintignore
                                      -rw-r--r--   1 pi pi       448 Oct  8 18:56 .eslintrc.json
                                      drwxr-xr-x   3 pi pi      4096 Oct  8 19:00 fonts
                                      drwxr-xr-x   8 pi pi      4096 Oct 10 10:33 .git
                                      drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 .github
                                      -rw-r--r--   1 pi pi      1074 Oct  8 18:56 .gitignore
                                      -rw-r--r--   1 pi pi      2385 Oct  8 18:56 Gruntfile.js
                                      -rw-r--r--   1 pi pi      2675 Oct  8 18:56 index.html
                                      drwxr-xr-x   3 pi pi      4096 Oct  8 18:56 installers
                                      drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 js
                                      -rw-r--r--   1 pi pi       271 Oct  8 18:56 jsconfig.json
                                      -rw-r--r--   1 pi pi      1118 Oct  8 18:56 LICENSE.md
                                      drwxr-xr-x   4 pi pi      4096 Oct  8 18:56 modules
                                      -rw-r--r--   1 pi pi      1040 Oct  8 18:56 module-types.ts
                                      drwxr-xr-x 642 pi pi     20480 Oct  8 19:00 node_modules
                                      -rw-r--r--   1 pi pi      2195 Oct  8 18:56 package.json
                                      -rw-r--r--   1 pi pi    271341 Oct  8 19:00 package-lock.json
                                      -rw-r--r--   1 pi pi     14450 Oct  8 18:56 README.md
                                      -rw-r--r--   1 pi pi       142 Oct  8 18:56 run-start.sh
                                      drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 serveronly
                                      -rw-r--r--   1 pi pi       478 Oct  8 18:56 .snyk
                                      drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 splashscreen
                                      -rw-r--r--   1 pi pi       126 Oct  8 18:56 .stylelintrc
                                      drwxr-xr-x   6 pi pi      4096 Oct  8 18:56 tests
                                      drwxr-xr-x   2 pi pi      4096 Oct  8 18:56 translations
                                      -rw-r--r--   1 pi pi       285 Oct  8 18:56 .travis.yml
                                      drwxr-xr-x   3 pi pi      4096 Oct  8 19:00 vendor
                                      If you have a permissions issue, you can fix it easily by typing:
                                      sudo chown -R pi:pi /home/pi
                                      This will change owner and group membership to pi
                                        @striiker Could it be the screensaver? Have you tried updating to 2.5.0 or downgrading to 2.3.x? I am pretty sure I didn’t have the problem with 2.3. In my case it’s enough to reload the MM only once a day. Also I had noticed that my Pi was reeeeeeeaaaaaaallllllyyyyyyy slow when connecting via shh after the screen blanked. Slow to the point I thought it crashed. Pretty sure it was a memory leak or so.
                                        I haven’t updated to 2.5 yet as I want to wait and see what problems other users experience :face_with_stuck-out_tongue_winking_eye:
                                          Well, I have disabled the screensaver via config settings as advised by several of the tutorials for setting up the mirror. Plus, if it were blanking or a screensaver, it would wake when I move the mouse or type. When I try to type etc, nothing shows, just the black screen. Ctrl-R or CTRL-Q works.
                                          I am on the latest (2.5) and have not tried downgrading. I assume that would require a full wipe and re-install but may be worth trying… When I experience this condition, I see no slowness while connected to ssh. I’m sure this is some odd leak which crashes some aspect of whatever displays the modules over time. I’m just surprised that nobody else (in any significant number) is experiencing this. It happens with a new everything… (Pi3B, latest firmware and latest mirror version)
                                          • H Offline
                                            hrjmsh @StrIIker
                                            @striiker I am having the exact same problem. Screen goes black every 6-8 hours with just the pointer showing. I have to reload/restart the Magic Mirror then. This started to happen after upgrade to version 2.4.0
                                            I have upgraded to 2.5.0 but the issue remains the same.
                                            I am still trying to figure out the solution; just wanted to share with you that you are not the only one facing this problem!
