    This might be a daft question, but...
    27 Posts 6 Posters 21.4k Views 5 Watching
      Mitchfarino Module Developer @alexyak
      Thanks @alexyak , much appreciated!
        Sorry, again
        Which of these projects would be the correct one?!
          alexyak @Mitchfarino
          @Mitchfarino Sorry, I’ve not tried this yet myself, but have you tried to use this option that you have selected: “From Existing Node.js code”?
            @alexyak Sorted, I tried that and imported an existing module
            Now I just to figure out what I’m doing now! :)
              OK, I’m up and running, but I’m not sure how to parse my JSON result in to html.
              I have this, but don’t know whether it’s correct
              I just want to see if I can list the names from the results of my GET request
              getDom: function () {
                  $.getJSON(this.url,
                      function (data) {
                          var tr;
                          for (var i = 0; i < data.length; i++) {
                              tr = $('<tr/>');
                              tr.append("<td>" + data[i].name + "</td>");
                              $('table').append(tr);
                          wrapper.append("<td>" + data[i].name + "</td>");
                  return wrapper;
              I’d like to note, this is all completely new to me, so I’m trying to learn as I go…
                @strawberry-3-141 I saw you were online, so I’m shamelessly tagging you in my post in the hopes of some guidance :-(
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @Mitchfarino
                  @Mitchfarino
                      var table = document.createElement("table");
                      $.getJSON(this.url,
                          function (data) {
                                  var row = document.createElement("tr");
                                  var name = document.createElement("td");
                                  name.innerHTML = data[i].name;
                                  row.appendChild(name);
                                  table.appendChild(row);
                              wrapper.appendChild(table);
                              return wrapper;
                  but I’m pretty sure that this will not work, because the return is in an asynchronous callback, i would do a different structure call your url in an interval somewhere else and save your data into an module variable and call the updateDom function after a result, then in getDom you iterate over the data.
                    Mitchfarino Module Developer @strawberry 3.141
                    @strawberry-3.141 Thanks very much, I’ll have a play with it over the weekend and hopefully I get can something working
                    I’ve not done anything like this before really, so just jumping in and seeing what happens :-)
                      @Mitchfarino
                      url: "", //Insert your url here
                      result: false,
                      defaults: {
                          updateInterval: 30 * 60 * 1000 //Every 30 mins
                      start: function(){
                          this.getData();
                          setInterval(()=>{
                              this.getData();
                          }, this.config.updateInterval);
                      getDom: function() {
                          if(this.result){
                              for (var i = 0; i < this.result.length; i++) {
                                  name.innerHTML = this.result[i].name;
                          } else {
                              wrapper.innerHTML = "No data to show!";
                          return wrapper;
                      getData: function(){
                          $.getJSON(this.url, (data) => {
                              this.result = data;
                              this.updateDom();
                        @strawberry-3.141 Thanks for this, I’ll see if I can get it working
                          Mitchfarino Module Developer @Mitchfarino
                          @strawberry-3-141 once I’ve got some code, how do I test it on my mirror?
                          Just copy the folder to the modules folder and add it to the config, or is there something else I need to do?
                            paviro @Mitchfarino
                            @Mitchfarino no that’s it :)
                            – The Doctor
                              Mitchfarino Module Developer @paviro
                              @paviro Awesome, thank you!
                              I’m stumbling my way through, hopefully I’ll have something working soon :)
                                paviro @Mitchfarino
                                @Mitchfarino good luck! :)
                                – The Doctor
                                  @paviro Just one more question…
                                  Why would I need to run npm install for some modules?
                                    to install the dependencies listed in the package.json file
                                      Hi All,
                                      I’m struggling a bit here, does anyone fancy doing a bit of hand holding to point me in the right direction?
                                      JS is completely knew to me, but I’m not sure where to start.
                                      Thanks in advance - I’m happy to do it through chats on this forum, or using hangouts or something similar.
                                        @Mitchfarino feel free to contact me via personal message
