    This might be a daft question, but...
    27 Posts 6 Posters 21.6k Views 5 Watching
      alexyak @Mitchfarino
      @Mitchfarino Most certainly you should be able to. There are node.js specific projects. You just need to install tools:
      https://beta.visualstudio.com/vs/node-js/
        Mitchfarino Module Developer @alexyak
        Thanks @alexyak , much appreciated!
          Sorry, again
          Which of these projects would be the correct one?!
            @Mitchfarino Sorry, I’ve not tried this yet myself, but have you tried to use this option that you have selected: “From Existing Node.js code”?
              @alexyak Sorted, I tried that and imported an existing module
              Now I just to figure out what I’m doing now! :)
                OK, I’m up and running, but I’m not sure how to parse my JSON result in to html.
                I have this, but don’t know whether it’s correct
                I just want to see if I can list the names from the results of my GET request
                getDom: function () {
                    $.getJSON(this.url,
                        function (data) {
                            var tr;
                            for (var i = 0; i < data.length; i++) {
                                tr = $('<tr/>');
                                tr.append("<td>" + data[i].name + "</td>");
                                $('table').append(tr);
                            wrapper.append("<td>" + data[i].name + "</td>");
                    return wrapper;
                I’d like to note, this is all completely new to me, so I’m trying to learn as I go…
                  @strawberry-3-141 I saw you were online, so I’m shamelessly tagging you in my post in the hopes of some guidance :-(
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @Mitchfarino
                    @Mitchfarino
                        var table = document.createElement("table");
                        $.getJSON(this.url,
                            function (data) {
                                    var row = document.createElement("tr");
                                    var name = document.createElement("td");
                                    name.innerHTML = data[i].name;
                                    row.appendChild(name);
                                    table.appendChild(row);
                                wrapper.appendChild(table);
                                return wrapper;
                    but I’m pretty sure that this will not work, because the return is in an asynchronous callback, i would do a different structure call your url in an interval somewhere else and save your data into an module variable and call the updateDom function after a result, then in getDom you iterate over the data.
                      Mitchfarino Module Developer @strawberry 3.141
                      @strawberry-3.141 Thanks very much, I’ll have a play with it over the weekend and hopefully I get can something working
                      I’ve not done anything like this before really, so just jumping in and seeing what happens :-)
                        @Mitchfarino
                        url: "", //Insert your url here
                        result: false,
                        defaults: {
                            updateInterval: 30 * 60 * 1000 //Every 30 mins
                        start: function(){
                            this.getData();
                            setInterval(()=>{
                                this.getData();
                            }, this.config.updateInterval);
                        getDom: function() {
                            if(this.result){
                                for (var i = 0; i < this.result.length; i++) {
                                    name.innerHTML = this.result[i].name;
                            } else {
                                wrapper.innerHTML = "No data to show!";
                            return wrapper;
                        getData: function(){
                            $.getJSON(this.url, (data) => {
                                this.result = data;
                                this.updateDom();
                          @strawberry-3.141 Thanks for this, I’ll see if I can get it working
                            Mitchfarino Module Developer @Mitchfarino
                            @strawberry-3-141 once I’ve got some code, how do I test it on my mirror?
                            Just copy the folder to the modules folder and add it to the config, or is there something else I need to do?
                              paviro @Mitchfarino
                              @Mitchfarino no that’s it :)
                              – The Doctor
                                Mitchfarino Module Developer @paviro
                                @paviro Awesome, thank you!
                                I’m stumbling my way through, hopefully I’ll have something working soon :)
                                  paviro @Mitchfarino
                                  @Mitchfarino good luck! :)
                                  – The Doctor
                                    @paviro Just one more question…
                                    Why would I need to run npm install for some modules?
                                      to install the dependencies listed in the package.json file
                                        Hi All,
                                        I’m struggling a bit here, does anyone fancy doing a bit of hand holding to point me in the right direction?
                                        JS is completely knew to me, but I’m not sure where to start.
                                        Thanks in advance - I’m happy to do it through chats on this forum, or using hangouts or something similar.
                                          @Mitchfarino feel free to contact me via personal message
