    This might be a daft question, but...
    27 Posts 6 Posters 18.7k Views 5 Watching
    • MitchfarinoM Offline
      Mitchfarino Module Developer
      What do you develop your modules in?
      A text editor, or is there some IDE I should look to use?
      I’ve got to start somewhere, so I’m going to pick at one of the existing modules to see what the score is
        ronny3050 Module Developer @Mitchfarino
        @Mitchfarino My favorite IDE is Webstorm for these kinds of projects. You can also use sublime text for a text editor, if you don’t wish to go the IDE route.
        MitchfarinoM 1 Reply Last reply Reply Quote 0
          Mitchfarino Module Developer @ronny3050
          @ronny3050 Thanks for your reply
          Will I get any kind of intellisense in the IDE?
          Also, do I develop on the Pi itself or can I do develop/test on my Windows machine?
            @Mitchfarino yes you do get intellisense, which helps when you are requiring core node modules to easily find out the function you’re looking for.
            You should always develop on your local machine before deploying it to the pi. This way your code is generic and you won’t have memory issues. Not to mention, there’s no lag if you’re sshing into pi and can see results straightaway without having to restart mm all the time.
            • KirAsh4K Offline
              KirAsh4 Moderator
              I use Notepad++, it does the job for me. However, I have other editors that I use for heavier tasks, like when I’m writing C/C++ code. For a peek at my crazy dev environment, read this post: https://forum.magicmirror.builders/topic/265/my-setup-or-how-crazy-i-am
                alexyak
                Visual Studio Code rocks! It’s relatively new, but it’s very lightweight, run on any platform, includes intellisense and bunch of addins. Allows you debugging in the node.js…
                • paviroP Offline
                  paviro
                  If you happen to have a Mac CodeRunner is amazing! It can compile and execute a lot of different programming languages and is really fast. Atom (Windows, Linux, Mac) is also really nice but I quite often find myself using CodeRunner instead because Atom needs so much CPU and is also a lot slower compared.
                  – The Doctor
                    Can I use Visual Studio?
                    What type of project would I create?
                      alexyak @Mitchfarino
                      @Mitchfarino Most certainly you should be able to. There are node.js specific projects. You just need to install tools:
                      https://beta.visualstudio.com/vs/node-js/
                        Mitchfarino Module Developer @alexyak
                        Thanks @alexyak , much appreciated!
