    This might be a daft question, but...
    27 Posts 6 Posters 20.8k Views 5 Watching
    • K Offline
      KirAsh4 Moderator
      I use Notepad++, it does the job for me. However, I have other editors that I use for heavier tasks, like when I’m writing C/C++ code. For a peek at my crazy dev environment, read this post: https://forum.magicmirror.builders/topic/265/my-setup-or-how-crazy-i-am
        alexyak
        Visual Studio Code rocks! It’s relatively new, but it’s very lightweight, run on any platform, includes intellisense and bunch of addins. Allows you debugging in the node.js…
          paviro
          If you happen to have a Mac CodeRunner is amazing! It can compile and execute a lot of different programming languages and is really fast. Atom (Windows, Linux, Mac) is also really nice but I quite often find myself using CodeRunner instead because Atom needs so much CPU and is also a lot slower compared.
          – The Doctor
            Mitchfarino Module Developer
            Can I use Visual Studio?
            What type of project would I create?
              alexyak @Mitchfarino
              @Mitchfarino Most certainly you should be able to. There are node.js specific projects. You just need to install tools:
              https://beta.visualstudio.com/vs/node-js/
                Mitchfarino Module Developer @alexyak
                Thanks @alexyak , much appreciated!
                  Sorry, again
                  Which of these projects would be the correct one?!
                    @Mitchfarino Sorry, I’ve not tried this yet myself, but have you tried to use this option that you have selected: “From Existing Node.js code”?
                      @alexyak Sorted, I tried that and imported an existing module
                      Now I just to figure out what I’m doing now! :)
                        OK, I’m up and running, but I’m not sure how to parse my JSON result in to html.
                        I have this, but don’t know whether it’s correct
                        I just want to see if I can list the names from the results of my GET request
                        getDom: function () {
                            $.getJSON(this.url,
                                function (data) {
                                    var tr;
                                    for (var i = 0; i < data.length; i++) {
                                        tr = $('<tr/>');
                                        tr.append("<td>" + data[i].name + "</td>");
                                        $('table').append(tr);
                                    wrapper.append("<td>" + data[i].name + "</td>");
                            return wrapper;
                        I’d like to note, this is all completely new to me, so I’m trying to learn as I go…
                          @strawberry-3-141 I saw you were online, so I’m shamelessly tagging you in my post in the hopes of some guidance :-(
                          • strawberry 3.141S Offline
                            strawberry 3.141 Project Sponsor Module Developer @Mitchfarino
                            @Mitchfarino
                                var table = document.createElement("table");
                                $.getJSON(this.url,
                                    function (data) {
                                            var row = document.createElement("tr");
                                            var name = document.createElement("td");
                                            name.innerHTML = data[i].name;
                                            row.appendChild(name);
                                            table.appendChild(row);
                                        wrapper.appendChild(table);
                                        return wrapper;
                            but I’m pretty sure that this will not work, because the return is in an asynchronous callback, i would do a different structure call your url in an interval somewhere else and save your data into an module variable and call the updateDom function after a result, then in getDom you iterate over the data.
                              Mitchfarino Module Developer @strawberry 3.141
                              @strawberry-3.141 Thanks very much, I’ll have a play with it over the weekend and hopefully I get can something working
                              I’ve not done anything like this before really, so just jumping in and seeing what happens :-)
                                @Mitchfarino
                                url: "", //Insert your url here
                                result: false,
                                defaults: {
                                    updateInterval: 30 * 60 * 1000 //Every 30 mins
                                start: function(){
                                    this.getData();
                                    setInterval(()=>{
                                        this.getData();
                                    }, this.config.updateInterval);
                                getDom: function() {
                                    if(this.result){
                                        for (var i = 0; i < this.result.length; i++) {
                                            name.innerHTML = this.result[i].name;
                                    } else {
                                        wrapper.innerHTML = "No data to show!";
                                    return wrapper;
                                getData: function(){
                                    $.getJSON(this.url, (data) => {
                                        this.result = data;
                                        this.updateDom();
                                  @strawberry-3.141 Thanks for this, I’ll see if I can get it working
                                    Mitchfarino Module Developer @Mitchfarino
                                    @strawberry-3-141 once I’ve got some code, how do I test it on my mirror?
                                    Just copy the folder to the modules folder and add it to the config, or is there something else I need to do?
                                      paviro @Mitchfarino
                                      @Mitchfarino no that’s it :)
                                      – The Doctor
                                        Mitchfarino Module Developer @paviro
                                        @paviro Awesome, thank you!
                                        I’m stumbling my way through, hopefully I’ll have something working soon :)
                                          paviro @Mitchfarino
                                          @Mitchfarino good luck! :)
                                          – The Doctor
                                            @paviro Just one more question…
                                            Why would I need to run npm install for some modules?
