    MMM-News
    55 Posts 15 Posters 51.1k Views 14 Watching
      A Former User
      I know there is already newsfeed and MMM-PNews, but I made this for my own purpose and now share with you.
      MMM-News
      MagicMirror module - displaying news articles with News.org API V2
      Features
      • Aggregate headlines from multiple sources at once.
      • Country specific, Category specific, Keyword specific news could be aggregated.
      • Touchable (Clickable) UI supported
      • Can open article page in iFrame and scrollable by touch or autoScroll
      • Controllable by notification
      • Controllable by MMM-TelegramBot
      • Customizable with Template
      Screenshot
      • type:horizontal, touchable:true
        Screenshot
      • type:vertical, touchable:false
        Screenshot
      • detail page is opened
        Screenshot
      • Control by Telegram
        Screenshot
      Details
      [card:eouia/MMM-News]
      cowboysdudeC justjim1220J 2 Replies Last reply Reply Quote 6
      • cowboysdudeC Offline
        cowboysdude Module Developer @Guest
        @sean That is FANTASTIC!! Nice job!
        • justjim1220J Offline
          justjim1220 Module Developer @Guest
          @sean Nice Work Sean!!
          "Life's Too Short To Dance With Ugly People"
          Jim Hallock - 1995
            A Former User
            UPDATED
            • Added : Reader mode. article details without adv. or any other annoying things.
            Screenshot
              mrdenmark
              does anyone know if BBC is a compatible source for this module?
              it works as advertised with all other news sources i’m interested in but from the bbc it receives nothing.
              if for some reason the bbc can’t be used what other british sources of news/sport are people using?
                A Former User @mrdenmark
                @mrdenmark
                use bbc-news as source.
                  dankerthrone
                  Hey, I’m getting this error message:
                  [NEWS] Error :  https://newsapi.org/v2/top-headlines?pageSize=20&apiKey=XXX result.code:Required parameters are missing. Please set any of the following parameters and try again: sources, q, language, country, category.
                  although I think have that configured correctly:
                  			module: "MMM-News",
                  			position: "bottom_right",
                  					apiKey : "XXX",
                  					type: "vertical",
                  					query : [
                  							language: "de"
                  					items: 20,
                  					timeFormat: "relative",
                  					endpoint :  "https://newsapi.org/v2/top-headlines",
                  					scanInterval: 1000*60*10, // This will be automatically recalculated by number of queries to avoid query quota limit. This could be minimum interval.
                  					templateFile: "template.html"
                  Any help is greatly appreciated :)
                    A Former User @dankerthrone
                    @dankerthrone
                    change language to country
                    • uros76U Offline
                      uros76
                      Hi. Is it possible to have two different queries of news, each displayed in a separate horizontal position?
                        cowboysdude Module Developer @uros76
                        @uros76 sure it is… see picture below…
                        Just using the stock newsfeed in MM…[I DETEST CNN but needed a quick example]
                        You can then use them in the same region or put one each in different regions.
                        The example is both using bottom_bar but I did try and put one in bottom_bar the other in middle_center and still works… ;)
                        [Just remember IF you copy the below code and put it in your config.js it will give you an error… you have to change the quotes “” or ‘’ because they do NOT copy correctly].
                        			module: 'newsfeed',
                        			position: 'bottom_bar',
                        				feeds: [
                        						title: "CNN",
                        						url: "http://rss.cnn.com/rss/cnn_latest.rss"
                        				showSourceTitle: true,
                        				showPublishDate: true
                        			module: 'newsfeed',
                        				feeds: [
                        						title: "New York Times",
                        • 1 / 6
