    MMM-News
    55 Posts 15 Posters 51.7k Views 14 Watching
      A Former User
      UPDATED
      • Added : Reader mode. article details without adv. or any other annoying things.
      Screenshot
        mrdenmark
        does anyone know if BBC is a compatible source for this module?
        it works as advertised with all other news sources i’m interested in but from the bbc it receives nothing.
        if for some reason the bbc can’t be used what other british sources of news/sport are people using?
          A Former User @mrdenmark
          @mrdenmark
          use bbc-news as source.
            dankerthrone
            Hey, I’m getting this error message:
            [NEWS] Error :  https://newsapi.org/v2/top-headlines?pageSize=20&apiKey=XXX result.code:Required parameters are missing. Please set any of the following parameters and try again: sources, q, language, country, category.
            although I think have that configured correctly:
            			module: "MMM-News",
            			position: "bottom_right",
            					apiKey : "XXX",
            					type: "vertical",
            					query : [
            							language: "de"
            					items: 20,
            					timeFormat: "relative",
            					endpoint :  "https://newsapi.org/v2/top-headlines",
            					scanInterval: 1000*60*10, // This will be automatically recalculated by number of queries to avoid query quota limit. This could be minimum interval.
            					templateFile: "template.html"
            Any help is greatly appreciated :)
              A Former User @dankerthrone
              @dankerthrone
              change language to country
              • uros76U Offline
                uros76
                Hi. Is it possible to have two different queries of news, each displayed in a separate horizontal position?
                • cowboysdudeC Offline
                  cowboysdude Module Developer @uros76
                  @uros76 sure it is… see picture below…
                  Just using the stock newsfeed in MM…[I DETEST CNN but needed a quick example]
                  You can then use them in the same region or put one each in different regions.
                  The example is both using bottom_bar but I did try and put one in bottom_bar the other in middle_center and still works… ;)
                  [Just remember IF you copy the below code and put it in your config.js it will give you an error… you have to change the quotes “” or ‘’ because they do NOT copy correctly].
                  			module: 'newsfeed',
                  			position: 'bottom_bar',
                  				feeds: [
                  						title: "CNN",
                  						url: "http://rss.cnn.com/rss/cnn_latest.rss"
                  				showSourceTitle: true,
                  				showPublishDate: true
                  			module: 'newsfeed',
                  				feeds: [
                  						title: "New York Times",
                  • uros76U Offline
                    uros76
                    Thanks @cowboysdude for the tips. I was more thinking of having two instances of MMM-News module because I like its ability to show a small pic. But multiple uses of MMM-News doesn’t seem to work :/.
                    Instead, I combined two modules and now have two different feeds working, the second one just without a picture.
                      @uros76 said in MMM-News:
                      MMM-News
                      Oh I see. I don’t have an api key for that so I can’t really test that one ;) I know you’re setup is not what you wanted but not really sure why running 2 of them is not working without being able to test it.
                      Here’s an idea… setup up 2 of them again and when you run your mirror run it in ‘npm start dev’ mode and see if you get any errors in the console.
                        A Former User
                        not so easy.
                        MM legacy structure doesn’t consider multiple instances of node_helper. One module should have just one node_helper and vice versa. So, the cloning instance of the module needs some manual fixing. Some simple modules could be clonable easily(like the original newsfeed module), but not this module’s case.
                        Another point is, to get news individually through cloned modules(If you’ve done somehow), it will consume system resources twice. and API quota also will be consumed doubly. Hmmm. it is not so beautiful.
                        A reasonable approach would be, Making a serving-slave process(which access the news API) by spawn/fork from one node_helper of the module. then other cloned modules would connect to the slave to get their own needs.
                        Or make another front-end module, which would just pull data from the original module.
                        Anyway, I didn’t make this module for that purpose. And under the current MM structure, to do so is not so easy.
                        Finally, I’m not supporting this module anymore. So, sorry. not possible by me.
                        • 1 / 6
