    MMM-PC-Stats
    41 Posts 3 Posters 23.6k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @justjim1220
      @justjim1220
      Well maybe your board doesn’t have temp sensors. Try this: Type sensor in a terminal window
        Mykle1 Project Sponsor Module Developer @Mykle1
        @mykle1
        sensors
        justjim1220J 2 Replies Last reply Reply Quote 0
        • justjim1220J Offline
          justjim1220 Module Developer @Mykle1
          @mykle1
          {cpu: {…}, ram: {…}}cpu: {name: "AMD Turion(tm) 64 X2 Mobile Technology TL-58", threads: Array(2)}ram: {free: "1.27", total: "3.87", unit: "GB"}__proto__: Object
          MMM-PC-Stats.js:126 Uncaught (in promise) TypeError: Cannot read property 'ISA adapter' of undefined
              at Class.getDom (MMM-PC-Stats.js:126)
              at main.js:110
              at new Promise (<anonymous>)
              at updateDom (main.js:109)
              at Object.updateDom (main.js:514)
              at Class.updateDom (module.js:358)
              at Class.socketNotificationReceived (MMM-PC-Stats.js:262)
              at module.js:246
              at r.<anonymous> (socketclient.js:25)
              at r.emit (index.js:83)
          getDom @ MMM-PC-Stats.js:126
          (anonymous) @ main.js:110
          updateDom @ main.js:109
          updateDom @ main.js:514
          updateDom @ module.js:358
          socketNotificationReceived @ MMM-PC-Stats.js:262
          (anonymous) @ module.js:246
          (anonymous) @ socketclient.js:25
          r.emit @ index.js:83
          r.onevent @ index.js:83
          MMSocket.self.socket.onevent @ socketclient.js:19
          r.onpacket @ index.js:83
          (anonymous) @ index.js:83
          r.ondecoded @ index.js:83
          a.add @ index.js:83
          r.ondata @ index.js:83
          r.onPacket @ index.js:83
          r.onData @ index.js:83
          ws.onmessage @ index.js:83
          Jim Hallock - 1995
            @justjim1220
            Can you open the threads array?
              @mykle1
              jim@jim-Aspire-4520:~$ sensors
              Command 'sensors' not found, but can be installed with:
              sudo apt install lm-sensors
              Jim Hallock - 1995
                @justjim1220
                YOu installed the dependencie?
                justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
                  @mykle1
                  Yeppers.
                  How do I open the threads array?
                  I can reinstall the dependencies if you want me to
                  Jim Hallock - 1995
                    @mykle1
                    Comment out console.log(this.Stats) so you only get the sensors output
                      @mykle1 ok
                      Jim Hallock - 1995
                        @justjim1220
                        Take a screenshot of just the output, not the whole screen. I might be able to see it then
                          pop@HPEu:~/MagicMirror$ sensors
                          nouveau-pci-0100
                          Adapter: PCI adapter
                          fan1:        1110 RPM
                          temp1:        +39.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                                 (crit = +105.0°C, hyst =  +5.0°C)
                                                 (emerg = +135.0°C, hyst =  +5.0°C)
                          coretemp-isa-0000
                          Adapter: ISA adapter
                          Core 0:       +29.0°C  (high = +83.0°C, crit = +99.0°C)
                          Core 1:       +30.0°C  (high = +83.0°C, crit = +99.0°C)
                          Core 2:       +29.0°C  (high = +83.0°C, crit = +99.0°C)
                          Core 3:       +28.0°C  (high = +83.0°C, crit = +99.0°C)
                          f71858fg-isa-0a00
                          +3.3V:        +3.31 V
                          3VSB:         +3.31 V
                          Vbat:         +3.20 V
                          fan1:        1910 RPM
                          fan2:         998 RPM
                          fan3:           0 RPM  ALARM
                          temp1:        +29.2°C  (high = +70.0°C, hyst = +60.0°C)
                          temp2:        +15.4°C  (high = +100.0°C, hyst = +85.0°C)
                          temp3:        +32.5°C  (high = +100.0°C, hyst = +85.0°C)
                          pop@HPEu:~/MagicMirror$ ^C
                            @mykle1
                            Objectacpitz-virtual-0: {Virtual device: {…}}k8temp-pci-00c3: {PCI adapter: {…}}nouveau-pci-0090: {PCI adapter: {…}}__proto__: Object
                            moment-timezone-with-data.js:481 Moment Timezone has no data for American/Chicago. See http://momentjs.com/timezone/docs/#/data-loading/.
                            logError @ moment-timezone-with-data.js:481
                                at main.js:110
                                at module.js:246
                                at main.js:110
                                at Class.socketNotificationReceived (MMM-PC-Stats.js:268)
                                at module.js:246
                            Jim Hallock - 1995
                              @mykle1
                              jim@jim-Aspire-4520:~/MagicMirror$ sensors
                              k8temp-pci-00c3
                              Core0 Temp:   +69.0°C
                              Core0 Temp:   +67.0°C
                              Core1 Temp:   +69.0°C
                              Core1 Temp:   +68.0°C
                              acpitz-virtual-0
                              Adapter: Virtual device
                              temp1:        +71.0°C  (crit = +100.0°C)
                              nouveau-pci-0090
                              GPU core:     +1.20 V  (min =  +1.00 V, max =  +1.20 V)
                              temp1:        +64.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                                     (crit = +105.0°C, hyst =  +2.0°C)
                              Jim Hallock - 1995
                                @justjim1220
                                Ok, I see it. In dev tools you can expand the output to see the tree
                                  @mykle1
                                  there is a lot of things to expand, how much do you need?
                                  Objectacpitz-virtual-0: Virtual device: temp1: name: "temp1"type: "temperature"value: 80__proto__: Objectconstructor: ƒ Object()arguments: (...)assign: ƒ assign()caller: (...)create: ƒ create()defineProperties: ƒ defineProperties()defineProperty: ƒ defineProperty()entries: ƒ entries()freeze: ƒ freeze()getOwnPropertyDescriptor: ƒ getOwnPropertyDescriptor()getOwnPropertyDescriptors: ƒ getOwnPropertyDescriptors()getOwnPropertyNames: ƒ getOwnPropertyNames()getOwnPropertySymbols: ƒ getOwnPropertySymbols()getPrototypeOf: ƒ getPrototypeOf()is: ƒ is()isExtensible: ƒ isExtensible()isFrozen: ƒ isFrozen()isSealed: ƒ isSealed()keys: ƒ keys()length: 1name: "Object"preventExtensions: ƒ preventExtensions()prototype: {constructor: ƒ, __defineGetter__: ƒ, __defineSetter__: ƒ, hasOwnProperty: ƒ, __lookupGetter__: ƒ, …}seal: ƒ seal()setPrototypeOf: ƒ setPrototypeOf()values: ƒ values()__proto__: ƒ ()[[FunctionLocation]]: <unknown>hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectk8temp-pci-00c3: PCI adapter: __proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()nouveau-pci-0090: PCI adapter: {GPU core: {…}, temp1: {…}}__proto__: Object__proto__: constructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()
                                  Jim Hallock - 1995
                                    @mykle1
                                    It looks like this is the line it is having a problem with…
                                        var core0TempCheck = Sensors["coretemp-isa-0000"]['ISA adapter']['Core 0'];
                                    particularly with: [‘ISA adapter’]
                                    Jim Hallock - 1995
                                      @justjim1220
                                      I know the line that is the problem. Listen, I’m tired. If you’ll let me TeamViewer into your machine tomorrow I’ll fix it. Doing it this way is very tedious
                                        @mykle1
                                        Absolutely.
                                        No Problem.
                                        Just let me know when.
                                        Jim Hallock - 1995
                                          is there something I need to set up on this end for TeamViewer?
                                          Jim Hallock - 1995
                                            @mykle1
                                            And, your gonna have to let me know how to do a screen shot of just a certain part of the screen, or how to crop the image. A lot different than Windows.
                                            Jim Hallock - 1995
                                            • 2 / 3
