    MMM-PC-Stats
    41 Posts 3 Posters 22.2k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @justjim1220
      @justjim1220
      Can you open the threads array?
      • justjim1220J Offline
        justjim1220 Module Developer @Mykle1
        @mykle1
        jim@jim-Aspire-4520:~$ sensors
        Command 'sensors' not found, but can be installed with:
        sudo apt install lm-sensors
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          @justjim1220
          YOu installed the dependencie?
          justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
            @mykle1
            Yeppers.
            How do I open the threads array?
            I can reinstall the dependencies if you want me to
            Jim Hallock - 1995
              Mykle1 Project Sponsor Module Developer @Mykle1
              @mykle1
              Comment out console.log(this.Stats) so you only get the sensors output
                @mykle1 ok
                Jim Hallock - 1995
                  @justjim1220
                  Take a screenshot of just the output, not the whole screen. I might be able to see it then
                    pop@HPEu:~/MagicMirror$ sensors
                    nouveau-pci-0100
                    Adapter: PCI adapter
                    fan1:        1110 RPM
                    temp1:        +39.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                           (crit = +105.0°C, hyst =  +5.0°C)
                                           (emerg = +135.0°C, hyst =  +5.0°C)
                    coretemp-isa-0000
                    Adapter: ISA adapter
                    Core 0:       +29.0°C  (high = +83.0°C, crit = +99.0°C)
                    Core 1:       +30.0°C  (high = +83.0°C, crit = +99.0°C)
                    Core 2:       +29.0°C  (high = +83.0°C, crit = +99.0°C)
                    Core 3:       +28.0°C  (high = +83.0°C, crit = +99.0°C)
                    f71858fg-isa-0a00
                    +3.3V:        +3.31 V
                    3VSB:         +3.31 V
                    Vbat:         +3.20 V
                    fan1:        1910 RPM
                    fan2:         998 RPM
                    fan3:           0 RPM  ALARM
                    temp1:        +29.2°C  (high = +70.0°C, hyst = +60.0°C)
                    temp2:        +15.4°C  (high = +100.0°C, hyst = +85.0°C)
                    temp3:        +32.5°C  (high = +100.0°C, hyst = +85.0°C)
                    pop@HPEu:~/MagicMirror$ ^C
                    justjim1220J 2 Replies Last reply Reply Quote 0
                      @mykle1
                      Objectacpitz-virtual-0: {Virtual device: {…}}k8temp-pci-00c3: {PCI adapter: {…}}nouveau-pci-0090: {PCI adapter: {…}}__proto__: Object
                      moment-timezone-with-data.js:481 Moment Timezone has no data for American/Chicago. See http://momentjs.com/timezone/docs/#/data-loading/.
                      logError @ moment-timezone-with-data.js:481
                      MMM-PC-Stats.js:126 Uncaught (in promise) TypeError: Cannot read property 'ISA adapter' of undefined
                          at Class.getDom (MMM-PC-Stats.js:126)
                          at main.js:110
                          at new Promise (<anonymous>)
                          at updateDom (main.js:109)
                          at Object.updateDom (main.js:514)
                          at Class.updateDom (module.js:358)
                          at Class.socketNotificationReceived (MMM-PC-Stats.js:262)
                          at module.js:246
                          at r.<anonymous> (socketclient.js:25)
                          at r.emit (index.js:83)
                          at main.js:110
                          at Class.socketNotificationReceived (MMM-PC-Stats.js:268)
                          at module.js:246
                      Jim Hallock - 1995
                        @mykle1
                        jim@jim-Aspire-4520:~/MagicMirror$ sensors
                        k8temp-pci-00c3
                        Core0 Temp:   +69.0°C
                        Core0 Temp:   +67.0°C
                        Core1 Temp:   +69.0°C
                        Core1 Temp:   +68.0°C
                        acpitz-virtual-0
                        Adapter: Virtual device
                        temp1:        +71.0°C  (crit = +100.0°C)
                        nouveau-pci-0090
                        GPU core:     +1.20 V  (min =  +1.00 V, max =  +1.20 V)
                        temp1:        +64.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                               (crit = +105.0°C, hyst =  +2.0°C)
                        Jim Hallock - 1995
                          @justjim1220
                          Ok, I see it. In dev tools you can expand the output to see the tree
                            @mykle1
                            there is a lot of things to expand, how much do you need?
                            Objectacpitz-virtual-0: Virtual device: temp1: name: "temp1"type: "temperature"value: 80__proto__: Objectconstructor: ƒ Object()arguments: (...)assign: ƒ assign()caller: (...)create: ƒ create()defineProperties: ƒ defineProperties()defineProperty: ƒ defineProperty()entries: ƒ entries()freeze: ƒ freeze()getOwnPropertyDescriptor: ƒ getOwnPropertyDescriptor()getOwnPropertyDescriptors: ƒ getOwnPropertyDescriptors()getOwnPropertyNames: ƒ getOwnPropertyNames()getOwnPropertySymbols: ƒ getOwnPropertySymbols()getPrototypeOf: ƒ getPrototypeOf()is: ƒ is()isExtensible: ƒ isExtensible()isFrozen: ƒ isFrozen()isSealed: ƒ isSealed()keys: ƒ keys()length: 1name: "Object"preventExtensions: ƒ preventExtensions()prototype: {constructor: ƒ, __defineGetter__: ƒ, __defineSetter__: ƒ, hasOwnProperty: ƒ, __lookupGetter__: ƒ, …}seal: ƒ seal()setPrototypeOf: ƒ setPrototypeOf()values: ƒ values()__proto__: ƒ ()[[FunctionLocation]]: <unknown>hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectk8temp-pci-00c3: PCI adapter: __proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()__proto__: Objectconstructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()nouveau-pci-0090: PCI adapter: {GPU core: {…}, temp1: {…}}__proto__: Object__proto__: constructor: ƒ Object()hasOwnProperty: ƒ hasOwnProperty()isPrototypeOf: ƒ isPrototypeOf()propertyIsEnumerable: ƒ propertyIsEnumerable()toLocaleString: ƒ toLocaleString()toString: ƒ toString()valueOf: ƒ valueOf()__defineGetter__: ƒ __defineGetter__()__defineSetter__: ƒ __defineSetter__()__lookupGetter__: ƒ __lookupGetter__()__lookupSetter__: ƒ __lookupSetter__()get __proto__: ƒ __proto__()set __proto__: ƒ __proto__()
                            Jim Hallock - 1995
                              @mykle1
                              It looks like this is the line it is having a problem with…
                                  var core0TempCheck = Sensors["coretemp-isa-0000"]['ISA adapter']['Core 0'];
                              particularly with: [‘ISA adapter’]
                              Jim Hallock - 1995
                                @justjim1220
                                I know the line that is the problem. Listen, I’m tired. If you’ll let me TeamViewer into your machine tomorrow I’ll fix it. Doing it this way is very tedious
                                  @mykle1
                                  Absolutely.
                                  No Problem.
                                  Just let me know when.
                                  Jim Hallock - 1995
                                    is there something I need to set up on this end for TeamViewer?
                                    Jim Hallock - 1995
                                      @mykle1
                                      And, your gonna have to let me know how to do a screen shot of just a certain part of the screen, or how to crop the image. A lot different than Windows.
                                      Jim Hallock - 1995
                                        @justjim1220
                                        This is what you need to change in the main js
                                        		// Check if core0 has temp sensor
                                                var core0TempCheck = Sensors["acpitz-virtual-0"]; // ['ISA adapter']['Core 0'];
                                        		if (typeof core0TempCheck !== 'undefined'){
                                                var core0Temp = document.createElement("div");
                                                core0Temp.classList.add("small", "bright", "core0Temp");
                                                core0Temp.innerHTML = Sensors["acpitz-virtual-0"]["Virtual device"].temp1.value + " &nbsp  @  &nbsp "
                                        						    + Sensors["acpitz-virtual-0"]["Virtual device"].temp1.value + "&deg;C";
                                                wrapper.appendChild(core0Temp);
                                                // ["acpitz-virtual-0"]["Virtual device"].temp1.value
                                        		// Check if core1 has temp sensor
                                                var core1TempCheck = Sensors["acpitz-virtual-0"]; // ['ISA adapter']['Core 1'];
                                        		if (typeof core1TempCheck !== 'undefined'){
                                                var core1Temp = document.createElement("div");
                                                core1Temp.classList.add("small", "bright", "core1Temp");
                                                core1Temp.innerHTML = Sensors["acpitz-virtual-0"]["Virtual device"].temp2.value + " &nbsp  @  &nbsp "
                                        						    + Sensors["acpitz-virtual-0"]["Virtual device"].temp2.value + "&deg;C";
                                                wrapper.appendChild(core1Temp);
                                          Now leave me alone. I’m going to bed. :-)
                                          justjim1220J 4 Replies Last reply Reply Quote 0
                                            @mykle1 ok
                                            Jim Hallock - 1995
                                            • 2 / 3
