    Change newsfeed title to image/logo?
    58 Posts 7 Posters 42.6k Views 7 Watching
    • E
      electros Project Sponsor @blueadam
      @blueadam yes, now everything is fine. thank you
      • justjim1220J
        justjim1220 Module Developer @blueadam
        @blueadam @cyberphox @electros
        MMM-NewsFeedTicker
        Yes! I now have the scrolling newsfeed with logo that will change for more than 1 newsfeed!!! :smiling_face_with_sunglasses:
        Thanks to @sdetweil and @Sean for helping me along and learning me!
        Jim Hallock - 1995
          StrIIker @justjim1220
          @justjim1220
          I love this News Ticker. Can I ask how I can change the size of the ticker? My mirror is in Portrait mode and the font feels oversized. I would prefer 40-50% of the current release size which would also allow the full headline to show. Also, can you include an opacity value for the background? I like the maroon but would prefer it to be less intense. I am sure these could be handled via the custom.css but I am a novice with this all. Thank you again for a great module!
          justjim1220J 1 Reply Last reply
          • justjim1220J
            justjim1220 Module Developer @StrIIker
            @striiker
            Add this to custom.css, Make the changes you want in it…
            .MMM-NewsFeedTicker {
                height: 100px;
                background-color: maroon;
                opacity: 1.0;
            .MMM-NewsFeedTicker .headline {
                padding-top: 15px;
                font-size: 100%;
            .MMM-NewsFeedTicker .image {
              height: 100px;
              background-color: #FFF;
            Let me know if you have any problems with this.
            I am glad that you like it! :smiling_face_with_sunglasses:
            Jim Hallock - 1995
            S 2 Replies Last reply
              cyberphox
              Ok so to remove the old one and install this, let’s review the steps! :)
              Anyone…??
                StrIIker @cyberphox
                @cyberphox said in Change newsfeed title to image/logo?:
                Anyone…??
                Sure! I assume this is what you want…
                Refer to: https://github.com/justjim1220/MMM-NewsFeedTicker for the full install details etc.
                Install new news ticker:
                Log into your Raspberry Pi as pi and:
                cd ~/MagicMirror/modules
                git clone https://github.com/justjim1220/MMM-NewsFeedTicker.git
                This installs the requisite module into the correct directory.
                Remove old news and enable new news
                The nice thing with this is that enabling or disabling modules is done simply by adding or deleting entries in the config.js file. The only catch is that it’s touchy with proper syntax so make sure you aren’t missing something simple (like a trailing comma or a misplaced ‘}’ or ‘{’. I suggest backing up your current config.js so that you can revert to it if needed. This is generally a good policy when modifying any config files. To check your config for errors, reference the following article:
                https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners/2
                So, onto making that backup copy…
                cd ~/MagicMirror/config
                cp config.js config.bak01
                Increment the trailing number if you want to retain multiple backup copies. If you make a mistake and want to start over, copy the backup to overwrite the current version of config.js…
                cp config.bak01 config.js
                Now edit the config file…
                nano config.js
                To disable the default news reader, delete the following: (you may have additional feeds if you added anything).
                			"module": "newsfeed",
                			"position": "bottom_bar",
                			"config": {
                				"feeds": [
                						"title": "New York Times",
                						"url": "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                				"showSourceTitle": true,
                				"showPublishDate": true
                Now to add the new feed, add the following somewhere in the config (maybe where the old new feed was?) You can customize this by adding or removing news sources based upon what interests you.
                	disabled: false,
                	module: "MMM-NewsFeedTicker",
                	position: "bottom_bar",
                	//classes: "day_scheduler",
                	    feeds: [
                			title: "New York Times",
                			url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                			encoding: "UTF-8", //ISO-8859-1
                			className: "myClass",
                			defaultLogo : ""
                			title: "USA Today",
                			url: "http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories",
                			defaultLogo : ""
                			title: "BBC World News",
                			url: "http://feeds.bbci.co.uk/news/world/rss.xml#",
                			defaultLogo : ""
                Now you can reload the MagicMirror via Ctrl-R (I find that the system automatically reloads the module once it detects a changed config.js). You should see the new news feed at the bottom.
                  cyberphox
                  Got lots of config errors copying that…weird…
                  Checking file… /home/pi/MagicMirror/config/config.js
                  Line 192 col 1 Expected ‘}’ to match ‘{’ from line 160 and instead saw ‘]’.
                  Line 193 col 2 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘}’.
                  Line 193 col 3 Expected ‘}’ to match ‘{’ from line 11 and instead saw ‘;’.
                  Line 193 col 4 Missing semicolon.
                  Had to add an extra close bracket }
                    StrIIker @cyberphox
                    @cyberphox
                    Yeah, I have spent a lot of time trying to figure out where I was missing something… Generally it was a missing comma at the end of a config line which had additional content following it or misplacing the { or }.
                    Also, the modules are loaded in order as they appear in the config so if you want a couple of things in the top left (denoted by the location parameter “position”: “top_left”, the first module will be the top left and the second module read would be just below that.
                      cyberphox
                      I have it working now after adding the extra bracket, but as stated above its’ a little big for portrait mode…it’s running a bit sluggish but i expect thats more of a raspberry pi issue…changing the font % in custom.css didnt seem to shrink it any for me
                      • justjim1220J
                        @StrIIker
                        @cyberphox
                        My Apologies for the issues you are having, but, I am looking over the code to make these fixes and I am not seeing any of the problems you are describing…
                        Any way you could show me the specific places these errors are occurring?
                        I ran it through an error checker and it’s not finding any errors…
                        Jim Hallock - 1995
                        C S 2 Replies Last reply
                          cyberphox @justjim1220
                          @justjim1220 My apologies to you! The module is working just fine for me now…took a little tinkering but I got it.
                          The only issue I’m having now is re-sizing and maybe getting it to run a little smoother (again that might be a limitation of the Pi) Can’t seem to get a full headline in before it switches…but I’ll mess around with it
                          Great module…thanks for your work
                          Mykle1M justjim1220J 2 Replies Last reply
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @cyberphox
                            It is
                            C 1 Reply Last reply
                            Reply Quote 3
                            • justjim1220J
                              justjim1220 Module Developer @cyberphox
                              @cyberphox
                              Thanks!
                              Glad you like it.
                              What did you have to tinker with to get it working?
                              Jim Hallock - 1995
                                cyberphox @Mykle1
                                @mykle1 I have a Synology NAS running Docker…I really need to learn how to install this all in a docker package and edit it and run it from the Server…
                                Mykle1M 1 Reply Last reply
                                  @justjim1220 Literally I was just missing a } after copying and pasting somehow…
                                    @justjim1220 said in Change newsfeed title to image/logo?:
                                    @striiker
                                        height: 100px;
                                        opacity: 1.0;
                                        padding-top: 15px;
                                        font-size: 100%;
                                      height: 100px;
                                    I added the lines to the custom.css and adjusted as follows. I still see the scrolling text as full size / cut off (screenshot of section included…
                                        height: 50px;
                                        opacity: 0.5;
                                        padding-top: 15px;
                                        font-size: 50%;
                                      height: 50px;
                                    C justjim1220J 2 Replies Last reply
                                      @StrIIker
                                      @cyberphox
                                      Th example config on your git page is missing a trailing ‘}’ This is why people have had issues adding to their config.js
                                        cyberphox @StrIIker
                                        @striiker
                                        Same issue here
                                        • justjim1220J
                                          @striiker
                                          Another apology…
                                          When I was working with this module I had the font set to xlarge or large in the MMM-NewsFeedTicker.js file.
                                          It makes it easier for these old eyes to see changes,
                                          So, in the following section of the js file…
                                           var headline = document.createElement("span");
                                                          headline.setAttribute("style", "padding-bottom:25px");
                                                          headline.className = "bold xlarge bright";
                                                          headline.innerHTML = "<font color= #ffaa00>" + moment(new Date(this.newsItems[this.activeItem].pubdate)).fromNow() + ": &nbsp;" + "</font>" + this.newsItems[this.activeItem].title + "&nbsp; || &nbsp;" + this.newsItems[this.activeItem].description;
                                                          tickerBody.appendChild(headline);
                                          Change the ‘xlarge’ to small
                                          Jim Hallock - 1995
                                          Reply Quote 2
                                            cyberphox @StrIIker
                                            @striiker That’s the config issue i was having and solved it with the }
                                            • 2 / 3
