    Change newsfeed title to image/logo?
    58 Posts 7 Posters 42.6k Views 7 Watching
      A Former User @blueadam
      @blueadam
      I think this would be what @justjim1220 really typed;
        blueadam
        Yeah, with those changes newsfeed module came back but it still looks exactly the same that it was, so there isn’t that logo that I’m using
        EDIT
        showDescription was set to false and when I changed it to true all changes started to work but now I have another problem. Now there is the original headline and the new one so there are two headlines at the same time.
        EDIT 2.0
        Finally it works! I had to change the newsfeed.js code a little bit and had to change some true values to false from config.js. Also, I decided to move the module to bottom_left. After all changes the final result looks like this. I’m about to make second news module right below this one after this one.
        E 1 Reply Last reply
          cyberphox @justjim1220
          @justjim1220 I was just about to say that! lol
          justjim1220J 1 Reply Last reply
          • justjim1220J
            justjim1220 Module Developer @cyberphox
            @cyberphox @blueadam @Sean
            I see that I didn’t notice the changes that the forums made when I copy/pasted the code.
            Apologies!
            I also missed a step: Need to add getStyles function to the newsfeed.js Pic for placement
            And this is what I tried to post and the forums didn’t like it and cahnged it, This is what you need to get it to work:
            I will fix this in my original post.
            Again, Apologies!
            Jim Hallock - 1995
            • justjim1220J
              here it is with the New York Times…
              Jim Hallock - 1995
              C 1 Reply Last reply
                @justjim1220 figure out multiple feeds and logos yet? LOL
                justjim1220J 2 Replies Last reply
                • justjim1220J
                  @cyberphox
                  Working on it!!! :smiling_face_with_sunglasses:
                  Jim Hallock - 1995
                  • justjim1220J
                    @cyberphox
                    Did you get your to work?
                    Apologies for the mistakes posted by forums.
                    Jim Hallock - 1995
                    • E
                      electros Project Sponsor @blueadam
                      @blueadam can you tell me please how i can make to look like this ?
                      And please tell me, who know of course the picture logo must have a specific dimensions like no big then… ?
                      ? 1 Reply Last reply
                        A Former User @electros
                        @electros
                        See ‘max-width’, and ‘max-height’ or you can use ‘background-position:contain’ as backfroundimage to adjust image size
                        • E
                          electros Project Sponsor @Guest
                          @sean
                          Thanks I thought it was because the logo image is too big so it does not display it. Now I have solved, the logo is displayed, but I have the same problem as @blueadam, which means I have the newsfeed 2 times the old version and the new version. And I’ve tried many variants, but I can not make the old one disappear.
                          That’s why I ask @blueadam to tell me how he got rid of the old one.
                            blueadam
                            @electros
                            I’ll try my best to explain how I managed to get rid of the old one. Also I made all of these changes to code before @justjim1220 posted updated version of the code so I don’t guarantee it will work with those changes but you can give a try.
                            So, what I noticed is that part of the code in newsfeed.js file that we fixed was the description part. I spent some time staring at mine MagicMirror and I noticed that those news titles won’t show as double. Instead, there is the original one and the second one that we have created which shows the news description, not the title.
                            First I fixed the code that it will show the title instead of the description. In other words change the word ‘description’ to ‘title’.
                            Now we have done that there are two titles like you said. To understand why this is happening let’s go through the newsfeed.js code to understand why this is happening.
                            1. orginal part of the code which prints the title
                            2. first part of the new code which prints the logo and the timer
                            3. second part of the new code which prints the scrolling headline.
                            The scrolling effect is quite cool but unfortunately it won’t fit to my Magic Mirror lay out so I decided to remove that part of the code. For that reason I removed this part of the code.
                            Next thing we notice that the title is coming before our logo and timer. That is why we have to move new part of the code above the old one.
                            Now there is just one fault left which is that now there is our new logo + timer and the old text title + timer. To ‘remove’ the old one go to the config.js file and find the newsfeed module. Over there you can change showSourceTitle and showPublishDate values from ‘true’ to ‘false’. After that all should be working perfect.
                            I hope that helped you even a little.
                            justjim1220J E 2 Replies Last reply
                            • justjim1220J
                              justjim1220 Module Developer @blueadam
                              @blueadam
                              Cool, I have mine to show the title and description so I can at least see what the headline is and a brief description.
                              Just didn’t include that in the sample.
                              If you cahnge everything to false except what you are wanting to show, it will fix the double posting of the date. As I had it set to only show the description since everything is under that code snippet.
                              Still working on having more than one newsfeed with the logo images.
                              Thanks!
                              Jim Hallock - 1995
                              • E
                                @blueadam yes, now everything is fine. thank you
                                • justjim1220J
                                  @blueadam @cyberphox @electros
                                  MMM-NewsFeedTicker
                                  Yes! I now have the scrolling newsfeed with logo that will change for more than 1 newsfeed!!! :smiling_face_with_sunglasses:
                                  Thanks to @sdetweil and @Sean for helping me along and learning me!
                                  Jim Hallock - 1995
                                    StrIIker @justjim1220
                                    @justjim1220
                                    I love this News Ticker. Can I ask how I can change the size of the ticker? My mirror is in Portrait mode and the font feels oversized. I would prefer 40-50% of the current release size which would also allow the full headline to show. Also, can you include an opacity value for the background? I like the maroon but would prefer it to be less intense. I am sure these could be handled via the custom.css but I am a novice with this all. Thank you again for a great module!
                                    • justjim1220J
                                      justjim1220 Module Developer @StrIIker
                                      @striiker
                                      Add this to custom.css, Make the changes you want in it…
                                      .MMM-NewsFeedTicker {
                                          height: 100px;
                                          background-color: maroon;
                                          opacity: 1.0;
                                      .MMM-NewsFeedTicker .headline {
                                          padding-top: 15px;
                                          font-size: 100%;
                                      .MMM-NewsFeedTicker .image {
                                        height: 100px;
                                        background-color: #FFF;
                                      Let me know if you have any problems with this.
                                      I am glad that you like it! :smiling_face_with_sunglasses:
                                      Jim Hallock - 1995
                                      S 2 Replies Last reply
                                        cyberphox
                                        Ok so to remove the old one and install this, let’s review the steps! :)
                                        Anyone…??
                                          StrIIker @cyberphox
                                          @cyberphox said in Change newsfeed title to image/logo?:
                                          Anyone…??
                                          Sure! I assume this is what you want…
                                          Refer to: https://github.com/justjim1220/MMM-NewsFeedTicker for the full install details etc.
                                          Install new news ticker:
                                          Log into your Raspberry Pi as pi and:
                                          cd ~/MagicMirror/modules
                                          git clone https://github.com/justjim1220/MMM-NewsFeedTicker.git
                                          This installs the requisite module into the correct directory.
                                          Remove old news and enable new news
                                          The nice thing with this is that enabling or disabling modules is done simply by adding or deleting entries in the config.js file. The only catch is that it’s touchy with proper syntax so make sure you aren’t missing something simple (like a trailing comma or a misplaced ‘}’ or ‘{’. I suggest backing up your current config.js so that you can revert to it if needed. This is generally a good policy when modifying any config files. To check your config for errors, reference the following article:
                                          https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners/2
                                          So, onto making that backup copy…
                                          cd ~/MagicMirror/config
                                          cp config.js config.bak01
                                          Increment the trailing number if you want to retain multiple backup copies. If you make a mistake and want to start over, copy the backup to overwrite the current version of config.js…
                                          cp config.bak01 config.js
                                          Now edit the config file…
                                          nano config.js
                                          To disable the default news reader, delete the following: (you may have additional feeds if you added anything).
                                          			"module": "newsfeed",
                                          			"position": "bottom_bar",
                                          			"config": {
                                          				"feeds": [
                                          						"title": "New York Times",
                                          						"url": "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                          				"showSourceTitle": true,
                                          				"showPublishDate": true
                                          Now to add the new feed, add the following somewhere in the config (maybe where the old new feed was?) You can customize this by adding or removing news sources based upon what interests you.
                                          	disabled: false,
                                          	module: "MMM-NewsFeedTicker",
                                          	position: "bottom_bar",
                                          	//classes: "day_scheduler",
                                          	    feeds: [
                                          			title: "New York Times",
                                          			url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                                          			encoding: "UTF-8", //ISO-8859-1
                                          			className: "myClass",
                                          			defaultLogo : ""
                                          			title: "USA Today",
                                          			url: "http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories",
                                          			defaultLogo : ""
                                          			title: "BBC World News",
                                          			url: "http://feeds.bbci.co.uk/news/world/rss.xml#",
                                          			defaultLogo : ""
                                          Now you can reload the MagicMirror via Ctrl-R (I find that the system automatically reloads the module once it detects a changed config.js). You should see the new news feed at the bottom.
                                            cyberphox
                                            Got lots of config errors copying that…weird…
                                            Checking file… /home/pi/MagicMirror/config/config.js
                                            Line 192 col 1 Expected ‘}’ to match ‘{’ from line 160 and instead saw ‘]’.
                                            Line 193 col 2 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘}’.
                                            Line 193 col 3 Expected ‘}’ to match ‘{’ from line 11 and instead saw ‘;’.
                                            Line 193 col 4 Missing semicolon.
                                            Had to add an extra close bracket }
                                            • 2 / 3
