    MMM-BMW-DS (A different kind of weather module)
    65 Posts 13 Posters 63.6k Views 11 Watching
      Minor Update
      **Now with sound support for rain, thunder and wind
      Download:
      [card:mykle1/MMM-BMW-DS]
      Version 1.0.4
      You can use your own mp3 sound files as long as you name them rain.mp3, thunder.mp3 and wind.mp3 and place them in the sounds folder of the module itself.
      git pull or install as per the readme
        i just installed this module, and the default CSS causes the display to take over the entire screen…
        css:1, fixes it… I ‘assume’ the default should be 1?
          @sdetweil said in MMM-BMW-DS (A different kind of weather module):
          Sorry the module is giving you trouble. You should not have a “default.css” file at all. In the css folder of the module there should only be 6 css files, named:
          MMM-BMW-DS1.css
          MMM-BMW-DS2.css
          MMM-BMW-DS3.css
          MMM-BMW-DS4.css
          MMM-BMW-DS5.css
          MMM-BMW-DS6.css
          Maybe the way I implemented this, or documented this, is not very clear. I do apologize for that. If you have a suggestion for cleaning this up I would appreciate that, or if the problem is something else then please assist me in understanding and correcting.
            your readme
              css: "1",                         // 1-6 (default, Clean, Lord of the Rings, Handwriting, etc)
            ok, what is ‘default’?
            ie, the setting if one doesn’t chose anything?
            if I do not supply the line above, what value will be used
            the screen shots show a line at the bottom of the page, so I ASSUME this must be the ‘default’ behavior…
              Ok, I see. I’m off to dinner right now but I will correct that when I return. I’m sorry for the trouble and thank you for pointing that out to me.
                Ok, this is what I’ve done. I don’t know if this is the proper way of doing it but it does work.
                // Gets correct css file from config.js
                    getStyles: function() {
                      if(this.config.css != ""){
                        return ["modules/MMM-BMW-DS/css/MMM-BMW-DS" + this.config.css + ".css"];
                      } else {
                        return ["modules/MMM-BMW-DS/css/MMM-BMW-DS1.css"]; // default.css
                  sdetweil @Mykle1
                  @mykle1 easier if u just declare a defaults section in your module.js which has css: 1
                  The when it is merged with the user supplied config, there will always be something set.
                  Then u don’t need the if/then at all
                    I don’t know how I missed that. Thanks again for showing me the error of my ways. :-)
                    // Module config defaults.
                        defaults: {
                            apiKey: "", // Get FREE API key from darksky.net
                            tempUnits: "C", // C  or F
                            lat: "40.123456", // Latitude
                            lng: "-74.123456", // Longitude
                            css: "1", // 1=default, 2=Clean, 3=Lord of the Rings, 4=handwriting, 5=Julee, 6=Englebert
                            ownTitle: "Current Conditions", // Default = Current Conditions
                            useHeader: false, // true if you want a header
                            header: "Your Header", // Any text you want. useHeader must be true
                            maxWidth: "100%",
                            animationSpeed: 3000,
                            initialLoadDelay: 4250,
                            retryDelay: 2500,
                            updateInterval: 5 * 60 * 1000,
                    • cirdanC Offline
                      cirdan
                      Mykle, kids called me at work today. magic mirror is making weird noises. 😀
                      Afraid for hardware failure I went home only to find out mmmbmwds had added sounds and it rained for the first time.
                      Would you consider building in a config switch to enable/disable sounds?
                      Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
                        Rename the mp3 files to something else
                          Mykle1 Project Sponsor Module Developer @cirdan
                          @cirdan said in MMM-BMW-DS (A different kind of weather module):
                          git pull in the MMM-BMW-DS directory and playSounds: "no" in the new config option. :thumbsup:
                          Why can’t everything I try to do with modules be that easy?
                          cirdanC 1 Reply Last reply Reply Quote 1
                          • cirdanC Offline
                            cirdan @Mykle1
                            @mykle1 tnx for the quick fix.
                            (At last peace returns to the grey havens 😁)
                              RV Knight
                              Hi, sorry about bringing back up this old post. I’m currently having issues with it, it’s displaying in the bottom with acquiring you weather but doesn’t go any further than that. I’ve checked the config as far as I can tell but I’m still having issues, would it be possible to have some help? Thanks
                                Mykle1 Project Sponsor Module Developer @RV Knight
                                @RV-Knight
                                Please post your config entry for MMM-BMW-DS (in a code block) so I can take a look at it for you. It should look something like this:
                                            disabled: false,
                                            module: "MMM-BMW-DS",
                                            position: "bottom_bar",
                                                apiKey: "123456789123456789", // Your api key from darksky.net
                                                tempUnits: "F", // C of F
                                                lat: '42.123456',
                                                lng: '-74.123456',
                                                css: "2",
                                                playSounds: "no",
                                                header: "Your header",
                                                maxWidth: "100%",
                                You can also start your mirror using npm start dev. Click the Console tab in the window that opens (top left) and report any errors (appearing in RED). You may have to scroll
                                  @RV-Knight
                                  Have you made any progress?
                                  • LordyL Offline
                                    Lordy
                                    Great Module, i loved
                                    • LordyL Offline
                                      Lordy
                                      how or where can i enlarge the font and icon?
                                      Wie oder wo kann ich die Schrift und das Symbol vergrößern?
                                      • LordyL Offline
                                        Lordy
                                        thanks, I’ve already found (copy and paste in “custom.css”.
                                          Mykle1 Project Sponsor Module Developer @Lordy
                                          @Lordy said in MMM-BMW-DS (A different kind of weather module):
                                          Glad you found your solution. I post below some of the things you can use in custom.css for anyone that cares.
                                          .MMM-BMW-DS .header {
                                            color: yellow;                 /* Header color. */
                                          .MMM-BMW-DS .image {             /* icon size */
                                             width: 1.75%;
                                             height: 1.75%;
                                             margin-top: 0px;
                                             margin-bottom: -10px;
                                          .MMM-BMW-DS .current {
                                            color: #FFFFFF;               /* Current text forecast color. Default is white. */
                                            font-size: .6em;
                                          .MMM-BMW-DS .summary {
                                            color: #FFFFFF;               /* General summary text forecast color. Default is white. */
                                            font-size: .6em;
                                            display: none;                /* uncomment to hide */
                                          .MMM-BMW-DS .daily {
                                            color: #FFFFFF;               /* Days of the week and hi/lo temp color. Default is white. */
                                            font-size: .6em;
                                            Thank you, mate. :thumbsup:
                                            • 3 / 4
