    Default Calender relative removes start time
    14 Posts 3 Posters 6.9k Views 3 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @cptkex
      @cptkex
      Aha! The “dateheaders” option is quite new and I haven’t seen that before. Will check that out as well
        cptkex @lavolp3
        @lavolp3 I’m home and I was mistaken. It does not show the date when it goes into relative, only the end time. I will try your code later tonight and see if it works.
          cptkex @lavolp3
          @lavolp3 i tried your addition to the code but it only said
          meeting in 5 hoursInvalid Date-1800
          lavolp3L 2 Replies Last reply Reply Quote 0
          • lavolp3L Offline
            • lavolp3L Offline
              @cptkex There is an open issue that might describe the same issue:
              https://github.com/MichMich/MagicMirror/issues/1457
              Yours?
              Else it might be worth following.
                cptkex @lavolp3
                @lavolp3 not mine, but thanks, i will keep an eye on it
                • lavolp3L Offline
                  @cptkex
                  You could try this
                  timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow()) + this.capFirst(moment(event.startDate, "x").format(this.config.dateEndFormat));
                  I took the dirty way to use the dateEndFormat variable for a starting time.
                  This is just a guess! I haven’t tried it out yet…
                  • BKeyportB Offline
                    BKeyport Module Developer
                    because of the ending times, I went 100% absolute. works best on a small screen, too…
                    dateFormat: “M/D h:mm a”,
                    fullDateEventDateFormat: “M/D”,
                    timeFormat: “absolute”,
                    getRelative: 0,
                    urgency: 0,
                    dateEndFormat: “h:mm a”,
                    • lavolp3L Offline
                      lavolp3 Module Developer @BKeyport
                      @bkeyport that’s what I would recommend otherwise as well.
                      I’m using the same config with the timeFormat: ‘dateheaders’ but for some reason I’m missing the ending times…
                      • lavolp3L Offline
                        lavolp3 Module Developer @lavolp3
                        A bit offtopic, sorry, but wanted to write it down:
                        The (quite) new ‘dateheaders’ option is a bit odd.
                        It neglects most of the other options like urgency, today/tomorrow, getrelative, showEnd (i.e. shows only the starting time of an event).
                        I guess it would need to be placed somewhere else in the code and be more integrated.
                          cptkex @lavolp3
                          @lavolp3 thanks i will try it!
