    MMM-NewsFeedTicker
    94 Posts 15 Posters 92.5k Views 14 Watching
    • Cr4z33C
      Cr4z33 @justjim1220
      @justjim1220
      That did the trick thanks. :thumbs_up_medium-light_skin_tone:
      justjim1220J 1 Reply Last reply
      • justjim1220J
        justjim1220 Module Developer @Cr4z33
        @cr4z33
        Yep! Always lad to help! :smiling_face_with_sunglasses:
        Jim Hallock - 1995
          cyberphox
          So is there a way to use this without the scrolling function to ease up on CPU usage?
          Cr4z33C 1 Reply Last reply
          • Cr4z33C
            Cr4z33 @cyberphox
            @cyberphox if you don’t want it to scroll then why don’t you use the default newsfeed module of MagicMirror? :thinking_face:
            C justjim1220J 2 Replies Last reply
              cyberphox @Cr4z33
              @cr4z33 I like the logo feature with multiple feeds
              • Cr4z33C
                Cr4z33 @cyberphox
                @cyberphox oh OK.
                • Cr4z33C
                  Cr4z33 @justjim1220
                  @justjim1220 said in MMM-NewsFeedTicker:
                  you might have better luck using encoding: "ISO-8859-15" or encoding: "ISO-8859-9"
                  The latter one is supposed to work best with European characters
                  I still got some wrong encodings from time to time, but doing a search it came out that Italian users have to use encoding: "ISO-8859-16" instead.
                  • justjim1220J
                    @cr4z33
                    To stop the marquee (scroll) put the following in your config file:
                    showMarquee: false,
                    Jim Hallock - 1995
                    • Cr4z33C
                      Cr4z33 @justjim1220
                      @justjim1220 maybe you were referring to @cyberphox ? :grinning_face_with_smiling_eyes:
                      • Cr4z33C
                        Cr4z33
                        Hi @justjim1220 any news about your next update? :)
                        • justjim1220J
                          @cr4z33
                          Nothing just yet, been a bit under the weather with the flu. Keep falling asleep or losing concentration.
                          I will keep trudging through. :winking_face:
                          Jim Hallock - 1995
                          • justjim1220J
                            If anyone is interested…
                            Adding the following will scroll the image with the article, but it will stop at the left while the rest of the article finishes scrolling:
                            @Keyframes marqueeImage {
                            0% {left: 100%;}
                            100% {left: 0;}
                            .MMM-NewsFeedTicker .image {
                            position: absolute;
                            display: inline-block;
                            vertical-align: middle;
                            margin-left: 0;
                            height: 100px;
                            z-index: 1;
                            background-color: rgb(175, 175, 175);
                            animation: marqueeImage 20s linear;
                            Jim Hallock - 1995
                            • justjim1220J
                              New Update —> please run a git pull && npm install within the NewsFeedTicker directory
                              Jim Hallock - 1995
                              • Cr4z33C
                                Cr4z33 @justjim1220
                                @cr4z33
                                Have a good recovery and thanks for the update. ;)
                                • Cr4z33C
                                  Cr4z33 @justjim1220
                                  Got an error:
                                  ~/MagicMirror/modules/MMM-NewsFeedTicker $ git pull && npm install
                                  remote: Enumerating objects: 7, done.
                                  remote: Counting objects: 100% (7/7), done.
                                  remote: Compressing objects: 100% (4/4), done.
                                  remote: Total 4 (delta 2), reused 0 (delta 0), pack-reused 0
                                  Unpacking objects: 100% (4/4), done.
                                  Da https://github.com/justjim1220/MMM-NewsFeedTicker
                                     5895a96..eed535d  master     -> origin/master
                                  Aggiornamento di 5895a96..eed535d
                                  error: Your local changes to the following files would be overwritten by merge:
                                  	MMM-NewsFeedTicker.css
                                  Please commit your changes or stash them before you merge.
                                  Aborting
                                  • Cr4z33C
                                    Cr4z33 @justjim1220
                                    @justjim1220 althought I know ZERO about developing, JSON, CSS & Co. I was doing a quick search on Google about scrolling text stuttering in Electron on slow devices and I found out a suggestion at Stackoverflow.com that actually improved A LOT the overall perfomance of the newsfeed scrolling!
                                    Go open /home/pi/MagicMirror/modules/MMM-NewsFeedTicker/MMM-NewsFeedTicker and replace
                                    .MMM-NewsFeedTicker .tickerbody {
                                      position: relative;
                                    with
                                      position: relative;
                                      transform: translateZ(0);
                                      backface-visibility: hidden;
                                    You should notice now an improvement. :upside-down_face:
                                    • justjim1220J
                                      @cr4z33
                                      This error you got is just letting you know it can’t overwrite file within the module that you made any changes to
                                      You have to rename the file or delete it or just remove it from the directory
                                      Jim Hallock - 1995
                                      • Cr4z33C
                                        Cr4z33 @justjim1220
                                        @justjim1220 OK I ran the update succesfully by deleting the CSS.
                                        However I would like to revert to how it was looking before the update (static image on the left and smaller scrolling text). :grimacing_face:
                                        How do I do that please?
                                        • justjim1220J
                                          @cr4z33
                                          If you did not make any changes to the original files, run git pull && npm install
                                          If you made changes to any of the original files that you want to keep, rename those files, then run git pull && npm install
                                          if there isn’t anything you need saved, delete the MMM-NewsFeedTicker directory and run the git clone '. . .'
                                          Jim Hallock - 1995
                                          • Cr4z33C
                                            Cr4z33 @justjim1220
                                            @justjim1220 that’s what I already did, but I see you now fixed that. :)
                                            Thanks.
                                            • 3 / 5
