    MMM-Page-Selector: A page switcher that can set positions of modules
    94 Posts 14 Posters 109.6k Views 15 Watching
      Banandze
      @Veldrovive I will try it on the weekend. Yes, you ynderstand me with the problem of appearing. There is my config
      var config = {
      	port: 8080,
      	language: "ru",
      	timeFormat: 24,
      	units: "metric",
      			"module": "MMM-Page-Selector",
      			"position": "top_center",
      			"config": {
      				"defaultPage": "главная",
      				"displayTitle": true,
      				"selectPageNotif": [],
      				"incrementPageNotif": [],
      				"decrementPageNotif": []
                         module: 'MMM-page-indicator',
                         position: 'bottom_bar',
                         "pages": "all",
                         pages: 6,
                         activeBright: true,
                         inactiveHollow: true,
           			module: "alert",
                              "pages": "all",
      		module: 'MMM-PIR-Sensor',
      	        "pages": "all",
                               sensorPIN: 22,
                               powerSaving: true,
                               powerSavingDelay: 120,
                      module:     'MMM-3Day-Forecast',
                      position:   'top_right',
                      "pages": {"главная": "top_right"},
      		api_key:    '2f91769xxxxxxxxxxxxxxx',
      		lat:        54.61972,
      		lon:        39.740002,
      		units:      'M',
      		lang:       'ru',
      		interval:   900000,
      		module: "currentweather",
                      animationSpeed: 500,                     	// This can be any of the regions.
      		"pages": {"погода": "top_left"},							// Best results in left or right regions.
      			locationID: "500096", //Location ID from http://openweathermap.org/help/city_list.txt
      			appid: "ab3164xxxxxxxxxxxx" //openweathermap.org API key.
                      module: "MMM-EARTH",
                      position: "bottom_center",
                      "pages": {"погода": "middle_center"},
                      mode: "Natural",
                      rotateInterval: 5000,
                      MaxWidth: "50%",
                      MaxHeight: "50%",
                      module: "weatherforecast",
                      position: "left",       // This can be any of the regions.
                      colored: true,
                      pages: {погода: "left"},
                              locationID: "500096", //Location ID from http://openwea$
                              appid: "ab31646bxxxxxxxxxxxxx" //openweather
      			module: "updatenotification",
      			position: "top_bar",
                              "pages": "all",
      			module: "clock",
                              "pages":{"главная": "top_left", "погода": "top_left", "почта": "top_left", "новости": "top_left", "календарь": "top_left", "фото": "top_left" },
      			header: "US Holidays",
      	                "pages": {"календарь": "upper-third"},
      						symbol: "calendar-check-o ",
              		module: "newsfeed",
      			position: "bottom_bar",
      			"pages": {"главная": "bottom_bar", "новости": "bottom_bar"},
      				feeds: [
      						title: "Финансовые новости MFD",
      						url: "http://mfd.ru/rss/news/handler.ashx"
      				showSourceTitle: true,
      				showPublishDate: true
      			"module": "MMM-Cursor",
      • V
        Veldrovive Module Developer
        @Banandze,
        I’ll take a look at it. It is very possible that I made a mistake while refactoring and module precedence has been swapped.
        • V
          Changes that edit the way users must set up their config.js file have been made to this module. The position prop is no longer necessary to have inside the module config and the way to exclusions are handled has changed. For more information, look at the updated readme in the development branch of the GitHub page.
          These changes will be merged into the master branch in a couple of days which will cause errors if your config is not updated.
          • rudibaraniR
            rudibarani Project Sponsor
            Dear @Veldrovive,
            would it be possible to add an option to make the current page persistent until the next page change?
            I have to use cases where this would help:
            • if the Pi restarts, the Mirror always shows the standard page - no matter what page was active before the restart.
            • if you open the Mirror on a browser (e.g. mobile phone), you always see the standard page until the next page change happens.
            In both cases, if would be great to see the currently “active” page. Maybe there is a way to store and restore the current page?
            Thanks a lot for your active development of the module!
            • V
              Persistent properties such as those could be achieved through a temp file so definitely something that could be implemented.
              My reading week is over so I don’t have as much time to do development now, but I’ll get it done in some free time.
              rudibaraniR 1 Reply Last reply
              • rudibaraniR
                rudibarani Project Sponsor @Veldrovive
                @veldrovive That would be great - thanks a lot!!!
                You could implement it as an option for the config part - maybe there are people out there that like to have a fallback to the standard page.
                • V
                  Yea. I’m trying my best not to change base functionality so any sort of bells and whistles like this will have to be manually activated.
                  • rudibaraniR
                    @Veldrovive If I got your new pages-implementation right, we define a name for a module which is later used to organize the page layout. Is that correct? Would it be possible to give multiple names to the same module (not have on module configured and shown multiple times via different names)?
                    It would be helpful for modules with rate-limited APIs, if different parts of one module should be shown at different locations on the same page. I would like to achieve this via a custom css which addresses your name-tag.
                    If this where possible, I would like to take this one step further in the future and implement a distance based layout which keeps the information most important to me readable throughout the room, when I prepare for my way to work. Changing the layout via css could be dynamic and would not involve a whole page refresh as it occurs when switching between pages.
                    • V
                      Ok, I’ve implemented persistent pages. In order to access them right now, you need to be in the development branch since I don’t have the time to do extensive testing.
                      I’m not exactly sure what you mean when you say “not have on module configured and shown multiple times via different names”. You do not want to have the same module shown multiple times on the same page?
                      If the module was shown multiple times by this module, then all the instances would have the same config and I don’t see how that would help with rate-limited APIs.
                      Could you clarify?
                      • rudibaraniR
                        Thanks for the persistent pages. I can try them today or tomorrow.
                        Regarding showing one module multiple times: I do not want to put e.g. “clock” multiple times into the config.js and show it in different places on the screen.
                        My idea was - and I hope that I got the concept right - that if the same module (which is implemented only once in the config.js and calls the API only once) could be shown multiple times on one page. Then I could set multiple name-tags for that module and address each representation of this module separately via the name-tag in the custom.css file and show/hide/scale different parts of the module at different locations on the screen. This could be of general use for other people as well.
                        My next step after this would be to learn how to inject css info dynamically - e.g. to keep infos about my upcoming trains/flights, the traffic-map to the station and weather info at my destination at the same visual size as I move throughout the room. This I would like to achieve with a distance measurement via PIR or doppler-microwave-sensor.
                        I hope this helps to explain the idea I had.
                        • V
                          The way that this system would have to work could not reduce API calls. Duplicating the module would simply send two calls instead of one. As I understand it, a large rework of how magic mirror works at a much baser level than what this module does would be necessary to change that.
                          It would be possible to have one module shown in different places by assigning it multiple names, but I don’t see how that would really be useful.
                          • rudibaraniR
                            OK - thank for your feedback.
                            Do you have any idea on how to change the css-info or the class of a module on the fly? Would this be possible through notifications?
                            • V
                              I’ve worked with changing the classes of modules on the fly during my work on this module.
                              In order to change the class of a module or some modules:
                              MM.getModules().withClass(/*Your module name or list of names*/).enumerate(module => {
                                  ref = document.getElementById(module.data.identifier);
                                  if(ref === null){
                                      Log.log("Module does not exist")
                                  }else{
                                      ref.classList.add("Your new class")
                                      // Or if you want to get rid of a class
                                      ref.classList.remove("Your old class")
                              Reply Quote 2
                              • rudibaraniR
                                @veldrovive Thank you very much!
                                • rudibaraniR
                                  Dear @Veldrovive,
                                  sorry for not getting back to you anytime sooner. I am still struggling to get my mirror to work again. I updated MMM-Page-Selector from a version prior the changes with the second config-layout to your development branch to try out persistent pages.
                                  Since then, my mirror is very slow and unusable. If I try the new layout, my mirror stays black. If I try the old layout for the config file, it sometimes shows an image after a long period of time - but so slow, you can see how the site is being built up.
                                  I will need some time, hopefully this weekend, to reduce my current config to just MMM-Page-Selector and add one module after the other to see if the problem originates from MMM-Page-Selector or the combination with another module.
                                  • rudibaraniR
                                    Dear @Veldrovive,
                                    I have reduced my config file to very few modules but my MagicMirror keeps restarting every few seconds. That does not happen, if I stick with the “old” style of configuring Pages within MagicMirror. It seems, I make a general mistake with the way, the second Page setup should be done.
                                    Would you mind having a look, why this slimmed down version does not work?
                                    /* Magic Mirror Config Sample
                                     * MIT Licensed.
                                    var config = {
                                      address: '0.0.0.0', // Address to listen on, can be:
                                      // - 'localhost', '127.0.0.1', '::1' to listen on loopback interface
                                      // - '', '0.0.0.0', '::' to listen on any interface
                                      // Default, when address config is left out, is 'localhost'
                                      port: 8080,
                                      ipWhitelist: [
                                        '127.0.0.1',
                                        '::ffff:127.0.0.1',
                                        '::1',
                                        ['192.0.0.60', '192.0.0.189']
                                      // ['127.0.0.1', '::ffff:127.0.0.1', '::1', '::ffff:192.168.1.5'],
                                      // ['127.0.0.1', '::ffff:127.0.0.1', '::1', '::ffff:192.168.3.0/28'],
                                      language: 'de',
                                      timeFormat: 24,
                                      units: 'metric',
                                      customCss: 'css/custom.css',
                                          module: 'MMM-Page-Selector',
                                          position: 'top_bar',
                                            defaultPage: 'tag', // Tag
                                            displayTitle: true, // disable in production mode
                                            persistentPages: true,
                                            selectPageNotif: ['SELECT_PAGE'],
                                            incrementPageNotif: ['PAGE_UP'],
                                            decrementPageNotif: ['PAGE_DOWN']
                                          module: 'alert',
                                          disabled: false,
                                          config: {}
                                          module: 'MMM-WatchDog',
                                          disabled: false,
                                          module: 'MMM-Remote-Control',
                                          disabled: false
                                          module: 'MMM-Remote-Control-Repository',
                                          disabled: false
                                          module: 'updatenotification',
                                          disabled: false
                                          module: 'MMM-Snow',
                                          disabled: true, // final: set to false, hide in Remote Control & Save
                                            flakeCount: 111,
                                            theme: 'winter' // Possible values are winter, love, and water
                                          module: 'MMM-Love',
                                            flakeCount: 111,
                                            theme: 'love' // Possible values are winter, love, and water
                                          module: 'MMM-ip',
                                          disabled: false,
                                          config: {}
                                          module: 'clock',
                                          disabled: false,
                                            clockBold: false,
                                            displaySeconds: false,
                                            dateFormat: 'dddd, ll'
                                          module: 'MMM-TextClock',
                                          disabled: false,
                                            layout: 'Field', // options are 'Line' and 'Field'
                                            its24: 'ES IST', // text before hour
                                            to24: ' ', // text between hour and minute
                                            after24: 'UHR', // text after minute
                                            marked: 'color: white; font-weight: 400;', // css code to mark current time in Field layout
                                            offset: 2 // standard: 2
                                          module: 'newsfeed',
                                          disabled: false,
                                            // If no config is set, an example calendar is shown.
                                            feeds: [
                                                title: 'Tagesschau',
                                                url: 'http://www.tagesschau.de/xml/rss2'
                                      ], // top_bar, top_left, top_center, top_right, upper_third, middle_center, lower_third, bottom_left, bottom_center, bottom_right, bottom_bar, fullscreen_above, and fullscreen_below
                                      pages: {
                                        tag: {
                                          'clock': 'bottom_left',
                                          'newsfeed': 'bottom_bar'
                                        abend: {
                                        nacht: {
                                          'MMM-TextClock': 'bottom_center' // Bottom Center nur für MMM-TextClock verwenden. CSS verändert!!!
                                        wochenende: {
                                        annika: {
                                        phillip: {
                                          'updatenotification': 'top_bar',
                                        kinder: {
                                          'newsfeed': 'bottom_left'
                                        system: {
                                          'updatenotification': 'bottom_bar',
                                          'MMM-ip': 'bottom_right',
                                          'MMM-Remote-Control': 'bottom_right' // uncomment the following line to show the URL of the remote control on the mirror
                                        test: {
                                      exclusions: {
                                    /** ************* DO NOT EDIT THE LINE BELOW ***************/
                                    if (typeof module !== 'undefined') {
                                      module.exports = config;
                                      robiv8
                                      I guess it’s the MM-WatchDog module
                                      Check that out
                                      MMM-WatchDog module keeps an eye on your UI and quits app in case the UI crashes. If you combine this with the PM2 process manager, MM2 will automaticly restart after a UI failure.
                                      So you said: “my MagicMirror keeps restarting every few seconds.”
                                      • V
                                        Yep, I can verify that it is in fact WatchDog.
                                        I can also provide an explanation and a patch that you can do yourself. The way I made it possible to not include the position prop anymore is by building a temporary config, loading that one, restarting magic mirror, and then replacing the temporary with the original. I’m really sure of the underlying reason, but this process seems to trigger WatchDog to trigger an abort.
                                        As robiv says, combined with pm2, this causes a restart loop.
                                        The two easiest ways to get around this are:
                                        1. Don’t use watchdog. If you don’t think that you are going to experience crashes, then that works
                                        2. Give a position prop to every module. Including position props doesn’t change any of the visual function and that way, Page-Selector never triggers a restart and the problem doesn’t occur in the first place. The config for any given module should follow this format:
                                            module: 'MMM-module-name',
                                            position: 'any_position' //It doesn't matter what it is
                                            disabled: false,
                                        I will try to find a way to make the modules play well together, but that might take a while.
                                        rudibaraniR 2 Replies Last reply
                                          robiv8
                                          Hallo Veldrovive,
                                          I just asked you a question on GitHub about Button.
                                          Should I write this here or on GitHub? Where do you prefer it?
                                          • V
                                            Hey robiv,
                                            I do actually prefer to have issues opened on GitHub. That way I can more easily keep track of them and also it provides a record of my work in case I want to use it in order to prove my merit.
                                            Thanks for asking.
                                            • 3 / 5
