    MMM-AssistantMk2
    421 Posts 61 Posters 789.0k Views 57 Watching
    • T
      Tschili
        A Former User
        UPDATED
        [2.1.1] - 2018.11.23
        • TTS feature is added. Now, Other modules can order MMM-AssistantMk2 to say something. It can be used like something similar TEXT-TO-SPEECH. By example, you can build your customClock module to say current time via MMM-AssistantMk2
          • USAGE:
            • this.sendNotification("ASSISTANT_SAY", "Time to go to bed")
            • this.sendNotification("ASSISTANT_SAY", {text:"C'est trop chaud", lang:"fr-FR"})
          • NOTICE:
            • This feature is somekind of Assistant hooking. If you say “Repeat after me SOMETHING”, Google Assistant will repeat SOMETHING. So, there could be a possibility of not responding as intend. Too long or complex text might be not available.
            • Currently I can’t find correspondence of Repeat after me for German/Japanese/Korean language. PR please.
          • Thanks to Valerio Pilo. His brilliant idea and PR could make this feature.
        • For TelegramBot, TTS feature is also added. Now you can make your Home Mirror to say something with MMM-TelegramBot even when you are working in your office.
          • /s Please open the door, mom!
        • Youtube playing status in frontend dev-panel is added.
          • At least you can get status of Youtube player event when video fails to be played.
        • For update from 2.1.0
        cd ~/MagicMirror/modules/MMM-AssistantMk2
        git pull
        • T
          teitlebot
          @Sean Thank for the update
          I have another strange problem starting with the previous update already. If I have assistant module running my node serveronly debug doesnt show anything past “open your browser…”
          Basically everything is working but no information gets displayed in the debug window. This problem is only there if I load this module, so something here is doing it.
            A Former User @teitlebot
            @teitlebot Weird. I cannot guess what could make that. Exactly what commands did you execute? and Is MM running regardless no log?
            • T
              teitlebot @Guest
              @sean Yes MM is running without log just fine.
              I didnt execute anything but I do have lots of modules running and none of their info shows in the log unless I disable assistant.
                A Former User
                Maybe verbose:true ?
                • T
                  teitlebot @Guest
                  @sean said in MMM-AssistantMk2:
                  verbose:true
                  just tried that but didnt help
                    @teitlebot
                    I don’t know how could do that. No suspicious point to guess at this moment. Or even how to represent your symptom… :(
                    • T
                      teitlebot @Guest
                      @sean
                      ok. I tried searching for such problem but cant find anything either.
                      my MM is not up to date and im not using electron
                      maybe the problem will repeat by someone else.
                      • Cr4z33C
                        Cr4z33 @teitlebot
                        @teitlebot just out of curiosity what are you using then instead of Electron? :thinking_face:
                        • citizendevpiC
                          citizendevpi
                          @Sean just wanted to thank you again for the module and making some of our magic mirror wishes come to life! great job
                          • T
                            teitlebot @Cr4z33
                            @cr4z33 I use node serveronly and open the browser. I had some electron error. Am I making any sense?
                            • Cr4z33C
                              Cr4z33 @teitlebot
                              @teitlebot oh OK.
                                reddyman
                                Thank you Sean/Eouia for all of your hard work, this is an absolutely amazing module!
                                I do have two small issues ever since two major updates ago (when commands were added). Sorry!
                                The first one is more significant. I can’t get the screen output to show unless the module is set to “top_right”. And when I do try to say something, it distorts the module above it (fig 3). A scroll bar also appears on the bottom of the screen output (fig 4). In addition, when I activate the voice command, all the modules on the top of the screen move down a few inches (1&2). They are all probably related to an issue with display size but I can’t figure out how to adjust it.
                                It sounds somewhat similar to @teitlebot’s second issue. Did anyone ever figure it out?
                                Fig 1: https://imgur.com/rNBMHEo
                                Fig 2: https://imgur.com/EyY3htC
                                Fig 3: https://imgur.com/0IC7pL9
                                Fig 4: https://imgur.com/txuHkce
                                My second issue is more minor. When I use the command HideAll, it works for several minutes, but then eventually the default current weather and weather forecast modules unhide themselves automatically. All other modules remain hidden, including newfeed. Any advice for this issue? Kinda stuck on where the issue is and how to address it.
                                  A Former User @reddyman
                                  @reddyman
                                  I can’t find exact reason, but It might seem CSS collision being happened with your other modules
                                  add this into your css/custom.css
                                  #ASSISTANT_SCREEN {
                                    width: 1000px;  // adjust for your screen resolution or your prefer values;
                                    height: 1000px;  // Here also.
                                  For second issue; Are you using other module to control to hide and show modules? Maybe it makes to show specific module by force. There is no way to prevent force revealing by other module.
                                  https://github.com/MichMich/MagicMirror/blob/master/modules/README.md#visibility-locking
                                  ? R 2 Replies Last reply Reply Quote 0
                                    A Former User @Guest
                                    FIXED
                                    • In Italian language(or others), All results of Youtube Searching has no voice responses at all and that would interrupt YT playing; So I make a patch to ignore that error message. Now your YT won’t be interrupted.
                                      A Former User
                                      UPDATED
                                      [2.1.2] - 2018.12.12
                                      • Fixed: Youtube playlist playing bug
                                      • Added:
                                        • youtubePlayerVars
                                        • youtubePlayQuality
                                      • citizendevpiC
                                        citizendevpi
                                        Updating c379637…3538008
                                        error: Your local changes to the following files would be overwritten by merge:
                                        MMM-AssistantMk2.js
                                        Please commit your changes or stash them before you merge.
                                        Aborting
                                        how do i get past this?
                                          A Former User @citizendevpi
                                          @citizendevpi
                                          You may have modified the source by yourself.
                                          Read the answer of https://stackoverflow.com/questions/14318234/how-do-i-ignore-an-error-on-git-pull-about-my-local-changes-would-be-overwritt
                                          Or you just remove that file than retry.
                                          citizendevpiC 1 Reply Last reply Reply Quote 0
                                          • citizendevpiC
                                            citizendevpi @Guest
                                            @sean thank you , yes i did set some preferences like my location and 8 sec response time which i reset after update thank you for your help(again)
                                            • 10
                                            • 11
                                            • 12
                                            • 21
                                            • 22
                                            • 10 / 22
