    MMM-AssistantMk2
    421 Posts 61 Posters 796.8k Views 57 Watching
    • T
      teitlebot @Guest
      @sean said in MMM-AssistantMk2:
      verbose:true
      just tried that but didnt help
      ? 1 Reply Last reply
        A Former User @teitlebot
        @teitlebot
        I don’t know how could do that. No suspicious point to guess at this moment. Or even how to represent your symptom… :(
        T 1 Reply Last reply
        • T
          teitlebot @Guest
          @sean
          ok. I tried searching for such problem but cant find anything either.
          my MM is not up to date and im not using electron
          maybe the problem will repeat by someone else.
          Cr4z33C 1 Reply Last reply
          • Cr4z33C
            Cr4z33 @teitlebot
            @teitlebot just out of curiosity what are you using then instead of Electron? :thinking_face:
            • citizendevpiC
              citizendevpi
              @Sean just wanted to thank you again for the module and making some of our magic mirror wishes come to life! great job
              • T
                teitlebot @Cr4z33
                @cr4z33 I use node serveronly and open the browser. I had some electron error. Am I making any sense?
                • Cr4z33C
                  Cr4z33 @teitlebot
                  @teitlebot oh OK.
                    reddyman
                    Thank you Sean/Eouia for all of your hard work, this is an absolutely amazing module!
                    I do have two small issues ever since two major updates ago (when commands were added). Sorry!
                    The first one is more significant. I can’t get the screen output to show unless the module is set to “top_right”. And when I do try to say something, it distorts the module above it (fig 3). A scroll bar also appears on the bottom of the screen output (fig 4). In addition, when I activate the voice command, all the modules on the top of the screen move down a few inches (1&2). They are all probably related to an issue with display size but I can’t figure out how to adjust it.
                    It sounds somewhat similar to @teitlebot’s second issue. Did anyone ever figure it out?
                    Fig 1: https://imgur.com/rNBMHEo
                    Fig 2: https://imgur.com/EyY3htC
                    Fig 3: https://imgur.com/0IC7pL9
                    Fig 4: https://imgur.com/txuHkce
                    My second issue is more minor. When I use the command HideAll, it works for several minutes, but then eventually the default current weather and weather forecast modules unhide themselves automatically. All other modules remain hidden, including newfeed. Any advice for this issue? Kinda stuck on where the issue is and how to address it.
                      A Former User @reddyman
                      @reddyman
                      I can’t find exact reason, but It might seem CSS collision being happened with your other modules
                      add this into your css/custom.css
                      #ASSISTANT_SCREEN {
                        width: 1000px;  // adjust for your screen resolution or your prefer values;
                        height: 1000px;  // Here also.
                      For second issue; Are you using other module to control to hide and show modules? Maybe it makes to show specific module by force. There is no way to prevent force revealing by other module.
                      https://github.com/MichMich/MagicMirror/blob/master/modules/README.md#visibility-locking
                      ? R 2 Replies Last reply
                        A Former User @Guest
                        FIXED
                        • In Italian language(or others), All results of Youtube Searching has no voice responses at all and that would interrupt YT playing; So I make a patch to ignore that error message. Now your YT won’t be interrupted.
                          A Former User
                          UPDATED
                          [2.1.2] - 2018.12.12
                          • Fixed: Youtube playlist playing bug
                          • Added:
                            • youtubePlayerVars
                            • youtubePlayQuality
                          • citizendevpiC
                            citizendevpi
                            Updating c379637…3538008
                            error: Your local changes to the following files would be overwritten by merge:
                            MMM-AssistantMk2.js
                            Please commit your changes or stash them before you merge.
                            Aborting
                            how do i get past this?
                              A Former User @citizendevpi
                              @citizendevpi
                              You may have modified the source by yourself.
                              Read the answer of https://stackoverflow.com/questions/14318234/how-do-i-ignore-an-error-on-git-pull-about-my-local-changes-would-be-overwritt
                              Or you just remove that file than retry.
                              citizendevpiC 1 Reply Last reply
                              • citizendevpiC
                                citizendevpi @Guest
                                @sean thank you , yes i did set some preferences like my location and 8 sec response time which i reset after update thank you for your help(again)
                                  @citizendevpi
                                  Oh, You don’t need to modify source itself. the everything you had to adjust for your environment should be done in config.js, not MMM-AssistantMk2.js. If you need more configuration options, tell me.
                                  • A
                                    Arkitct
                                    @Sean this is awesome module, thanks! I have been successful in getting it installed and working with Hotword - responds and provides answers including integrating with calendar, etc. (can make appointment).
                                    But when I attempt to proceed with the instructions for “Register your Mirror as Google Assistant related device.” I am not sure what input to provide in the deviceInstance.json file for the YOUR_MODEL_ID. I have tried various permutations of what I think it is, but no luck.
                                    The instructions indicate it comes from the Google Project Console. Is this the Google Cloud Platform? There is a Project Name and Project ID listed on the Cloud Platform; are one of these the YOUR_MODEL_ID?
                                    Thanks!
                                    ? 2 Replies Last reply
                                      A Former User @Arkitct
                                      @arkitct
                                      You’ve already made deviceModelId when you mad your credentials.json on first installation. (https://github.com/eouia/MMM-AssistantMk2/blob/master/INSTALL.md#get-auth-and-credentials-to-make-profile)
                                      If you have forgotten your deviceModelId,
                                      Go to Google Action console homepage(https://console.actions.google.com) Then find your project and the menu - Device Registration
                                      Of course, there are other methods to get Model Id (If you have a plan to get deviceInstanceId also, you need to use CLI. - See https://developers.google.com/assistant/sdk/reference/device-registration/register-device-manual
                                        @arkitct
                                        But… many features are restricted in this SDK, So I think you don’t need to register Mirror to your Google Home network. Even though your mirror registered on your phone looks very nice, but that’s all. :D
                                          Jmh474
                                          Sorry this is my first post, are there any guides for helping me install the MMM-assistantMK2 I’m a total beginner With the raspberry pi any help would be much appreciated
                                          • Cr4z33C
                                            Cr4z33 @Jmh474
                                            @jmh474 Follow the link in the first post that bring you to GitHub.
                                            Once there follow CAREFULLY the step-by-step installation & configuration.
                                            Only then if there’s still anything not clear or not working ask here. ;)
                                            J 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 12
                                            • 21
                                            • 22
                                            • 10 / 22
