    MMM-AssistantMk2
    421 Posts 61 Posters 796.8k Views 57 Watching
    • Cr4z33C
      Cr4z33 @teitlebot
      @teitlebot just out of curiosity what are you using then instead of Electron? :thinking_face:
      T 1 Reply Last reply
      • citizendevpiC
        citizendevpi
        @Sean just wanted to thank you again for the module and making some of our magic mirror wishes come to life! great job
        • T
          teitlebot @Cr4z33
          @cr4z33 I use node serveronly and open the browser. I had some electron error. Am I making any sense?
          Cr4z33C 1 Reply Last reply
          • Cr4z33C
            Cr4z33 @teitlebot
            @teitlebot oh OK.
              reddyman
              Thank you Sean/Eouia for all of your hard work, this is an absolutely amazing module!
              I do have two small issues ever since two major updates ago (when commands were added). Sorry!
              The first one is more significant. I can’t get the screen output to show unless the module is set to “top_right”. And when I do try to say something, it distorts the module above it (fig 3). A scroll bar also appears on the bottom of the screen output (fig 4). In addition, when I activate the voice command, all the modules on the top of the screen move down a few inches (1&2). They are all probably related to an issue with display size but I can’t figure out how to adjust it.
              It sounds somewhat similar to @teitlebot’s second issue. Did anyone ever figure it out?
              Fig 1: https://imgur.com/rNBMHEo
              Fig 2: https://imgur.com/EyY3htC
              Fig 3: https://imgur.com/0IC7pL9
              Fig 4: https://imgur.com/txuHkce
              My second issue is more minor. When I use the command HideAll, it works for several minutes, but then eventually the default current weather and weather forecast modules unhide themselves automatically. All other modules remain hidden, including newfeed. Any advice for this issue? Kinda stuck on where the issue is and how to address it.
              ? 1 Reply Last reply
                A Former User @reddyman
                @reddyman
                I can’t find exact reason, but It might seem CSS collision being happened with your other modules
                add this into your css/custom.css
                #ASSISTANT_SCREEN {
                  width: 1000px;  // adjust for your screen resolution or your prefer values;
                  height: 1000px;  // Here also.
                For second issue; Are you using other module to control to hide and show modules? Maybe it makes to show specific module by force. There is no way to prevent force revealing by other module.
                https://github.com/MichMich/MagicMirror/blob/master/modules/README.md#visibility-locking
                ? R 2 Replies Last reply
                  A Former User @Guest
                  FIXED
                  • In Italian language(or others), All results of Youtube Searching has no voice responses at all and that would interrupt YT playing; So I make a patch to ignore that error message. Now your YT won’t be interrupted.
                    A Former User
                    UPDATED
                    [2.1.2] - 2018.12.12
                    • Fixed: Youtube playlist playing bug
                    • Added:
                      • youtubePlayerVars
                      • youtubePlayQuality
                    • citizendevpiC
                      citizendevpi
                      Updating c379637…3538008
                      error: Your local changes to the following files would be overwritten by merge:
                      MMM-AssistantMk2.js
                      Please commit your changes or stash them before you merge.
                      Aborting
                      how do i get past this?
                        A Former User @citizendevpi
                        @citizendevpi
                        You may have modified the source by yourself.
                        Read the answer of https://stackoverflow.com/questions/14318234/how-do-i-ignore-an-error-on-git-pull-about-my-local-changes-would-be-overwritt
                        Or you just remove that file than retry.
                        citizendevpiC 1 Reply Last reply
                        • citizendevpiC
                          citizendevpi @Guest
                          @sean thank you , yes i did set some preferences like my location and 8 sec response time which i reset after update thank you for your help(again)
                            @citizendevpi
                            Oh, You don’t need to modify source itself. the everything you had to adjust for your environment should be done in config.js, not MMM-AssistantMk2.js. If you need more configuration options, tell me.
                            • A
                              Arkitct
                              @Sean this is awesome module, thanks! I have been successful in getting it installed and working with Hotword - responds and provides answers including integrating with calendar, etc. (can make appointment).
                              But when I attempt to proceed with the instructions for “Register your Mirror as Google Assistant related device.” I am not sure what input to provide in the deviceInstance.json file for the YOUR_MODEL_ID. I have tried various permutations of what I think it is, but no luck.
                              The instructions indicate it comes from the Google Project Console. Is this the Google Cloud Platform? There is a Project Name and Project ID listed on the Cloud Platform; are one of these the YOUR_MODEL_ID?
                              Thanks!
                              ? 2 Replies Last reply
                                A Former User @Arkitct
                                @arkitct
                                You’ve already made deviceModelId when you mad your credentials.json on first installation. (https://github.com/eouia/MMM-AssistantMk2/blob/master/INSTALL.md#get-auth-and-credentials-to-make-profile)
                                If you have forgotten your deviceModelId,
                                Go to Google Action console homepage(https://console.actions.google.com) Then find your project and the menu - Device Registration
                                Of course, there are other methods to get Model Id (If you have a plan to get deviceInstanceId also, you need to use CLI. - See https://developers.google.com/assistant/sdk/reference/device-registration/register-device-manual
                                  @arkitct
                                  But… many features are restricted in this SDK, So I think you don’t need to register Mirror to your Google Home network. Even though your mirror registered on your phone looks very nice, but that’s all. :D
                                    Jmh474
                                    Sorry this is my first post, are there any guides for helping me install the MMM-assistantMK2 I’m a total beginner With the raspberry pi any help would be much appreciated
                                    • Cr4z33C
                                      Cr4z33 @Jmh474
                                      @jmh474 Follow the link in the first post that bring you to GitHub.
                                      Once there follow CAREFULLY the step-by-step installation & configuration.
                                      Only then if there’s still anything not clear or not working ask here. ;)
                                      J 1 Reply Last reply
                                        Jmh474 @Cr4z33
                                        @cr4z33 OK thanks mate
                                          reddyman @Guest
                                          No luck here, I ended up doing a fresh install with no other modules installed and it still happens. Can’t figure why it only applies to the default weather app, even if I move the position.
                                          I can’t figure out why no one else has this issue. Oh well, I guess I can just not use the “hide all” command though. Thanks!
                                          • citizendevpiC
                                            citizendevpi @reddyman
                                            @reddyman my mirror also pops up the default weather after hide all , I got use to it
                                            • 10
                                            • 11
                                            • 12
                                            • 21
                                            • 22
                                            • 10 / 22
