Face Recognition with inferred light
yes he shows me
User Marvin with confidence 48.63… logged in and after 15 secs User Marvin logged out.
This was recorded in completely Darkness, only IR Light. The mirror will be positioned in a tiny corridor, so the lightment is enough. Otherwise i could raise the recording time or going into night mode.
Only the console or the US as well? The image could be a bit too dark for openCV to recognize a face :(
MOAR IR LIGHT! :)
hm? :D
no only the console says logged in.
@feuerball, I meant, add more IR lights for the camera to “see” better at night.
ay, that might be a point, so i will have a Terminator on my wall :D
A series of them along the top frame won’t look too bad. Or, depending on where/how the camera is, you might be able to add a ring of IR LEDs around it too.
this is the ir light.
First i placed the cam in the middle of it; the problem is, that the IR reflects @ the mirror, so the camera was blind.
A wall of IR lights might be a way to do it
Yeah, if that didn’t work around the camera, then you’ll need to add them to the frame (or in front of the mirror essentially.)
Maybe something like this embedded in the frame?
http://amzn.com/B019QTDDH2
