    Face Recognition with inferred light
    52 Posts 5 Posters 58.7k Views 4 Watching
    • K
      KirAsh4 Moderator @feuerball
      @feuerball, I meant, add more IR lights for the camera to “see” better at night.
      • F
        feuerball @KirAsh4
        @KirAsh4
        ay, that might be a point, so i will have a Terminator on my wall :D
        • K
          KirAsh4 Moderator
          A series of them along the top frame won’t look too bad. Or, depending on where/how the camera is, you might be able to add a ring of IR LEDs around it too.
          • F
            feuerball @KirAsh4
            @KirAsh4
            this is the ir light.
            http://www.amazon.de/Infrarot-Leuchter-Board-Plate-Sicherheitskamera/dp/B0057DPXI4?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
            First i placed the cam in the middle of it; the problem is, that the IR reflects @ the mirror, so the camera was blind.
            A wall of IR lights might be a way to do it
            • K
              KirAsh4 Moderator
              Yeah, if that didn’t work around the camera, then you’ll need to add them to the frame (or in front of the mirror essentially.)
              • K
                KirAsh4 Moderator
                Maybe something like this embedded in the frame?
                http://amzn.com/B019QTDDH2
                • F
                  feuerball
                  Saw this too :)
                  I think i will create a new frame with a larger monitor and a real mirror glas anyway so i gonna try to get more IR-Light into this.
                  The only doubt i got is the power consumption… Tons of IR-Lights = Tons of W/h :D
                  • K
                    KirAsh4 Moderator
                    Problem solved! 80-100 METERS of illumination!
                    • F
                      feuerball
                      :D a bit too strong for a 4x1.5m corridor :D
                      • K
                        KirAsh4 Moderator
                        This might work though, if you’re using either an rPi camera, or something similar. If you’re going to put the camera in the frame, you’ll be drilling a hole. Why not two more for the IR lights as well. And at 3W each, that’s mighty bright. http://amzn.com/B00ZEFIU6C
                        • F
                          feuerball
                          hmmmm. thanks sounds like a plan.
                          I think i have to drill one larger hole, otherwise the photodiode cant see wether its dark or not hm?
                          • K
                            KirAsh4 Moderator
                            A small hole next to the large one, enough for light to go through, should work. Usually it’s a tiny pinhole, but that’s also assuming the sensor is literally right up against the pinhole.
                            • F
                              feuerball
                              so still the problem with not logging in correctly :(
                                paviro
                                Is there any log in the Web inspector?
                                – The Doctor
                                • F
                                  feuerball
                                  How can I see the web inspector?
                                    paviro @feuerball
                                    @feuerball try alt cmd I
                                    – The Doctor
                                    • F
                                      feuerball
                                      Gonna give this a try when I’m back@home
                                      • F
                                        feuerball
                                        @paviro
                                          paviro @feuerball
                                          @feuerball please press on main.js on the right so we can see on what it tries to execute the lower case thing.
                                          – The Doctor
                                          • F
                                            feuerball
