Little voice testing.....
Just testing out some stuff…
I likey! :thumbsup:
that’s real cool!
@cowboysdude well thats cool …does it do turn on and turn off modules also ??
@richland007 said in Little voice testing.....:
Like this?
https://www.youtube.com/watch?v=2cedXKk1Alw
Or this?
is it also possible to turn off the monitor?
@cyrus1337 said in Little voice testing.....:
Yes, it is.
https://www.youtube.com/watch?v=3ldlUPkw2nM&feature=youtu.be -
Pretty slick. What’s changing the pages?
@cyrus1337 I just say ‘hide modules’… I could tell it to ‘go to sleep’ but haven’t gotten that far yet :)
@bkeyport MMM-voice and MMM-pages
Hey mate! Awesome work! Trying to do the same myself! How do you run MM natively on Linux? I can only seem to run it as a server. Are you using Docker or something? Thanks and merry Christmas!
@mdhenriksen said in Little voice testing.....:
Are you asking about something other than a Pi? ubuntu and MM run very happily together. Install ubuntu (I use 16.04 exclusively) and update. Install the latest stable version of node and npm. Install MM and its dependencies. Live a happy life. :)
@mykle1 said in Little voice testing.....:
I’ll try with 16.04 then! Currently on 18.10. Do you just run the npm start and then it opens in a new window or how does it work?
Just to be clear, 16.04 LTS. Never had a problem on several machines.
Now, everything is exactly the same as if it were running on a Pi. So, yes, all commands are exactly the same, including
npm startin the MagicMirror directory -
npm startin the MagicMirror directoryGreat. I really appreciate you taking the time to answer me. I’ve tried looking for answers every first and checked the guides as well, but just kept running into some problems.
Could you refer me to somewhere that shows how to install dependencies maybe?
Merry xmas!
In the case of the installation of MM, after you clone the MM repo, you would navigate to the MagicMirror directory in your terminal and run
npm install. That will install the dependencies for MagicMirror. In the case of adding modules, you would navigate to that module folder in your terminal and runnpm install. Simple as that. :-) -
npm install. That will install the dependencies for MagicMirror. In the case of adding modules, you would navigate to that module folder in your terminal and runnpm install. Simple as that. :-)Awesome, got it working finally! Thanks a lot! Great to see people like you helping out here. It’s much appreciated! :smiling_face_with_open_mouth:
That’s good news! Now enjoy yourself. :thumbsup:
@cowboysdude the modded module works well for something still in development, but I’ve come into an issue where the mic errors when mmm remote connection opens up the browser to view the actual mirror modules like you would see them on the mirror, I have looked of VNC and the mic works but as soon as you use mmm remote control to view the mirror it errors the mic. Any ideas why
@dazza120 No because I didn’t write MMM-voice I just modified it to work with MMM-Pages.
I would create a new topic under the troubleshooting section and see if anyone can help, because for this I really have no idea.
