    Calendar Module +1 day Error
    14 Posts 7 Posters 12.1k Views 7 Watching
      StrIIker @sdetweil
      @sdetweil said in Calendar Module +1 day Error:
      What is the system time one set to?
      Where are u located?
      I am in New York / Eastern time zone. System time is set to Eastern / New York.
      I installed the MMM-MyCalendar module and it’s working with correct dates etc. I’d prefer to use the default one though.
      Current default time zone: ‘America/New_York’
      Local time is now: Wed Oct 3 16:09:57 EDT 2018.
      Universal Time is now: Wed Oct 3 20:09:57 UTC 2018.
      • N
        Nilnik Project Sponsor
        Hi! If you put showEnd: false, in your config for calendar solves the problem.
        Oct 9th is and nov 1st when it ends.
          StrIIker @Nilnik
          @nilnik said in Calendar Module +1 day Error:
          Hi! I did try this and restarted. The problem persists. I placed that value in two locations… The config for the module and the config for the calendar. Neither has any impact. I also did not see this option mentioned in the GitHub documentation. Perhaps it’s an old value which was retired? Your observation does seem valid. I just wonder why it’s stuck in this mode for me.
                                  "module": "calendar",
                                  "header": "Calendar",
                                  "position": "top_left",
                                  "showEnd": "false",
                                  "config": {
                                          "calendars": [
                                                          "symbol": "calendar-check-o ",
                                                          "url": "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics",
                                                          showend: "false",
                                                          "color": "#FFFFFF"
          • N
            Hello again!
            I Think that you shouldn’t put quotes rond false
            Here is my config:
            module: ‘calendar’,
            header: ‘Kalender, Helg-och födelsedagar’,
            position: ‘top_left’,
            colored: true,
            timeFormat: ‘absolute’,
            maximumEntries: 12,
            urgency: 2,
            dateFormat: ‘Do MMM’,
            fullDayEventDateFormat:‘Do MMM’,
            showEnd: false,
            getRelative: 48,
            Reply Quote 2
              StrIIker @Nilnik
              Hello again!
              Here is my config:
              module: ‘calendar’,
              colored: true,
              maximumEntries: 12,
              urgency: 2,
              showEnd: false,
              getRelative: 48,
              Hi! That did it! Thank you for your patience and help! I greatly appreciate the help and will certainly help others whenever I can.
              To get this issue resolved, I had to include the showEnd value AND set the timeFormat to absolute as you have. Now my calendar displays the date correctly…
              • N
                Glad to help. Have a nice weekend
                • F
                  felafel
                  Edit: I thought I had this problem but I put
                  			timeFormat: 'absolute',
                  			showEnd: false,
                  in the wrong section. Once I put it in the config it worked.
                    Blackmirror
                    I have the same problem, but this fix will not solve my problem.
                                            module: 'calendar',
                                            classes: 'default everyone',
                                         //   header: 'Termine',
                                            position: 'top_right',
        url: 'https://calendar.google.com/calendar/XXX',
        symbol: 'calender',
        colored: true,
        displayRepeatingCountTitle: 'Birthday',
        maximumEntries: 5,
        dateFormat: 'DD MMM',
        fullDayEventDateFormat:'DD MMM',
        showEnd: false,
        getRelative: 48,
        urgency: 2
                    And the chance from the date will not work.
                    The Date shows : Dec 8 and not 8 Dec.
                    Blackmirror
                    • Y
                      yawns Moderator
                      It is a bit irritating where to put the config stuff. Some needs to go to config section directly, some need to go to the calendars section.
                      Please try this:
                      	module: 'calendar',
                      		displayRepeatingCountTitle: true,
                      		showEnd: false,
                      		getRelative: 48,
                      		urgency: 2,
                      				symbol: 'calender',
                      				colored: true,
                      				maximumEntries: 5,
                      				repeatingCountTitle: 'Birthday'
                        Blackmirror
                        Thanks. It’s work fine
                          Joerg633
                          Hello again,
                          i still have the same problem with goggle calendar fullday entries.
                          For example an entry for 2 fulldays (01/19-01/20) will be:
                          ics data from the google calendar link:
                          DTSTART;VALUE=DATE:20190119
                          DTEND;VALUE=DATE:20190121
                          So the module shows
                          So i check all timezone / language etc. settings, in MM, modules section and raspi settings with no success.
                          Calendar views in google calendar webpage, android calendar apps and also outlook 365 are correct (2 days not 3).
                          my config
                          		module: 'calendar',
                          		header: 'Familienkalender',
                          		position: 'bottom_left',
                          			maximumEntries: 13,
                          			displaySymbol: false,
                          			maxTitleLength: 24,
                          			fade: true,
                          			fadePoint: 0.7,
                          			fullDayEventDateFormat: 'Do MM k:mm',
                          			dateFormat: 'Do MMM k:mm',
                          			urgency: 0,
                          			colored: false,
                          			coloredSymbolOnly: true,
                          					url: 'https://calendar.google.com/calendar/ical/.../basic.ics'
                          Thanks for any hint
                          Joerg
