    Change module position
    9 Posts 3 Posters 42.7k Views 4 Watching
      samydp
      I know that can change the position from the modul of the right to the left ,bottem.
      I can change them exactly px ? even if the module has no style.css.
      because I want to have on the left side more modules
      sorry for my bad English
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @samydp
        @samydp those are all valid positions you can enter in the config.js https://forum.magicmirror.builders/topic/286/regions
        however you can make your custom layout in ~/MagicMirror/css/custom.css
          samydp
          perfect! how do I link the file created in the config? I can also change the font?
            @samydp you don’t need to link the custom.css file it’s already working with the content in this file
            of course you can change the font as well
              samydp
              Perfekt:)
              can i with the help of .modulname in the Main chance the position of the individual modules?
              For example:
              .Clock (Modul Name)
              Left : 100 px,
              Top:50 px
                @samydp the module name is case sensitive so you have to write it like in the config file e.g. in your case it would be .clock
                .clock{
                  left : 100 px,
                  top:50 px
                also think about using position with the values fixed, absolute or relative
                  samydp
                  Thank you for your help!! language I could change only in what config I make the position of the modules
                    sorry I couldn’t get your question
                    • L Offline
                      Legendary_Wiz @strawberry 3.141
                      @strawberry-3-141 I tried putting this into cutstom.css and changing the left and right px . But nothing happened . I want to shift my clock to the right a little for alignment . Is there anything I’m doing wrong ? Thank you .
