    Details about Nunjucks templating system?
    11 Posts 4 Posters 9.0k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @j.e.f.f
      @j.e.f.f I didn’t had a look yet, but maybe you want to have a look into the refactor of the weather modules where the nunjuck idea was born https://github.com/MichMich/MagicMirror/tree/weather-refactor/modules/default/weather
        j.e.f.f Project Sponsor Module Developer @strawberry 3.141
        @strawberry-3.141 I ended up just diving in and figuring it out. I spent some time rewriting MMM-MyCalendar to use the Nunjucks templating system. Here’s what I’ve learned:
        • The screen update is triggered using the updateDom() function, just like other modules
        • When updateDom() is called, so is getTemplateData() which refreshes the data model provided to the template
        • The screen often seems to physically update even if the DOM contents have not changed, which is different behaviour from modules using the old getDom() routine. I’m wondering if Nunjucks injects something into the template that makes each update distinctly different in the markup…
        • Updates on the screen seem to take a second or so longer than the old way of doing things. A screen update will result in a moment of black even if you have not specified a fade duration (i.e. updateDom() vs updateDom(200))
        Generally I really like the templating system. Makes tweaking the UI so much easier than wading through a bunch of document.createElement statements. If you’ve used Nunjucks before you’ll feel right at home and wonder what took so long for this feature to be implemented :)
        Just to give you an idea of what to expect, here is what the template looks like for MMM-MyCalendar now. Much less code and way easier to read.
        1 Reply Last reply Reply Quote 4
        • cowboysdudeC Offline
          Little late to this party but I agree the Hello World example is well not really a good example.
          So I’m playing around with it …
            j.e.f.f Project Sponsor Module Developer @cowboysdude
            @cowboysdude After having used it with my calendar module, I’ve since abandoned this and reverted to the JavaScript generated DOM like before. I’ve found that if the module is hidden, then it doesn’t always update properly. I’m not sure if this is a Nunjucks behaviour issue or a bug with MM, but in either case I haven’t found a way to work around it.
            I had theorized that I could have some kind of event watcher that monitored when the module became visible, and have it trigger a DOM update, but I never got around to exploring that.
            Hopefully you get further than I did. To get familiar with how Nunjucks works, this page is your friend:
            https://mozilla.github.io/nunjucks/templating.html
            Good luck! And if you experience my issue and a way to work around it, I’d love to hear how you did it! I’d still love to use a templating system instead of JS generated DOM.
            strawberry 3.141S 1 Reply Last reply Reply Quote 1
              @j-e-f-f did you try to call updateDom in the resume hook of your module?
                @strawberry-3-141 I forgot that that hook even existed! Maybe I can give that a try, but I wonder it means I’ll have stale data… if the module is suspended, does that mean it doesn’t respond to socket notifications from the helper, or even send socket notification to trigger a data pull?
                  sdetweil @j.e.f.f
                  @j-e-f-f said in Details about Nunjucks templating system?:
                  no… it just doesn’t get called at getDom()… least thats how my modules see it…
                  you can’t present new info unless the getDom() method is called
                  your module can call updateDom() to request the callback at getDom(), but you are suspended… so the callback never happens
                    j.e.f.f Project Sponsor Module Developer @sdetweil
                    @sdetweil ok sounds like that’s the ticket then. I’m going to try updating DarkSky with the template system and see how it behaves. Will report back when I know more.
                      OK I’ve got a version of MMM-DarkSkyForecast using the Nunjucks templating system. Seems to be working well… will run it for a few days to observe. Funny thing is I didn’t need to put anything in the resume() hook… it just… works.
                      You can see my work here:
                      https://github.com/jclarke0000/MMM-DarkSkyForecast/tree/templated
                      I original ran into the problem with my calendar module, which does a DOM update for each configured calendar, which results in a burst of DOM updates… I wonder if the issue has to do with frequent successive DOM updates.
                        Seems to be no issues. I’ve released v1.6 of MMM-DarkSkyForecast using the Nunjucks templating system. Seems like my way forward from here :)
                        I’ll have to go back and revisit MMM-MyCalendar to see what caused the issue.
