    My first Magic Mirror (Italy)
    19 Posts 5 Posters 9.2k Views 3 Watching
      A Former User
      Modules configured, clean and simple, just what I need, ALEXA coming soon:
      The video on bottom left is LIVE YouTube channel of EURONEEWS Italy
        A Former User
        Testing temperature, heatsink is needed considering summer temperatures
          A Former User
          Testing vertical layout, look better right?
            bhepler Module Developer
            You’re definitely off to a good start! I like the FLIR tool. I’m jealous. I don’t know why I would need one, but I want one now.
            I notice that you took off the metal backing to your monitor. Did you have any concerns with that? I have to take the one off the mirror I’m building now because it kind of fell off during the bezel removal process. I haven’t done that before and I’m nervous I’ll short something.
            ? 1 Reply Last reply
              A Former User @bhepler
              @bhepler Yes I removed the shield to make it slimmer.
              All the boards are 1cm above the LCD surface, I used some plastic spacers and I put an Electrical insulation paper above them.
              I use the Flir thermocamera for testing the Broadcast Cameras that I sell, many cameraman complains about heat coming from cameras.
              B 1 Reply Last reply
                bhepler Module Developer @Guest
                @qbox83 - Aha! I have a thin sheet of acrylic I can use as an insulation layer. I can then reposition the two boards of the monitor and position the Pi where I need it. Thanks!
                • V
                  vinp Module Developer
                  complimenti !
                    A Former User
                    Almost done, tomorrow I will post all the pictures step by step
                      A Former User @vinp
                      @vinp grazie :-)
                        A Former User
                        2_1544439429634_IMG_5364.jpg 1_1544439429634_IMG_5363.jpg 0_1544439429634_IMG_5362.jpg
                        Cr4z33C 1 Reply Last reply
                        • Cr4z33C
                          Cr4z33 @Guest
                          @qbox83 said in My first Magic Mirror (Italy):
                          Hey I am Italian too and in need to find a solid frame solution for my 55" MagicMirror project.
                          Alluminium frames are a pain in the a** as no online national company builds them so big (not to mention local companies that don’t want to deal with that kind of requests…) so big so I went back thinking at wooden solutions.
                          Can you please tell me where can I buy that special sawing kit?
                          I like it alot and your project is coming out really well! :thumbs_up_medium-light_skin_tone:
                          • G
                            Giuse
                            Hi Antonio,
                            Sono uno sviluppatore italiano e da circa 6 mesi sto implementando la mia soluzione MIRROR 2.0 ampliata all’ambito italiano.
                            Saresti interessato a collaborare in quest’impresa?
                            Attualmente sto cercando di implementare il modulo legato alle api dei trasporti pubblici, un modulo per i comandi vocali con Alexa e un modulo per interfacciarsi con i veicoli Tesla.
                            Fammi sapere!!
                            Ciao!
                            Giuseppe
                            • G
                              Giuse
                              Ho dimenticato di inserire un’email di contatto…
                              Giuse.scibetta@gmail.com
                              Un saluto
                              Giuseppe
                                A Former User
                                @Cr4z33 lo trovi da Leroy Merlin
                                https://www.leroymerlin.it/catalogo/tagliacornici-dexter-550-mm-35861224-p
                                • Cr4z33C
                                  Cr4z33 @Guest
                                  @qbox83 OK thanks. :thumbs_up_medium-light_skin_tone:
                                    A Former User
                                    2_1544951150798_IMG_5383.jpg 1_1544951150798_IMG_5382.jpg 0_1544951150798_IMG_5380.jpg
                                    FINISH.
                                    I have to say that Acrylic sheet isn’t the best choice since it scratch too easily and it’s hard to clean without ruin it.
                                    I will move to DIELETTRIC MIRROR
                                      A Former User
                                      ragazzi comprate gli specchi qui:
                                      https://www.brigla-shop.de/
                                      spedito mi fanno online perun 54cm x 34cm cca 68€ il MirroView della Pilkington
