    modules day and time Depending represented
    29 Posts 7 Posters 22.6k Views 7 Watching
    • I Offline
      ianperrin
      So, my current thinking is based around the following config
      	module: 'MMM-ModuleScheduler'
      	module: 'calendar',
      	position: 'top_left',
      	classes: 'scheduler',
      		// Show at 9:00 and hide at 18:00 every day from Monday through Friday
      		module_schedule: {from: '0 9 * * 1-5', to: '0 18 * * 1-5'}
      	module: 'MMM-soccer',
      	position: 'top_right',
      		// Show at 9:00 on Saturday and hide at 20:00 on Sunday
      		module_schedule: {from: '0 9 * * SAT', to: '0 20 * * SUN'}
      Modules would then be shown and hidden based on the addition of a specific class classes: 'scheduler' and a module_schedule config option containing the cron expressions which control when the module should be shown (from) and hidden (to).
      How does that sound?
      p.s. here’s another useful cron resource - http://crontab.guru/
      "Live as if you were to die tomorrow. Learn as if you were to live forever." - Mahatma Gandhi
        bjoern
        YES! That’s gerat!
        • KirAsh4K Offline
          KirAsh4 Moderator
          You can easily have another module (module_scheduler?) keep track of time and when require, it can call another module’s .hide() or .show() routine. And you’d want to check on the other module every so often, in case the mirror restarted and re-displayed it.
          • I Offline
            ianperrin
            @bjoern - I have created an initial version of MMM-ModuleScheduler and pushed it to github -https://github.com/ianperrin/MMM-ModuleScheduler
            If you would like to test it, feel free to install it on your Mirror and report back here.
            However, please remember that this is work in progress and has not yet been fully tested, so please do use with care.
            • cowboysdudeC Offline
              Seems to work pretty well! I did load it to test it to turn off at 7:50 and it took a while for the mirror to load but I assumed it was the cron preparing itself. The module is indeed off… it didn’t load the Holidays or News feed it just said loading…
              So I stopped the mirror and restarted it. It loaded quicker [still slow so people don’t freak out :)]… the Holiday and News Feed did indeed load …
              So the only thing NOT on the screen is the thing I attached to the scheduler… so it’s working… Only thing I can see wrong is the speed [decreased] of loading the mirror! BUT it’s not like you start and stop the mirror daily anyway so once it loads it works :)
              I like it!! Thank you!!!
                It’s turning anything off with 'classes: ‘scheduler’, attached no matter what time you set it for ;)
                • I Offline
                  ianperrin @cowboysdude
                  @cowboysdude said in modules day and time Depending represented:
                  As part of the install process, npm install needs to be run to install the dependency on node-cron. This can take a little time, but is only required once. Having completed the install, I’m not seeing the performance issues you mention so we might need to look into that a little further.
                  • I Offline
                    The expected functionality is that the module is shown between the dates specified, so once the module has done it’s thing, it hides the modules and they are not shown until the next ‘from’ date.
                    In more detail, it should follow the following process once it receives the notification (DOM_OBJECTS_CREATED) that all modules have been loaded:
                    • It checks each module to see if it contains the ‘scheduler’ class
                    • If yes, it checks whether the module config includes the ‘module_scheduler’ option
                    • if yes, it checks whether the option includes the ‘from’ and ‘to’ properties
                    • if yes, it creates the cron jobs to show (‘from’) and hide (‘to’) the module
                    • if the next show (‘from’) date for the module is in the future and less than the next hide (‘to’) date, it hides the module
                    • when the ‘from’ cron job is triggered, it sends a notification to show the module
                    • when the ‘to’ cron job is triggered, it sends a notification to hide the module
                    Now, as this is work in progress I haven’t had time to check all permutations of modules and cron expressions. However, it’s logging is rather verbose so please do check out the console log (pm2 logs mm) to see what it thinks it is doing!
                    If you find problems, can you post your config (or at the least, which module you are trying to schedule and the values for the module_scheduler option?
                    • I Offline
                      ianperrin
                      Earlier versions of the module would create duplicate cron jobs if the Mirror recreated the modules (e.g. after a page refresh in the browser). The current version attempts to resolve this.
                      Trailblazers who’ve already grabbed a copy of the module please run git pull from the module directory - see https://github.com/ianperrin/MMM-ModuleScheduler#updating for more details
                        cowboysdude Module Developer @ianperrin
                        @ianperrin said in modules day and time Depending represented:
                        No no it’s only an issue one time … after it loads the first time it’s fine thereafter :)
