    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 549.6k Views 29 Watching
    • Y
      yawns Moderator
      Well, the main problem is that the authority which issued and signed the certificate is untrusted. Therefore browsers block access to this site showing a warning
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @yawns
        @yawns
        Thank you for that info. Please allow me to ask 2 more questions.
        1. Is that something that the owners of the API have to correct?
        2. If they can’t, or won’t, is there a way to have electron accept the untrusted certificate or disregard the warning?
          @mykle1 they should have used a proper certificate authority.
          there is no way to do it ‘automatically’.
          As their note suggests, you will have to do it manually…
          what a pain in the rear!..
          Mykle1M 2 Replies Last reply
          • Mykle1M
            Ahh, what terrible news. I’m going to write back to them.
            • Mykle1M
              @sdetweil said in MMM-Lunartic:
              I found this in a readme of another module here on the forum. I tried to add it to my config.js (in a few places) without success. It would error the config, or not work, depending. I was hoping something like this might work for me for even though you stated there is no way to do it ‘automatically’.
              Readme quote:
              This module requires an extra step to work:
              “If you don’t already have one, add a electronOptions object with the following options in your MagicMirror config.js file.”
              and
              electronOptions: {
                  webPreferences: {
                      webSecurity: false
              I also found this online regarding electronOptions.
              allowDisplayingInsecureContent: true,
              Is there any hope?
              EDIT
              Ok, never mind. This didn’t work
              • Mykle1M
                I have written to the US Naval Observatory again, pointing out that their use of an improper certificate authority has sidelined my Lunartic and SunRiseSet modules. I don’t hold out much hope of action on their part.
                • Mykle1M
                  I’ll see what I can do with this
                  Event: ‘certificate-error’
                  Returns:
                  event Event
                  webContents WebContents
                  url String
                  error String - The error code
                  certificate Certificate
                  callback Function
                  isTrusted Boolean - Whether to consider the certificate as trusted
                  Emitted when failed to verify the certificate for url, to trust the certificate you should prevent the default behavior with event.preventDefault() and call callback(true).
                  const {app} = require('electron')
                  app.on('certificate-error', (event, webContents, url, error, certificate, callback) => {
                    if (url === 'https://github.com') {
                      // Verification logic.
                      callback(true)
                    } else {
                      callback(false)
                  • Mykle1M
                    Well, the closest I could get with the above event handler is an error stating that I could only use the callback once and some foreboding warnings in the dev console about exposing the user to security risks. BLEH!
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @Mykle1
                      @mykle1 said in MMM-Lunartic:
                      Their reply to my 2nd email:
                      **Mr. Lange:
                      I’m afraid this is a problem that goes well beyond the USNO. Over the course of the past few month ALL DoD websites have been reconfigured to “https”, resulting in certificate errors to non-DoD users. I came across this site today which has another way to correct the issue, as well as an explanation of why the problem is occurring. Evidently it’s the browser providers that seem to be on the hook to update their certificate stores.
                      https://mrmc.amedd.army.mil/index.cfm?pageid=ssl
                      Interestingly I had to manually accept the site certificate for this page, despite the fact that I’m coming in from a .mil domain!
                      Regards,
                      Geoff Chester
                      Public Affairs Officer
                      U.S. Naval Observatory
                      3450 Massachusetts Avenue, NW
                      Washington, DC 20392
                      geoff.chester@navy.mil
                      • qu1queQ
                        qu1que Project Sponsor
                        @Mykle1
                        Maybe this can help you.
                        Before using the MMM-Lunartic module, I used the module MMM-moonphases https://github.com/spectroman/mmm-moon-phases until one day a few months ago it also stopped working (the images of the moon did not come out ). At that time I decided to install the Lunartic, until they also stopped seeing the images of the moon a few weeks ago.
                        Then, yesterday it occurred to me to try again with the MMM-moonphases, and now the images come out. I do not know if I could give you any idea or if it can help you in something.
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @qu1que
                          @qu1que said in MMM-Lunartic:
                          Thank you. I will look into that right now.
                          FYI, there is a temporary fixed uploaded to MMM-Lunartic
                          EDIT
                          The site used by moon-phases suffers from the same security issue. I don’t know how your MM allows you in unless you’ve done something to circumvent the electron error. In which case, I’d like to know how you did it.
                          qu1queQ 1 Reply Last reply
                          • qu1queQ
                            qu1que Project Sponsor @Mykle1
                            @mykle1 Sorry for answering you so late. Apparently the moon-phases module worked correctly, or that was what I believed because the image of the moon was visible. The problem is that with time I realized that it was not updated, always showed half moon.
                            • Mykle1M
                              @qu1que
                              No worries, mate. The temporary fix I uploaded is working. Hopefully, the certificate store will update and I can go back to using the US Naval Observatory API again. In the meantime, the current version of Lunartic works
                              • Mykle1M
                                Download:
                                [card:mykle1/MMM-Lunartic]
                                Minor Update 1.0.5
                                Git user Mysh3ll donated a PR for correcting some French translations
                                • Mykle1M
                                  Update
                                  I am happy to report that the certificate issue with the US Naval Observatory API has been corrected. I don’t know if I had anything to do with the fix but I did keep emailing them and the electron team about updating the certificate stores.
                                  MMM-Lunartic is now working as intended. Please do a git pull to remove the temporary fix files, or install as per the readme.
                                  I’m very happy now.
                                  • Mykle1M
                                      sdetweil @Mykle1
                                      @mykle1 outstanding news!!!
                                      • Mykle1M
                                        Yeah, isn’t that fantastic! It affected both MMM-Lunartic and MMM-SunRiseSet so I’m very happy right now.
                                        • Mykle1M
                                          Back to normal. Now page one of my dev machine looks like this.
                                          justjim1220J 1 Reply Last reply
                                          • justjim1220J
                                            justjim1220 Module Developer @Mykle1
                                            @mykle1 Very cool layout!!!
                                            Jim Hallock - 1995
                                            • 13
                                            • 14
                                            • 6 / 14
