    MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!
    nestthermostatprotectsmoke detector
    65 Posts 18 Posters 51.7k Views 18 Watching
    • bheplerB Offline
      bhepler Module Developer
      Your first module you say? Wow. Coming in strong right out of the gate. Well done!
        PhiDeltDexter
        Love the screenshots, its exactly what I am looking for for a dashboard. However I cannot get it to load. I have gone through as much troubleshooting as I can think of, including starting over from scratch with a new RPi image.
        I go through the steps for setup and enter the numbers necessary from my Nest Developer account, PIN etc. It gives me the attached response with a token.
        The issues that the token comes across as
        token:"c.Ythenabunchofletters
        thoseletterscontinue }
        So my question is - is the "c. part of the token? I have tried copying the whole thing and it throws an error when reloading MM.
        module: "mmm-nest-status",
        position: "lower_third",
        config:  {
                       token:"c.Yblah
        moreletters           }
        I have tried copying the "c.yblah without an end quote and add a , and it throws an error.
        token:"c.Yblah,
        When I run config:check in MagicMirror folder it says there are no syntax errors but when I reload MM it throws an error.
        I have tried adding a " to the end and a , and MM loads, but my icon looks like this:
        token:"c.Yblah",
        The README shows as an int for the type so I should not need the " ", but thats the only way to make MM load.
        I have also tried all of the above steps without the c. and it still shows the loading icon.
        I apologize if this is something very simple that I just cannot figure out, so any help would be appreciated.
        D michael5rM 2 Replies Last reply Reply Quote 0
          dazza120 @PhiDeltDexter
          @phideltdexter said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
          config:  {
                         token:"c.Yblah
          moreletters           }
          token:"c.Yblah,
          token:"c.Yblah",
          So yours is like this try belows config just put in your token number
          module: ‘mmm-nest-status’,
          position: ‘bottom_left’, // pick whichever position you want
          token: “c.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX”,
          displayMode: ‘all’,
          displayType: ‘list’,
          thermostatsToShow: ‘all’,
          units: ‘metric’,
          thermostatSize: ‘small’,
          alignment: ‘left’,
          // … and whatever else configuration options you want to use
          • michael5rM Offline
            michael5r Module Developer @PhiDeltDexter
            @phideltdexter My bad - there’s a typo in the Read Me, the token should be a string, not an int (I have updated the module now to reflect this).
            Try this in your config:
                    token: "c.XXXXXXXXXX",
            where, of course, you replace c.XXXX with your actual token.
              PhiDeltDexter @michael5r
              @michael5r
              Just wanted to update you. I needed to update both the mmm-nest-status and MM overall and now it appears to be working fine. Thank you for your clarification!
              michael5rM 1 Reply Last reply Reply Quote 0
                @phideltdexter Great to hear - thanks for the update!
                  PhiDeltDexter
                  Would you have any way to add the outdoor temperature reading that the Thermostat has?
                    Unfortunately, no - the outdoor temperature reading on a Nest thermostat isn’t actually coming from Nest; they send your location data to the Weather Channel (yes, really!) and then show the returned value on the thermostat itself.
                    As such, they don’t include the outdoor temperature as part of their API data.
                      Just wanted to announce that there’s a new version out of both my Nest modules!
                      I added functionality to support Paviro’s MMM-PIR-Sensor module meaning that the modules can now be suspended & resumed based on movement detected through a PIR sensor (or whatever else you’re using for motion detection).
                      Check out the release notes here:
                      https://github.com/michael5r/mmm-nest-status/releases/tag/1.4.0
                      And for mmm-nest-cameras:
                      https://github.com/michael5r/mmm-nest-cameras/releases/tag/1.1.0
                      • E Offline
                        eawalker1
                        This is my first module I am attempting to install, and keep getting a Nest API Error:null. Total noob here, but I have registered as a developer, obtained Nest token/pincode, and believe I input code correctly into config.js file per below.
                            token: "my8characterpinfromnest",
                            displayType: "grid",
                            displayMode: "all",
                            thermostatsToShow: "all",
                        Any ideas how to resolve the API issue?
                        • 3 / 7
