    MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!
    nestthermostatprotectsmoke detector
    65 Posts 18 Posters 63.2k Views 18 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @michael5r
      @michael5r
      Could you give an example of how this is added to the config.js? Please and thank you.
      electronOptions: {
          webPreferences: {
              webSecurity: false
      michael5rM 1 Reply Last reply
      • michael5rM
        michael5r Module Developer @Mykle1
        @mykle1 said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
        @michael5r
        electronOptions: {
            webPreferences: {
                webSecurity: false
        Sure - it’s just another object, just like modules:
        • michael5rM
          michael5r Module Developer @culi831
          @culi831 said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
          The modules not update after the recent upgrade ???
          Both the nest-status and nest-cameras modules should be working just fine - what issue are you having?
          Bear in mind that the latest 1.3.0 update added socket notifications for data - which means you will need to restart your MagicMirror application in order for it to receive data, you can’t just reload the browser page (you’ll only have to do this this one time, though).
          • bheplerB
            bhepler Module Developer
            Your first module you say? Wow. Coming in strong right out of the gate. Well done!
              PhiDeltDexter
              Love the screenshots, its exactly what I am looking for for a dashboard. However I cannot get it to load. I have gone through as much troubleshooting as I can think of, including starting over from scratch with a new RPi image.
              I go through the steps for setup and enter the numbers necessary from my Nest Developer account, PIN etc. It gives me the attached response with a token.
              The issues that the token comes across as
              token:"c.Ythenabunchofletters
              thoseletterscontinue }
              So my question is - is the "c. part of the token? I have tried copying the whole thing and it throws an error when reloading MM.
              module: "mmm-nest-status",
              position: "lower_third",
              config:  {
                             token:"c.Yblah
              moreletters           }
              I have tried copying the "c.yblah without an end quote and add a , and it throws an error.
              token:"c.Yblah,
              When I run config:check in MagicMirror folder it says there are no syntax errors but when I reload MM it throws an error.
              I have tried adding a " to the end and a , and MM loads, but my icon looks like this:
              token:"c.Yblah",
              The README shows as an int for the type so I should not need the " ", but thats the only way to make MM load.
              I have also tried all of the above steps without the c. and it still shows the loading icon.
              I apologize if this is something very simple that I just cannot figure out, so any help would be appreciated.
              D michael5rM 2 Replies Last reply
                dazza120 @PhiDeltDexter
                @phideltdexter said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
                config:  {
                               token:"c.Yblah
                moreletters           }
                token:"c.Yblah,
                token:"c.Yblah",
                So yours is like this try belows config just put in your token number
                module: ‘mmm-nest-status’,
                position: ‘bottom_left’, // pick whichever position you want
                token: “c.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX”,
                displayMode: ‘all’,
                displayType: ‘list’,
                thermostatsToShow: ‘all’,
                units: ‘metric’,
                thermostatSize: ‘small’,
                alignment: ‘left’,
                // … and whatever else configuration options you want to use
                • michael5rM
                  michael5r Module Developer @PhiDeltDexter
                  @phideltdexter My bad - there’s a typo in the Read Me, the token should be a string, not an int (I have updated the module now to reflect this).
                  Try this in your config:
                          token: "c.XXXXXXXXXX",
                  where, of course, you replace c.XXXX with your actual token.
                  P 1 Reply Last reply
                    PhiDeltDexter @michael5r
                    @michael5r
                    Just wanted to update you. I needed to update both the mmm-nest-status and MM overall and now it appears to be working fine. Thank you for your clarification!
                    • michael5rM
                      @phideltdexter Great to hear - thanks for the update!
                        PhiDeltDexter
                        Would you have any way to add the outdoor temperature reading that the Thermostat has?
                        • michael5rM
                          Unfortunately, no - the outdoor temperature reading on a Nest thermostat isn’t actually coming from Nest; they send your location data to the Weather Channel (yes, really!) and then show the returned value on the thermostat itself.
                          As such, they don’t include the outdoor temperature as part of their API data.
                          • michael5rM
                            Just wanted to announce that there’s a new version out of both my Nest modules!
                            I added functionality to support Paviro’s MMM-PIR-Sensor module meaning that the modules can now be suspended & resumed based on movement detected through a PIR sensor (or whatever else you’re using for motion detection).
                            Check out the release notes here:
                            https://github.com/michael5r/mmm-nest-status/releases/tag/1.4.0
                            And for mmm-nest-cameras:
                            https://github.com/michael5r/mmm-nest-cameras/releases/tag/1.1.0
                            • E
                              eawalker1
                              This is my first module I am attempting to install, and keep getting a Nest API Error:null. Total noob here, but I have registered as a developer, obtained Nest token/pincode, and believe I input code correctly into config.js file per below.
                                  token: "my8characterpinfromnest",
                                  displayType: "grid",
                                  displayMode: "all",
                                  thermostatsToShow: "all",
                              Any ideas how to resolve the API issue?
                              • michael5rM
                                michael5r Module Developer @eawalker1
                                @eawalker1 If your token is 8 characters long, it’s not the correct Nest token. It should be a long-ass string that usually begins with c. I think you’re confusing the token with the PIN you get from Nest.
                                Did you run the getToken.sh bash script in the module? It has multiple steps - you start by entering the client id and client secret which then generates a URL you need to open in a browser to get a PIN.
                                You then enter the PIN in the bash script and on the next screen, it should display your actual token.
                                E 1 Reply Last reply
                                • E
                                  eawalker1 @michael5r
                                  @michael5r Nope, that did the trick. Thanks.
                                  • michael5rM
                                    @eawalker1 said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
                                    Great :thumbs_up:
                                      costascontis
                                      thnx for your hard work ,i really like this module,but its not updating right.When i restart MM works fine for few hours and then stops updating.My token is working fine ,i use it also to my Openhab setup .Also my other modules are all updating fine.My config is :
                                                             position: "top_center", // pick whichever position you want
        token: "c.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
        displayMode: "all",
        updateInterval: "60000",
        showNames: true,
        thermostatSize: "medium",
        // ... and whatever else configuration options you want to use
                                      michael5rM N 2 Replies Last reply
                                      • michael5rM
                                        michael5r Module Developer @costascontis
                                        @costascontis You configuration looks fine - the updateInterval is set to 60000, so it’s only pulling data every 10 minutes.
                                        What exactly do you mean that it “stops updating”?
                                          costascontis
                                          isnt updateinterval in ms?cause if it is then 60000 ms = 1min…
                                          • michael5rM
                                            @costascontis said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
                                            My bad - you’re right, it’s 1 minute :)
                                            • 2 / 4
