    MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!
    nestthermostatprotectsmoke detector
    65 Posts 18 Posters 63.2k Views 18 Watching
    • michael5rM
      michael5r Module Developer @dazza120
      @dazza120 said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
      @michael5r Hi yeah thats what i mean but that has shifted it further to the right and only the Nest protect battery stuff i need to move it in the opposite direction finally figure how to take a screen capture lol here is what i mean hue status lower right, the more bulbs you have the worse it will get as it moves up when bulbs are turned on! PS speeds aren’t this slow changed the config file for the speed test and it knocked of a zero so it was a 4 second test lol 0_1544518147439_2018-12-11-084242_1824x984_scrot.png
      It looks like the module is in the middle_center or bottom_bar position, though - which is why it it takes up the entire width of the page. Shouldn’t it be using bottom_left?
      D 1 Reply Last reply
        dazza120 @michael5r
        @michael5r said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
        bottom_left
        Yes you the man, i swear i did that and the MM just showed me a black screen changed it back to default and it worked. But that was it it looks good i might have to bring some modules back well at least compliments lol
          max64
          Love the module. (and I tried them all)
          2 humble requests:
          1. Any way to add a transparency setting to the entire graphic so that an underlying background pic can partially show through? (Can that be done via custom.css?)
          2. Can you add a “initial polling delay” config option? (similar to what is in the weather forecast module). My use case is a vertical monitor where I have two instances of the module loaded. One in top-right (Upstairs) and one in bottom right (Downstairs). Nest recommends polling of not more than once per minute with separate device per hour and token limits. I set up each instance of the module to use a different token, but as you can only set the ‘updateInterval’ it’s a challenge to get the two modules to stagger the calls. (And I think this is why i was getting “null” response displayed after a while… )
          1 observation: when using the “alignment” option, both text and graphics are justified according to the setting. This is OK for “center” and even looks OK for “left”, but it does look odd for “right” where the thermostat graphic itself is flush right of the allocated space (e.g., top-right), but the title text is also right justified (.e.g., Upstairs) and not aligned with the graphic itself. IMHO the text above and below the graphic would look best centered with the graphic, and then the whole block is “aligned” according to the setting chosen.
          Again…great work.
          michael5rM 1 Reply Last reply
          • michael5rM
            michael5r Module Developer @max64
            @max64 said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
            2 humble requests:
            Again…great work.
            1. Certainly - add this to your custom.css file and the dial becomes transparent:
            .mmm-nest-status .thermostat .circle {
                background: transparent !important;
            .mmm-nest-status .thermostat .dial-classic .dial-circle {
                fill: transparent !important;
            The !important means that this will also apply when the thermostat is heating or cooling (eg. it will no longer have the blue or orange background). If you only wish for the grey version of the dial to be transparent, remove the !important.
            If you’re using the classic mode of the thermostat, setting the styles above means you get a nice colored glow when the thermostat is heating or cooling:
            1. It’s already there - for some reason I just forgot to add it to the documentation. Just add initialLoadDelay with whatever value you want to your configuration. The value is in ms, so if you want a 1 minute delay, set the value to be 60000.
            2. In regards to your observation - that’s a legit bug, thanks for spotting it! The alignment setting should only apply to the graphic itself, not the text inside it. I have pushed an update that fixes it, so if you pull the latest version of the module from github, it should be fixed.
            It’s an interesting usecase you have - I hadn’t even thought about using 2 instances of the module to have separate thermostats displayed on the screen in separate locations.
            The reason you’re getting the null response is because of this:
            https://developers.nest.com/guides/api/data-rate-limits
            (I’ve updated the module to display a more helpful error message when that happens.)
            Anyway … it’s not a good idea to make 2 separate calls to the Nest API to get the data (that gives you even more of a chance to get that null error), so check out the latest version (1.3.0) I just pushed - if you use the same token in both module instances, they’ll only do 1 call to the Nest API and use the sockets to update both thermostats at the same time :thumbs_up:
            Thanks for the comments!
            • michael5rM
              Btw, for those of you with Nest cameras as well, I’ve just published a new module called mmm-nest-cameras which shows your camera streams on the mirror as well.
              When both of my Nest modules are installed on the same mirror and you use the same Nest token for both, they’ll share data streams to avoid unnecessarily pinging the Nest API.
              Check it out here:
              [card:michael5r/mmm-nest-cameras]
              M D 2 Replies Last reply
                max64 @michael5r
                @michael5r
                The right alignment text is perfectly centered over the dial. And the transparent background looks very very good.
                Switched the token to the same for both modules and set the updateInterval to 1.5 minutes on both also. No null yet… Using your socket method there’s really no reason to use initialLoadDelay to stagger the API calls.
                Many thanks.
                  max64 @michael5r
                  @michael5r
                  Is Nest Lock status next on your agenda?
                  • michael5rM
                    @michael5r
                    I’d love to, but, unfortunately, Nest doesn’t provide API access to their security system.
                    It seems silly - I mean, at the very least providing the current status (home, home guarding, away guarding) seems like it should be a no-brainer, but for now it’s a no-go.
                    Mykle1M 1 Reply Last reply
                      dazza120 @michael5r
                      @michael5r no freaking way! You’ve made another module I have to have lol 😂
                        culi831
                        The modules not update after the recent upgrade ???
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @michael5r
                          @michael5r
                          Could you give an example of how this is added to the config.js? Please and thank you.
                          electronOptions: {
                              webPreferences: {
                                  webSecurity: false
                          • michael5rM
                            michael5r Module Developer @Mykle1
                            @mykle1 said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
                            @michael5r
                            electronOptions: {
                                webPreferences: {
                                    webSecurity: false
                            Sure - it’s just another object, just like modules:
                            • michael5rM
                              michael5r Module Developer @culi831
                              @culi831 said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
                              Both the nest-status and nest-cameras modules should be working just fine - what issue are you having?
                              Bear in mind that the latest 1.3.0 update added socket notifications for data - which means you will need to restart your MagicMirror application in order for it to receive data, you can’t just reload the browser page (you’ll only have to do this this one time, though).
                              • bheplerB
                                bhepler Module Developer
                                Your first module you say? Wow. Coming in strong right out of the gate. Well done!
                                  PhiDeltDexter
                                  Love the screenshots, its exactly what I am looking for for a dashboard. However I cannot get it to load. I have gone through as much troubleshooting as I can think of, including starting over from scratch with a new RPi image.
                                  I go through the steps for setup and enter the numbers necessary from my Nest Developer account, PIN etc. It gives me the attached response with a token.
                                  The issues that the token comes across as
                                  token:"c.Ythenabunchofletters
                                  thoseletterscontinue }
                                  So my question is - is the "c. part of the token? I have tried copying the whole thing and it throws an error when reloading MM.
                                  module: "mmm-nest-status",
                                  position: "lower_third",
                                  config:  {
                                                 token:"c.Yblah
                                  moreletters           }
                                  I have tried copying the "c.yblah without an end quote and add a , and it throws an error.
                                  token:"c.Yblah,
                                  When I run config:check in MagicMirror folder it says there are no syntax errors but when I reload MM it throws an error.
                                  I have tried adding a " to the end and a , and MM loads, but my icon looks like this:
                                  token:"c.Yblah",
                                  The README shows as an int for the type so I should not need the " ", but thats the only way to make MM load.
                                  I have also tried all of the above steps without the c. and it still shows the loading icon.
                                  I apologize if this is something very simple that I just cannot figure out, so any help would be appreciated.
                                  D michael5rM 2 Replies Last reply
                                    dazza120 @PhiDeltDexter
                                    @phideltdexter said in MMM-Nest-Status - New module for your Nest thermostats and protect smoke detectors!:
                                    config:  {
                                                   token:"c.Yblah
                                    moreletters           }
                                    token:"c.Yblah,
                                    token:"c.Yblah",
                                    So yours is like this try belows config just put in your token number
                                    module: ‘mmm-nest-status’,
                                    position: ‘bottom_left’, // pick whichever position you want
                                    token: “c.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX”,
                                    displayMode: ‘all’,
                                    displayType: ‘list’,
                                    thermostatsToShow: ‘all’,
                                    units: ‘metric’,
                                    thermostatSize: ‘small’,
                                    alignment: ‘left’,
                                    // … and whatever else configuration options you want to use
                                    • michael5rM
                                      michael5r Module Developer @PhiDeltDexter
                                      @phideltdexter My bad - there’s a typo in the Read Me, the token should be a string, not an int (I have updated the module now to reflect this).
                                      Try this in your config:
                                              token: "c.XXXXXXXXXX",
                                      where, of course, you replace c.XXXX with your actual token.
                                      P 1 Reply Last reply
                                        PhiDeltDexter @michael5r
                                        @michael5r
                                        Just wanted to update you. I needed to update both the mmm-nest-status and MM overall and now it appears to be working fine. Thank you for your clarification!
                                        • michael5rM
                                          @phideltdexter Great to hear - thanks for the update!
                                            PhiDeltDexter
                                            Would you have any way to add the outdoor temperature reading that the Thermostat has?
                                            • 2 / 4
